Pangra wanted
Date: 02/05/2017 01:58 pm
Date: 08/01/2018 01:27 pm
Front grill for '72
Date: 03/02/2022 12:09 pm
Date: 08/08/2017 01:44 pm
1978 RUNABOUT
Date: 04/01/2017 03:18 pm
77-78 front grill
Date: 04/07/2017 12:35 am
ford pinto door panels
Date: 03/20/2022 07:51 pm
Date: 03/06/2019 06:40 pm
Date: 01/28/2019 05:15 pm
  • Online today: 323
  • Guests: 291
  • Total: 291
The Redrocket, my 1978 Pinto project.
Started by 78pinto, March 07, 2004, 08:24:51 PM
my rad slipped right in....with the help of my cutoff wheel :o  bought all new hoses today, i'll put them on Monday and snap a picture or two. Had to "modify" my thermostat housing a bit (yup, with the cutoff wheel) to make the outlet more level to the rad hight. I'll be firing it up next week, just have to put my new A9L computer in first, and ground pin #30 and install a few resistors where sensors once were. (no EGR, TAB, TAD, EVP ect.  no smog stuff!)  ..............god, i hope it runs.... ;)
got my new (shiney ;D) aluminum rad today, $776 Canadian....cha ching :-\  Looks goooood though, i'll be puting it in tomorrow.  Pictures will come soon after. My hood is still not done yet >:(  hopefully this week, or i'll be cruising around town without one!
its pretty stiff really (the front end i mean) The springs are cut down....but they are 302 "air" springs so hopefully my shiney headers stay off the road!
Jeff, you WILL have more clearance after your 1st wheelie... the pan, headers,& exhaust will be flattened!!!!
I"M KIDDING!!!!
I wouldn't wish that on you or ANYONE! 3.5" ought to be fine, but if you want to absolutely certain you could put some X-large bumpstops in among the shiney stuff in the front end
Well....more money spent today. Just ordered a Harwood cowl scoop  43x29.5x4 inches high! At 43 inches long i'll be cutting some off....unless front overhang would look cool? :D ;)  It's a bolt on scoop.
Yes it is....and its gonna stay there untill the next time i pull the engine! Then i'll clean it all up, replace the rack (might as well, everything else is new) put in my new bushing and make it look shiney. Untill then.....screw it! ;D
 Jeff, Is that dirt and oil I see on the rack ?????  >:( >:( >:(
Dirt/Oil not shiney......bad............ :o
yup lots of room for wheelies! It's the landing that'll kill me! :o :'(
That sure is a purty engine. Dont worry about the ground clearence. Youll have plenty after your first wheelie.  ;)
about 3 1/2 inches of clearance :o
more pics! I need a new custom rad now, my alternator is in the way! More freakin $$$ The 6 million dollar Pinto for god sakes ;D
 Shiney , .........Good.........spend more $$$. We want to see more shiney stuff.......... ;D
They look kinda like plastic model parts in the pics.  :P
Youll just need a flashlight as a droplight when you work under the hood, theres so much shiney. ;D
I still have to finish a roll of film before I can show my less shiney parts.
i hope so too! I'll take some pics tomorrow after its all installed.
OOOOOHHH SHINEY!!!  ;) those will look plum sharp on your 'Lil Horse Jeff!! (I hope they make it as fast as it is SHINEY!!)
yes, intake and headers both ceramic coated, I cut off  two complete coils, plus about an inch and a half or so. The springs are 302 with air for a mustang II
straw boss
Cool!
Are the headers ceramic coated?  Also, how much did you end up cutting off the springs?
intake pic........and it only cost me a kajillion dollars! :-\
well it sits normal now...only had to take the front left side apart and back together 3 times! :o >:(  Hit or miss, i decided to cut the springs a little at a time....didn't want to cut too much off and scrap a new pair of spring. Right side i just cut off once at the same point as the final  cut on the left....looks good. Brad... got some shiney pieces today, my ceramic coated headers and intake finally are done! They are going on Friday. ;D
brad, any idea how much i should cut the coils?
not fun,  i may go as much as a coil and a half! It's way up there...it looks like one of those "gassers" from the '60's  What do you think Brad?  EDIT: look at my avitar photo, kind of like that....but sitting still!
Wow  :o
I was wondering about mine after getting it on the ground and its still maxed out. After I saw the size of the t5 that came out of the Tbird today, I dont think there will be a problem.
I dont know how many coils to cut.  ???
well, its what i thought would happen, i dropped her down from the stands and the front end sits way too high, i now have to take it apart and cut the springs >:( :'(  was thinking of cutting off one full coil, any thoughts on this, i need to lower about 2-3 inches. I hate cars...... ;)
Yes, i have no sway bar. They are for people who want to take corners fast.....my front rims, at 3 1/2 inches wide, don't WANT to be cornered fast! It is set up for the dragstrip, no corner carving for me. I'm not sure on the weight savings.....but there is a big difference in the weight of the two of them. Next time i have to pull the motor i will get a new rack and put my new bushings in.
Nice Pictures. I started to forget what a complete front end looks like. Do you always run without a swaybar?
Those tubular arms really give ya some room. What was the weight savings?
Shine on 8)
Brad, i think i'm buying an MSD pro billet distributor in about an hour, and ya know.....its freakin shiney ;D  *update* I bought it for $177 !
again
suspension
