Date: 07/01/2019 03:17 pm
79 pinto steering column
Date: 08/18/2018 02:00 pm
Date: 10/24/2019 01:45 pm
Date: 04/13/2018 11:30 am
pinto wagon parts
Date: 12/19/2019 01:43 pm
Drip rail chrome
Date: 01/14/2017 09:18 am
78 pinto wagon
Date: 06/04/2020 12:42 pm
Date: 03/14/2020 01:52 pm
Mustang II C4 Transmission
Date: 07/28/2017 06:26 am
  • Online today: 553
  • Guests: 242
  • Total: 242
The Redrocket, my 1978 Pinto project.
Started by 78pinto, March 07, 2004, 08:24:51 PM
Wow Jeff youre car is looking great. The interior is bitc hin.
As for the hood scoop.....I think it looks too big for the car. Then again I like the second shot. I think the design doesnt match the Pinto.
Maybe when its painted it might blend.
maybe i'm too used to the old scoop, not really liking it at all. :'(
Poison Pinto
Honest opinion?
You're right. It needs to be red like the rest of the car and the seams where the scoop meets the hood need to be de-emphasized a bit with body filler sculpted and sanded smooth.
the hood is done.....not really thinking i like it. It needs to be red and have the screw holes filled, but that wasn't an option as i have to wait till this winter to have it painted. With it being black it really draws attention to it and thats not what i was looking for. Opinions wanted.....honest ones!
Poison Pinto
soon i'll redo the back seats to match the front ones, but for now, it will stay as is. This is a before picture. I see it started a new page, if you go back to page 4 the first pictures i just posted are there.
oh and i put on a 5 liter Mustang fresh air, fenderwell kit to draw cool air from the fenderwell, instead of hot engine compartment air.
ok, here are some pictures.  I painted the center tray black (it was red) and it turned out great, i may do the same to the kick panels as they are faded really bad. I made the scuff plates out of 1/8th inch aluminum checker plate, the factory ones were oxidizing badly....and the carpet was put in the die off center and the edge was not long enough to go under the tiny scuff plates.
Seats are in, if its not raining tomorrow i'll snap some pictures, i also ordered some 1/8 aluminum and will be making my own door sills as the factory stuff is nasty looking and corroding badly. To anyone wanting to put plastic racing seats in there Pinto: The pasenger side is different in that the seat mounting brackets are closer together (left bracket is about an inch or so closer to the outboard bracket) I did not see this and made up two mounting plates the same, needless to say i had to modify the passenger side to make it work! :-[   Live and learn......measure twice....cut once!
well, the carpet is in! The trunk has been insulated and carpeted, my batteries died in the camera before i even got one shot of it before install...i'll take some tomorrow. Seats are next!
NOS Reproductions in Komoka, Ontario Canada. $198 Canadian funds, i think they said they are made by a company in Georgia....but i might be wrong on that.http://www.nosreproductions.com/
Poison Pinto
Snazzy seats, Jeff.
Who makes the repro carpet? I'm planning on redoing my interior in black, so I need to grab some repro carpet that fits in without a bunch of cutting and fitting.
the seat with cover on
is it ever REALLY over.....no... so i started on my carpet and seats last night. Becky and i took all the interior trim off, removed the seatbelts, took out both front and rear seats, and removed the old faded red carpet. I bought a black reproduction, along with some extra carpeting to do the trunk also. I also bought some dynamatt to try and keep the engine sounds and the electric fuel pump sound from entering through the firewall and trunk area. I'll be using high density fibre board to block off the trunk behind the rear seats. I'll post some pictures later. My floor pan has a bit of surface rust, so i'll be hitting it with a wire brush then a good coating of tremclad. Factory seat brackets and sliders will be going on my plastic racing buckets....but they are nowhere close to lining up, so i'll be fabricating some adapter plates.
Poison Pinto
QuoteMy project is finished for now.
Congratulations!
I can hardly wait for the day I can say the same....
I think i have everything worked out fine now. I put some resisters in where the EGR, TAB, TAD,EVP selenoids were (came in a kit for this purpose) They trick the computer into thinking it's all still there, but not opening (better than no raedings at all) Idles great, goes like hell, smokes the tires untill i let off (sidewys in a big hurry!) Line lock is in and works great....BUT, I'm still waiting for my hood to get finished. He says Monday or Tuesday (its all cut and fitted, just has to paint it) I'll be taking it to the Tuesday night cruise with or without the hood! My project is finished for now.
well i fired it up today, a few minor coolant leaks (fixed) then i broke the valvetrain and cam in for about 20 minutes at between 1500 and 2200 rpms. It would not idle at all just kept stalling. I dissconected the battery for 20 minutes, unplugged the idle air control, fired it up and set the idle to about 950 rpm with the throttle stop, shut it off reconected the IAC started it again and set the TPS to .98 volts and it idles perfectly! I still have a small annoying vacum leak on the upper where the tree is located, i'll pull the upper and fix that tomorrow.
thanks Brad, once i get it all sorted out.....i'm gonna go looking for some chevies! lol
pinto_351
i am very jealous now for two reasons.  1) your car is running and 2) it looks awesome under the hood.  Good job Jeff it looks killer hope it runs well.  If you want my friend with the nova is runnin his mouth about fords especially pintos.  wanna come clean him.
Brad #2
Started it up tonight! Some minor issues arose, leaks and whatnot.....but it RAN! Sounds awesome, i'll be playing with the timing and whatnot tomorrow. Every neighbour within a 1 block radius came out to see what was making all the "noise"!
Looks great.
Start it and do a wheely.
done....sort of. i'm gonna start it tonight or tomorrow.
If it won't Jeff I'm sure you've got the resources to get it running. nuttin like bein' a Ford "insider" LOL
