1980 Ford Pinto For Sale
Date: 07/01/2018 03:21 pm
79 pinto driveshaft
Date: 08/18/2018 02:03 pm
1980 hood needed
Date: 04/23/2020 10:41 pm
1970-1973 Gas Tank/Blue Dash
Date: 02/07/2019 11:57 pm
FREE PARTS!!
Date: 01/10/2017 02:38 pm
parts needed
Date: 02/20/2017 07:58 am
need 1978 pinto guage cluster
Date: 03/07/2021 07:35 am
Many Parts Listed Below
Date: 04/20/2018 11:15 am
Date: 07/04/2017 03:26 pm
  • Online today: 645
  • Guests: 522
  • Total: 522
The Redrocket, my 1978 Pinto project.
Started by 78pinto, March 07, 2004, 08:24:51 PM
sorry about that, i had it set so i didn't get email notification of my pm's..... i changed it now.  You can buys these at any rod shop. They cost me about $650 CND dollars
71hotrodpinto
Quote from: 78pinto on August 13, 2004, 12:18:22 PM
new SHINEY Carrera coil-overs on the way.....its going to be the 6 cajillion dollar car if this keeps up! :o? I think my wife may want to divorse me.....
Hey there i sent you a pm but you didn't reply so ill try this ;) I was wondering where and how much did you pay for these coil overs?
I want some SHINEY  also !!  ;D
gearhead440
78, thanks for the quick reply and the info  :D!  I remember you saying in another post that you had used a 351w crown vic pan an d then I read the truck pan.  I have a truck pan for a 302 that is rear sump and was curious.  The 351w pan I have is front sump and is from a 75 351w passenger car (Montego).  It is still in the car but will be pulled very soon.  If I can get away without cutting it that would be sweet.  Or, I'll weld and piece as necessary, it just takes the most valuable commodity I have: time.   Take care, good fortuen and thanks again.
Quote from: gearhead440 on August 11, 2005, 12:10:18 PM
78Pinto, In another one of your posts you mentioned using a 351w pan from an F150.  Looking on ebay the info on that pan lists it as a rear sump pan that doesnt work for a 351w car block.  I am confused  ???.  Do you have any pics, part numbers or other info that I can use to get the correct pan?  Thanks
Holy crap....your right, where did i say that? You need a 351w pan from a Crown Vic police car or ANY front sump oil pan for a 351w. along with the pickup tube. sorry for any trouble this may have caused. I know my pan came from a Crown Vic police car and was modified. Pre '90 model i believe.
I found the post, i believe i was thinking about a 460 into a fox body car for an F150 pan (460 truck pan fits 460 into '79 to '93 Mustang) Not really sure why i would post that my 351w pan came from a truck??? Thanks for catching that,  Jeff
gearhead440
house roof.....i don't have a garage :-[  evryone is fine, 12 year old house and the shingles are screwed already!
Hey 78PINTO,
Are you talking about your house roof or garage roof?
Hope you and your family are OK.
big storm last night.....my roof leaked bigtime, $3100 to redo it....turbo project put on hold till fall.....crap! >:(
I'm going to do it all myself (except the dyno tune and chip, i have a buddy that does that) some of those turbo places (most really)charge upwards of 3-4 thousand for a custom kit and i can do it for a whole lot less!
pintojoeII
check out turbo people in n.y. jobey spetter does a lot of f.i. stuff for fords . they tune big dady dwanye drag radial car.and our blower car.
hmmm, turbos will boost any engine just fine provided it can handle the boost.
http://www.turbomustangs.com/feature_cars/craigwmarch.php
check this out, completly stock block and runs 10's  sounds great to me! ;D
The shop that has been of great informational help "Turbo City" has said to me many times that the Turbo 5.0 is "SLOW" compared to a HiPo ex. Your 408 version???
They explain that my 4cyl Turbo is a great BOOST in power but the V8 does not benefit as much from the Turbo.
Maybe you should build another Pinto W/ the turbo V8 and leave your 408 alone.
Maybe a 78 C/wagon.
COOL!!!!!
LOL  Yup, just put it in......i really want a turbo motor! It has all kinds of power....thats not the problem, i just love the sound of a turbo at full song.....er.....whistle i guess. My wife thinks i'm nuts, and maybe i am, i should have built what i really wanted in the first place and then i would have been happy. Turbos rule! ;D
OK...
Let me see if I have this correctly???
Didn't you just put that 408 in your Pinto???
Dosent it have enough power???
Why would you want a turbo 5.0?
WHATS UP?????????
From LOST AGAIN Pintony 8)
Talked to a Turbo builder and the 62-1 i'm looking at will support 630 hp (at the crank) but i dare not try that kinda power with a 302 block. I'll be re using my 42lb injectors for this build also, but i WILL have to get a custom chip done for it for sure. I have a buyer for the 408 short block at the end of fall, the heads and intake will come off and be for sale if anyone has an interest. The headers will be for sale also, as i'll be fabbing up a set using 5 liter shorty headers as a start. They are Hooker super comps for a 302 but were MODIFIED for a 351w using mustang II motormounts and a C4/C5 tranny.
Quote from: 78pinto on July 07, 2005, 11:29:36 AM
here is a look at the 62-1 turbo. It is based on the TO4B turbocharger but has a larger compressor wheel and housing. I'm thinking i'll mount it on the passenger side in the fenderwell, so i don't have any problems getting the down pipe (will be 3 1/2 inches) around the steering shaft.
That out to get it done. Before you start your hunt for new parts, go out and buy the August eddition of Hot Rod Magazine and read the " Go fast on Pump Gas" article. Its really great and has a lot of usefull info especially on recommended compression vs. Cam duration.................... ;D
CHEAPRACER
Quote from: 78pinto on July 08, 2005, 07:20:04 AM
Quote from: CHEAPRACER on July 08, 2005, 12:51:28 AM
If I personally donated the bolts to hold the turbo on, can I have the first ride?
do you want my wife to kill us both? :o  You pay for the engine and you can borrow it for a week! ;D ;D
Hmmmmm, maybe not.
CHEAPRACER
Hey Brad, i'm thinking Master Power 62-1 p trim .70 a/r cold side with a .81 a/r hot side. Should be good for 500-600 hp (more than what i need, yet if i ever do decide to wick it up, i can!)
well, for starters.... it has a 10.5:1 compression, so it's not really boost friendly (unless i run race gas) it also has 42lb injectors....that is the maximum i can go on the stock electronic engine control without going to a stand alone efi system. It will also create ALOT more heat underhood and i'm having issues with it idling for long periods and staying cool now. The 408  makes alot of power as it is, i can't really use any more (i can't believe i just said that!) without a rollcage and lots of safety equipment, and this is a street car FIRST.....i have to be able to pile the wife and kids in. A 302 with a near stock engine and a 60mm turbo will make just as much power as my 408 in its current configuration (a cam change, and a 150 shot of nitrous would put me in the nines i'm sure) with  106 cubic inches less, better gas mileage and alot better cooling. Most of all.....i love the sound of a spooled turbo in full song ;D :o
pintojoeII
dirt track demon
Uh  huh.  You probably have more in the heads of that 408, than I have in my whole ride. ;D
Fomoco's biggest achievement:
The PINTO!!
Fomoco's biggest mistake:
Quote from: dirt track demon on July 03, 2005, 01:00:55 PM
You must have too much money. ::)
oh to be rich! Then.....then you would see a PINTO! Notice i said sell the 408.....to be able to afford to turbo a 302.
CHEAPRACER
Quote from: 78pinto on July 03, 2005, 12:20:41 PM
What do you-all think, am i crazy or should i just do it?
I think everything should have a turbo.
dirt track demon
The PINTO!!
The car runs good now......but i'm just not into it. My heart is really into turbocharging, i'm seriosly considering selling the 408 stroker and building a 302 EFI (roller block) with a single turbo. :o  My wife is supportive.....thank god for that, and just wants me to be happy with the car. What do you-all think, am i crazy or should i just do it?
Yeah, I know what you mean. Thats why I bailed on my EFI set-up on the green car. It got to Frankenstein for any of the factory stuff to handle even with a chip.
Iv'e checked it all Brad. I have even tried "clocking" my mass air meter to see if it has a sweet spot. I'm going to give it another try today. I set the idle up again last week and have started it a couple of times since and it seems to be fine, i'll start it up and take it for a spin and see what happens. If it buggers up, it will become Megasquirted.....i'm gettin tired of the factory set up causing problems anyhow! ;D With the Megasquirt, it's a speed density system with no mass air meter....i like that!
