Date: 08/17/2022 06:27 pm
Date: 04/14/2023 06:15 am
Date: 05/13/2021 05:33 pm
76 drivers fender
Date: 07/20/2018 08:24 pm
ENGINE COMPLETE 1971 PINTO
Date: 12/28/2017 03:55 pm
Anyone scrapping a 1980
Date: 03/13/2020 08:46 pm
1979 hatch needed
Date: 05/13/2018 08:52 pm
1980 Pinto Parts
Date: 08/05/2020 04:20 pm
Date: 10/31/2018 12:00 pm
  • Online today: 600
  • Guests: 343
  • Total: 343
The Redrocket, my 1978 Pinto project.
Started by 78pinto, March 07, 2004, 08:24:51 PM
Great!
Sheesh the one header tube on the passenger side looks like it is worn flat and through. I bet the ceramic coating helps alot.  Maybe you can adjust the front all the way up and get the wheels to come off the ground on take off. That would really cool while your lighting up the rears on fire. :o
straw boss
Quote from: 78pinto on August 19, 2004, 09:33:54 PM
Straw Boss-   Blow a seal in what? The shock is.....just a shock
Well, that's the problem.  Every couple of years my shocks start to leak.  I assume it is from the cold weather, but it could just be the nature of NAPA shocks!
we have had an unusual amount of rain this summer...and its been on the cool side too. They are a direct bolt on just like it said......nothing like duct tape, torches, welders or anything!
bricker4864
Is it realy raining in the middle of august? We're having the 'hot summer nights' car shows right now. There's boat races down the river this weekend!
I also get rusty brakes when I don't drive. The car lives outside while all the tools and spare parts live in the garage.
If I remember right, those coil-overs are advertised as bolt in. Did they really just "bolt in" or was there some other work to be done. (hammer, duct tape, torch...) They still look really SHINEY so it must not have been too bad?
yes thats rust on the disks! I have no garage to park my baby in during the rain.
Straw Boss-   Blow a seal in what? The shock is.....just a shock, the weight is supported by the stock upper spring pocket and the ring around the shock body. It rides 300%  better than the cut coils i was using. I'm very happy with them.
straw boss
Hey, that's pretty cool!  I wouldn't mind having some of those on my car, but since I drive it in the winter, I would be worried about blowing a seal in the cold weather.
How does that setup compare to the stock spring and shock absorber weight-wise?
bricker4864
coil-overs went in yesterday, the headers will be spared from anymore pavement scraping! They are a nice setup and the ride hieght is fully adjustable...... a bit pricey but well worth it. i'll post a picture later.
new SHINEY Carrera coil-overs on the way.....its going to be the 6 cajillion dollar car if this keeps up! :o  I think my wife may want to divorse me.....
bought the EEC tuner today (crane interceptor II) and may have a nitrous kit by tomorrow if all goes well!
i decided the turbo is not a real good idea with my pistons.....maybe on the next engine! ;D
pimpin_pinto
so what did you decide about the dodge cummins diesel turbo into the 351?  sounds like you got enough planned already though.
my front springs have settled.....they are too low at the front, i cut too much off them :-[ oh well live and learn! I decided to go with a front coil over shock set up instead of getting new springs. $349 bucks aint too bad, and best of all they are adjustable... and SHINEY!
     http://www.speedwaymotors.com/xq/asp/strBase_List./hilt./source.2192/base_no.2559000/str_base_no.000%2DCATALOG+STREET%2C1356021%2C25508%2C2551818B%2C2551866C%2C2551951%2C2552254%2C2553235A%2C2553243A%2C2559000%2C44408%2C58211%2C582C500%2C582SM%2C582SM400%2C7022506%2C721395%2C721485%2C721585%2C721785%2C/header_title.Street+Rod+Products%2DShocks+%26+Mounts/page_name.prod%5Flist%5Fdisplay%2Easp/search_type.L1%7E299/search_option./deptsearch./deptSearch_id.225/dept_id.L1%7E299/dept_id_p./dept_name./dept_name_p.Street+Rod+Products/ShowImages.yes/sq.0/cont.1/intPgNo.1/redirect./qx/product.htm
just have to decide what spring rate i need and i'll be good to go. I am also buying a programable tuning system for the computer (EEC) in my car so i can toy with injector pulse width, timing, air fuel mixture....from inside the car while driving. I'm getting a Crane Interceptor II. I'm also considering a 75-100 shot of nitrous......should be fun!
last trip to the dragstrip loosened up my 9 inch bad so i took it apart put new bearings, seals and gears in (3.50) its back together now and ready to rock! Those third members are very heavy and ackward to put back in when up on jackstands!
now i'm thinking......single Holset HX35 turbo from a Dodge Cummins :o :o :o :o.....hmmm. I'm looking into it and will follow up on my idea later.
straw boss
Never mind.  I found your other post about the subframe connectors.
underside, headers
pimpin_pinto
i agree, with just a lil paint and some fiberglass work it will look so much better, too bad you have to wait until winter.  the cars looking great though....keep it up, and keep the pictures coming.  I see it looking like this if you molded the hood to the scoop real smooth and with a lot of work.
another...first one is a bonded look (previous page) this is filled bolt holes and painted red.
i had somebodt do some photoshop work on it here they are. I like this much better as opposed to being black!
losin sux
Ok, I thought I was on the right track about getting it "painted" for a better opinion.  I looks much better, seems to flow now, if you will, from the front of the hood.  It looks, for lack of a better description, blobby in black when I compare the 2.  IMHO
77 HB 2.3 C3 3.40
Poison Pinto
It's a rough job, but I think painting the scoop red is a big improvement.
JMHO.
Poison Pinto
It's rough, but I think taking on the color of the car makes it fit in much better.
72 sedan
I sure don't want to sound negative, but the new scoup just doesn't blend with the lines of the car. Something more soft, smooth, rounded--natural looking. Have you looked into full fiberlass hoods with built in cowl scoups?
Look alive SON, You're about to get your butt kicked!
sure, i'll private message you....check your pm's     Jeff
imperfection
hey man nice ride... do you think you could give me a hand with something .. im trying to find replacement doors and fenders for my 1980 pinto and im having a hell of a time trying to find them
Quote from: Glassman on June 14, 2004, 02:22:42 PM
Wow Jeff youre car is looking great. The interior is bitc hin.
As for the hood scoop.....I think it looks too big for the car. Then again I like the second shot. I think the design doesnt match the Pinto.
Maybe when its painted it might blend.
Yes i think it looks too big, but is that because its black and very obvious? I have to have it that big to cover the engine.... no choice.  Can anyone photoshop it red, filling in the screw holes?
losin sux
If you had the hood red after some photoshopping we might be able to give you a better idea as well as yourself.  I would like to see the scoop flow back more at an angle similar to the grill tilt.  That matching tilt might not be doable though.  Your ride is sweet nonetheless.  I'm JEALOUS!
77 HB 2.3 C3 3.40
