Date: 01/30/2017 01:48 pm
Bell housing
Date: 08/23/2017 05:41 am
front end parts
Date: 03/30/2018 12:48 pm
Date: 01/23/2023 02:22 pm
Wanted - 71-73 Pinto grill
Date: 12/15/2016 03:32 pm
Date: 08/30/2021 03:20 pm
79 pinto driveshaft
Date: 08/18/2018 02:03 pm
Date: 03/30/2021 12:29 pm
6.6.75 carrier
Date: 02/14/2018 06:47 am
  • Online today: 536
The Redrocket, my 1978 Pinto project.
Started by 78pinto, March 07, 2004, 08:24:51 PM
Huh Hh, He said snow...... ;D Snow is NOT shiney......... :'(
the nitrous kit is installed now, just have to fill the bottle, put my new filler neck on and i'm ready to rock......except....it feels like its going to snow! :o >:(  I'll snap a few pictures on the weekend. Ive set it up for a 75 shot..... if i use the 150, i'll get booted from the track in a hurry!
DiDn't work Brad, if i connect the two wires the guege goes up, if i try it through the sender it does not work. Must be the wrong one. Gues i'll be getting an aftermarket gauge!  thanks
No idea, it was bought off Ebay, its new. Crap, i didn't know there was a difference! I'll mess with it and see ft it will work, my fuel filter was clogged up with all kinds of crap, i drained out the cell, cleaned it and the filter, installed the sender and put it all back together yesterday. Thanks for the info, hopefully it will work!
OK, well the black would go to a grond source on the tank, you probably will need to attach a ground lug some where on the sender. then it should be simple to use the factory wires. If its white or yellow it should go to the center post. Do you know what Ohm sender you have. the ford's are like chrysler and NOT like GM.
no autometer gauge, just a factory set up. The loom has two wires in it, black and i think white....or maybe it yellow. My sender only has the center lug conector.
Yeah, the ground wire ( the tab on the sender that is NOT in the middle) go's all the way back to the guage ground. The Center post on the sender go's back to the guage and hooks up to the ( s ) post ( on a auto meter guage). Then the 12 volt ignition source is connected to the ( I ) post of the guage.
Hey Brad, any idea how to hook up an aftermarket fuel level sender in my fuel cell? I have two wires running from the old sender....and no real idea what to do. It seems my new unit only uses a one wire hookup.
the mufflers are 2.5 inch two chamber flowmasters
71ss351
I saw a video of you racing 78pinto, and I was wondering what kind of exhaust you had on yours, It sounds really good.
71 Pinto
351 Interceptor w/ comp 274 cam
C-5 Transmission
7.5 rear end with 3.73 posi trac.
the kit will be dropped off hopefully tomorrow before i go to work, i'm off next week, so i'll install it then.
Dry setup bought, and on its way, i have an aftermarket adjustable billet aluminum regulator (shiney) on the car allready. I'll only be spraying 50-75 shot, at 11.49 i need a cage and thats not gonna happen yet.
In a wet system the actual N2O injector has 2 nozzles, one for fuel the other for n2o. Take a fogger or plate system under a carb. One side of the spray bar has fuel solenoids the other the n2o. In a direct system the injectors have 2 nozzles to increase the fuel supply to compensate fot the n2o. the plumbing issues for a wet system are considerable, as you're adding a complete second fuel supply system. (pump & all) but the reliabiltiy & repeatability of a wet system are awesome.
A dry system has usually one injector in the intake pipe of an FI car, or in the breather of a carbed one. However in either setup you HAVE to add extra fuel to compensate for the n20. If not you'll discover quickly that n2o by itself is REALLY bad for pistons. Dry systems are great for a small shot of "naws" because of thier ease of installation, especially on FI motors. For a BIG spray you'd be better off using a "wet" system
Another Proviso for nitrous.. if you intend to add big # spray you MAY want forged pistons to handle the extra pressures & higher cylinder temps.
bricker4864
How do you add a seperate fuel system? Is the nitrous mixing with the fuel before it is injected? Do you just have a seperate injector for when you are running the nos?
If you run it dry, do you increase fuel pressure to keep the a/f ratio the same once you hit the button?
Yes. The two are defined by a seperate fuel system on the wet and using the factory fuel system on the dry.
bricker4864
Are we talking about a wet/dry NOS system? I didn't know there were different ways to run it. I am new to the world of nitrous. I know nitro though. Very fun stuff!
The Dry system relies on your fuel pressure regulator to slam shut ( the fuel return)and provide the 100 lbs pressure to the injectors for added fuel.This is a risk if you do not have a paxton fp regulator made with a kevlar diaphram. ( its even worse if you add boost but I wont go there). So, this does not allow you to regulate your fuel/nos ratio with any acuracy. With the wet system you can either use your existing fuel pump or add one. you have both a nos AND a fuel jet. You can regulate the fuel pressure with some degree of acuracy with a pressure regulator that was made for the system and even regulate the fuel pump output by the voltage you send it. Just my 2c
FYI, I had a dry setup on my Green car and it all works BUT if I had it to do over I would go with a wet system.
Are you going to do a wet or dry system?
the turbo is not meant to be, i have to change too many things to get that combo to work, (injectors, mass air meter, headers) and it is just too much money. So....Nitrous it is, with a 3200 stall convertor! My buddies STOCK engined '92 LX 5 liter runs 11.90's with a 150 shot, i'll only go 75 or so, should be good for low 11's  i have no cage so an 11.49 will get me booted from the track! I'll maybe use an adjustable time delay setup to kick it in when i hit high gear.
yes i was also thinking T04b  but....i can get the 8000km Holset HX35 for about $140 U.S.  I'll look into it and see what i can come up with. I'm only looking to run 6-8 lbs of boost, with rpms in the 5500 range so i won't need alot of turbo for that.
 I like the TO4B,S-3 trim for your car, Or you could do a T3/T4, 60 trim. BUT, to do it right it would be best to review all the compressor maps and see what trim would be most efficent on your combo. In order to do that you just need to plug in your specs on a turbo calculator like the one on Ray Hall Turbos and it will spit out the info. Then, find one thats close to what you need at a good price.
Tell me what you think Brad.... The Holset is cheap, i have Hyperutectic pistons, so i can't pump 12-15 lbs of boost to it, my shift point is 5500rpm. My guestamate for RWHP is about 400 to 450 with about 6-8 lbs of intercooled boost. Also, i can only go 11.50's or i will have to put a cage in it.....not ready to do that yet! What turbo were you thinking of? I was also considering a T04b......talk to me Brad ;D
Jeff, there are better turbos to use. Dont buy one yet !!!!  >:(
well....i have made a decision, i'm going to be putting a turbo in it over the course of the fall and winter. I'm thinking Holset HX35W from a Dodge Cummins truck. This is not me thinking about it......i'm going to do it!
Quote from: 78pinto on August 19, 2004, 09:33:54 PM
yes thats rust on the disks! I have no garage to park my baby in during the rain.
Jeff, I know I've told you this about as many times as dollars you have been spending latley, ;), But  Rust is NOT Shiney................. :-\ >:( :'( ;D
yes, most of that was pre-coating damage.....but some has been since they were coated >:(  its not right through though.
