13" Style Steel Trim Rings
Date: 10/09/2020 10:35 pm
Front Body parts needed
Date: 02/09/2018 06:09 pm
Date: 11/04/2018 02:34 am
Windshield
Date: 01/15/2022 09:31 pm
Date: 07/20/2018 03:00 pm
Date: 09/20/2018 11:01 pm
parts needed
Date: 02/20/2017 07:58 am
Date: 07/21/2017 11:49 am
Date: 04/21/2017 02:03 pm
  • Online today: 645
  • Guests: 522
  • Total: 522
The Redrocket, my 1978 Pinto project.
Started by 78pinto, March 07, 2004, 08:24:51 PM
megasquirt is built and it works!
Quote from: turbopinto72 on March 09, 2006, 11:26:43 PM
Jeff, my bigger concern is your wife lets you solder on the kitchen table???
ummmm YEA! If i f@#k it up.....she thinks i have to buy her a new one :laugh:
Quote from: CHEAPRACER on March 09, 2006, 10:35:39 PM
I've also been following & considering the MS  but I want to know if it's a race only application or if it can be reliable for everyday use. Keep us posted.
Yes its very reliable, just have to tinker with the tune till you get it right. (get the wideband O2 with it.......it will really help with the final tuning.)
CHEAPRACER
LOL, its an electronic engine controller (like Fast, Big stuff 3, DFI ect) its VERY cheap but you have to assemble it. Here is the link, Brad, this would be great on the Green beast.      http://www.megasquirt.info/
no it won't be till next year!  Here is a picture of my dining room table as i assemble my new ECM (megasquirt) when i started......the table was FULL of those little packets containing electronic parts!
Do you need sun glasses to walk in you're cellar?
Looking good that maybe this year you'll have an avatar of the Red Rocket with the front wheels up.  :fastcar:
I just bought a Innovate LC-1 wide band O2 sensor for the set up. This will be tied in with my Megasquirt EFI (ordering that this weekend) and will control my air/fuel mixture. The wideband O2 are very accurate and have 5 wire sensors, they are great for tuning any car (carb or EFI) but are very important to any boosted application (turbo, supercharger, NOS...ect) so as not to burn holes in pistons....or take out head gaskets, if the mixture is too lean.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1,1&item=8038744547&sspagename=STRK%3AMEWA%3AIT
This version is all i need, it connects to my EFI controller and i can data log off of that to a laptop and get all the vital info from idle to wide open throttle. There are other wideband O2 setups that are stand alone and have built in gauges and datalogging, they start at about $350
My very large front mount intercooler is on its way, it got held up a Customs for a bit but was finally released today. Once all the parts arrive i'll take a picture of them all piled up on the floor.......my god i have alot of work to do this spring!
hmmm i think the motorcycle spent more time riding him!  ;D  I didn't say it was going to be a cheap street car! ;)
dirt track demon
I like the use of the words " its just a street car",  with all youve done to this thing so far, that's like saying Evil Kneivel was just some guy who rode a motorcycle! ;)
Fomoco's biggest achievement:
The PINTO!!
Fomoco's biggest mistake:
I have most of the stuff for the mach up now. Just need some mandrel bends and i'll be good to go. The turbo is back from Cherry Turbos, they did an awesome job on the machine work to fit the Garrett T4 .96a/r turbine housing to my Holset HX40! The housing has a 3.5 inch exhaust outlet.....i'm sure it'll be fun finding room for the down pipe :'(
Ordered my T4 turbo flange, and three 2.5 V band flange kits (for the crossover) and a Tial 46mm wastegate, the turbo is still in the shop getting the Garrett housing machined and fitted. Up next will be a crossover merge and various 2.5 inch mandrel bends along with a 3' 90 degree bend for the turbo flange. In the spring i'll take the car to my buddies shop and build the headers (mustang shorties flipped) crossover, merge and turboflange, then i'll do the compressor side with intercooler. I'll put my headers back on for the summer, and over the summer i'll weld all the joints solid and have everything ceramic coated (including turbo) and then start working on the roller 351w block.l
thanks Pete.....its a start!  I just took it in to the local turbo shop to have a Garrett T4 style .96 A/R turbine housing machined to fit. Next up will be the 50mm external wastegate.
thanks, it should turn out ok....i hope! If i do a twin with these....i'd have enough airflow for about 1200-1300hp :o  if i could spool them each off 4 cylinders at all (possible with the 408 and smaller turbine housings 12-14cm) but no, it's just a street car......for now! :angel:
Brad, glad the shiny police approve! ;D
71hotrodpinto
WAIT WAIT WAIT !!!
I thought this was going to be a TWIN TURBO !?!
comon! you cant make 1000 rwhp with just one!! LOL  ::)
You might want to read this article on a sn95 mustang making just over that on a 331 stroker TT while running on E85 ethanol
there are some benifits to running it. one of which is its around 2 a gallon and has about 104 octane!! there are some disadvantages though primary being that its hard to come by.
check this link
http://www.turbomustangs.com/techarticles/e85dyno.php
check the video of the dyno run, its wicked.  8)
anyways i admire your work man its top notch and, Id bet your turbo setup will scream!
Robert
Very Shiny " approved by the Shiny police :police:"
got it back from the polishers, next, the hotside has to be ceramic coated!
I took the turbo apart today and dropped the compressor cover and discharge tube off at the polishing place. Next week at least half of the turbo will be shiny! ;D
Update, got my NEW Holset HX40 today, i'm VERY happy....price for this $1000+ turbo.....my time to wire a '79 F150 for an E.F.I. 302! They scrapped 34 of these last week, and theres nothing wrong with them, they are new and only had dyno time on them to ensure the engines ran before being shipped (2005 8.3 liter Cummins Diesel) They were sent with the wrong turbos hung on them, so the right ones were sent and put on and they were told to just scrap the 40 wrong ones......$40 000 down the tubes! :o As i said my friend saved 6 of them....what a waste! PICTURES!!!! Yes Brad....i'll make it shiny, hotside will be ceramic coated the compressor side will be polished 8) This turbo will support over 650 horsepower
no secret.... i'm gathering parts till NEXT winter to do the turbo thing. My roof ate up my play money so i'll have to wait. On a side note, a friend got me a Holset HX40 (new) to put on my car! I've yet to see it but he has it (actually he has 6) They are off Medium to light duty Sterling trucks (they build them in my city) The engines were damaged so they remove some parts and send the engines back, the parts are kept in a warehouse for a year incase they need them, then they are scrapped!! :o  Buddy kept 6 and threw out 20 perfectly good turbos :'(
gpinto2
Hey Jeff,you know I just had to bump this up to the top since we have not heard anything since Sept.,or is this becoming top secret? ;D ;D ;D
1972 Pinto 410,C-4
Quote from: turbopinto72 on September 20, 2005, 06:35:41 PM
Cool............make sure the turbos are SHINEY............
you know it buddy! ;D I'll polish the compressor housings by hand, the turbine housings i'll have ceramic coated along with the hotside piping after they are built. The cold side piping will be powdercoated. I'll get the T3's i think, i'm just making sure the compressor wheel trim is the same from the buick and ford.....i don't want the buick .42A/R I know the ford is a 60 trim, i'm just not 100% sure on the buick.
I happened upon a roller block 351w for $150 so my turbo motor will remain 351w based, but not likely a stroker of anykind (won't need more cubes) My thoughts thus far are as follows...
'95 351 roller block, bored 30 over (357)
stock crankshaft with ARP main studs and girdle
Scat forged I beam rods and TRW forged dished pistons
Ford motorsport roller "F" cam (.510 .510 lift)
My Windsor Sr. heads
My extrude honed GT40 lower intake with box style upper and 75mm throttle body with 42lb injectors
flipped mustang shorty headers...extended as needed to mate with turbos
TURBOS- i'm leaning towards 2 buick T3's with exhaust A/R of .82 and changing the compressor housing from the nasty Buick ones (.42 A/R) to a set of .60 A/R's from a Ford T3
OR- i might try 2 IHI gm8's from 6.5 GM diesel engines. I have one and would need another. The Buick turbo's i can get 2 of them really cheap.
The T3 turbos will support 300 hp each and the IHI's will support about 400hp each, more than i need for sure ;D TIMELINE- my roof set me back about a year on this, so i'm going to gather parts till fall of 2006 and go for it then i think.
i can't remember what spring i got.... they will help you out at the rod shop, they picked it out for me.
71hotrodpinto
Quote from: 78pinto on August 20, 2005, 08:28:25 AM
sorry about that, i had it set so i didn't get email notification of my pm's..... i changed it now.  You can buys these at any rod shop. They cost me about $650 CND dollars
Ok cool. A bit pricey, but i can save up. So what spring rate did you use? I only have a 302 ,as you have the 351 weight.
Thanks for the reply !
  ;D
