Two 1978 Pinto Station Wagons
Date: 05/18/2025 03:10 pm
Date: 06/18/2018 03:47 pm
1980 Pinto w/ Trunk
Date: 08/10/2022 04:09 pm
free transmissions
Date: 11/28/2019 10:21 am
74 Pinto wagon armrests
Date: 01/18/2017 07:04 pm
Date: 11/11/2019 03:38 pm
Pinto Runabout wanted
Date: 06/05/2018 04:42 pm
Date: 07/17/2019 05:23 pm
1974 Pinto Door Handles
Date: 03/07/2017 04:06 pm
  • Online today: 536
  • Guests: 521
  • Total: 521
The Redrocket, my 1978 Pinto project.
Started by 78pinto, March 07, 2004, 08:24:51 PM
You would think that those injectors/ecc would work ok. Its not like they cant be over-driven. How is the voltage to them? do you get a drop at all? does the air meter get a voltage drop? I know that with my Green car I had to install a 120 amp alternator to make sure the battery was allways fully charged. If the Batt was low the VAM would not work right.
yup, i checked the function, and its clean (new) I was told that 42lbers are on the edge of the A9L's capabilities....but i wanted to at least try it.
i'm having idle issues, i think my EEC (electronic engine control) is having a hard time dealing with my 42lb injectors. The idle surges up and down, it sometimes gets so bad it stalls. I'm considering the stand alone EFI system Megasquirt. I'll keep you'all posted
I set the idle today.....and got rid of the nasty whistle coming from my TB/upper intake. I used a dremel and champfered all the various openings in the intake and the throttle body, no real easy task but it seemed to work....so it was worth the effort. Time to put some miles on it so i can beat it up at the track soon ;D
dirt track demon
as long as it was fun. On the bright side you weren't the one who had to walk ;D
Fomoco's biggest achievement:
The PINTO!!
Fomoco's biggest mistake:
The Pinto is finally home! I took it to the local cruise night last night, and my god does it ever have the power ;D  When the cruise was done i ran out of gas on the way to the gas station :-[  my wife went and got some gas in a gascan for me.....but i couldn't get the pump to reprime, what a pain in the a$$. I had to cut my fuel pump positive wire and bypass the computer controll and hook it up the the battery direct to keep the pump going long enough for it to prime. Lesson learned, i'll be hooking up a fuel gauge soon! ;D
dirt track demon
Ok, I looked at a lot of different aluminum rads before I bought the one from speedway. And I hadn't seen one like yours, so that explains why.  Thanx.
Looks awesome.
The PINTO!!
The rad is a custom made unit, it is a copy of a Mustang II 302 rad that was in my car. I had them add 2 inches to the hight of it.
dirt track demon
Looks really nice. It does look like it is supposed to be there.  Where did you find the radiator at?
The PINTO!!
Nice job!! Looks like that engine were meant to be in there. For the gauges I know Pintoman did that with his 80 Rally and it looks sweet. Dunno where he got them from, but I know Advance Auto Parts has the gauges that will fit in the openings, as should most other parts stores.
and another. Next i might tackle a complete dash rebuild, pull it out strip it down, paint it, put some nice aftermarket gauges  (Autometer) in where the speedo and gas gauge are. I'll start aquiring the gauges over the course of the summer.
some pictures of the completed install. Fixed the tack (wire was disconected) I'll be driving it home tomorrow!
Yes i did! I didn't get a new rack, but i did clean it up and paint the crossmember... ;D
Hey 78Pinto,
I was wondering if you ever cleaned up that nasty "VERY UN-SHINEY" crossmember and changed out the Rack&Pinnion???? "Oh... I'll swap out the rack Next time I have the engine out"
Sorry Dude... I think you jinxed yourself on that one.????
It lives, the 408 roared to life tonight! It turned over about 4 times, then the battery died (should have put the charger on) I put in on a fast charge, got in about 5 minutes later and it fired right up! No leaks, no "strange engine noises" , my only problem is my tack isn't working ??? I can live with that!(more wiring) Couple more days and it'll be ready for the street, i'll post pictures tomorrow.
dirt track demon
The PINTO!!
no of course not! I ground off the offending part of the oilpump! ;D
dirt track demon
, a BFH fixed the oilpan problem and a grinder solved the counterweight hitting the oilpump problem! ]
  You didn't grind part of the crank off did you?   That much horsepower an unbalanced crank will be self detonating.
The PINTO!!
i hope not 10's  ......it'll be my last trip down the track, they'd boot me off for sure! ;D
The Pinto is 99% put back together, i'm going to run the fuel pump with the feed line dissconected to make sure no debris gets into my new 42lb injectors. I'll recheck all hoses, wire connections ect, fill it with some crappy no-name oil for initial fire up and wait till its at operating temperature....check for leaks, and shut it off, drain it all out while hot. Put another new oil filter on and refill it with some good stuff. My buddy Frank fabricated me an airbag for the passenger side rear leaf spring to eliminate the squat it does when launching at the track, its on i just have to fit the air line and shrader valve and i'll post some pictures of it.....very cool, made with a transport truck air ride seat bag! I'll take it very easy on the new motor to break it in,........i'll wait till the end of the driveway when i turn on to the highway before i'll let it go! (about 150 feet) :o :o ;D ;D ;D ;D
one a side note....wish me luck....it's the FIRST engine iv'e ever fully built by myself.
OOOOOH! SHINEY!!!! lookin great '78 Pinto. If it runs HALF as god as it looks, you'll be in the 10's!
thanks Tony......if i blow this one up, my wife will KILL me! :-\
WOW That is SWEET!!!!!!!!!!!
Nice job 78Pinto.
KEEP us posted.
Oh! and try not to blow this one up!!!!!!! ;D
Engine is in.....and with only minor scratches! This is my buddy Tom, He has a '71 with a carbed 351w in it. See.....you don't need to cut out the upper rad support to drop a V8 in, so don't do it!
another.  My buddy Tom is coming over tomorrow morning to help me scratch the paint....er...put the engine in the beast. Should have it running by this weekend or early next week as i'm waiting on a sampling tube for my C&L 76mm mass air meter to calibrate it for the 42lb injectors.
Here are the pictures. Looks the same as last year from the outside.....but it's a 408 stroker! ;D
The 408 is assembled, and painted Ford blue with a nice clearcoat finish(very shiney)! I had some clearance issues with the oilpan and oilpump with the stroker rods and crank, a BFH fixed the oilpan problem and a grinder solved the counterweight hitting the oilpump problem! I'll take the trusty battery eating digital camera with me tomorrow and get some shots before i screw the paintjob up putting the engine in the car ::) :'(
I went last night and found out they take two spiral locks on each side, getting the first ones in was a pain......but putting in the second ones was way worse! :-\ :'(  I might blow the day off work to assemble the shortblock today.
Ive never had problems putting in the locks.
Hope I never have to take them out!!!!!!!
