  • Online today: 536
  • Guests: 513
  • Total: 513
The Redrocket, my 1978 Pinto project.
Started by 78pinto, March 07, 2004, 08:24:51 PM
Quote from: 78pinto on May 01, 2005, 01:02:12 PM
Ok, i have the block cleaned, clearanced for the stroker crank and rods. The pistons have been hung on the rods, (spiral locks are a pain in the butt) and the rings have been filed and fitted. The crank has been set in the block and bolted down using ARP main bolts. today i'll be putting the pistons in and buttonning up the short block. I'll post some pictures later.
hehehe, yep.those spiral locks will tear you up ( even better when removing them............... >:( >:( >:( :'( :'( )
That looks REALLY nice Jeff. I like the material you used, it looks like it belongs in there. It'll look ESPECIALLY nice with the F.I. motor. Tres Hi Tech. That'll keep the Red Rocket cool too. 8)
Here is the finished product (other than tie strapping the looms back up under the fenders)
its a ruff spot to get at with the fenders on....i was going to tig it, but the metal on the firewall is up against the insulation by the wiper motor and i didn't want to burn it to the ground.......yet! I'll use a blending disk to make it look pretty.
That'll hold it together Jeff. I see someone there welds like I do!.... keep adding weld 'till it looks solid!
framerail mount, most of the innerfender opening will be filled with perferated sheet metal hiding the bars in behind it. This will make the engine compartment look more enclosed.
here are my front end bars....to keep it from twisting
too much work and money to convert to 5.4 so i'm sticking with the 408. I'll post pictures as i build the engine and tackle the front twist issue with some tubing. I'm also adding an airbag to the right rear spring on the car to keep the beast from squating during lauches at the dragstrip... it should improve my 60ft times. I think i'm going to also trade out my 2500 stall for a 3200 for a better lauch.
vonkysmeed
Nice work, that looks great.  I thought I was crazy for putting a 351 in a pinto, that thing with a blower must be insane
73 Pinto Runabout
351w from 74 galaxie
Heads from 69 Mercury Cougar
6 point cage
Cool. Are you going to shiney up the engine compartment?
Youre Pinto keeps getting more bad butt . I cant wait to see the track pics and times.
bricker4864
I think that the 5.4 looks pretty damn sweet. I've lined up against lightnings at the street legals. I beat them off the line (4.62 rearend, 3.99 first, 9" stickies; I beat a lot of people off the line), but they run me down with 13.0s. True there is no replacement for displacement, but big inches on the street has it's own set of problems.
I say 5.4 becasue i've always wanted to put a modular v-8 in mine. I'd go with the 5.4
1971 Pinto
pinto_351
go with the 5.4.   get thumbs up for cool factor and the rediculous power that can be twisted from the motor and still be driveable.  I test drove a lightning and they run hard.  I can only imagine one in a pinto.  Go fo it.
My buddy Frank really wants my 408 stroker.....so much that he wants to trade for a brand new 2003 5.4 lightning motor complete with supercharger..... i'm considering this option, but it is going to stick way up through the hood, even more than the 351w does. I can still use my C4/C5 with a trans adapter. What do you'all think, supercharged 5.4 or 408 stroker (both would be fuel injected of course) Here is a picture of a 5.4 through the hood of a Mustang II
the balancing is completed, the machine shop polished the crank and resized the rods (they were both brand new! you'd think that Eagle would be good about the QC they do on their parts?!) I'll start the assembly process so i can see where the bottom of the cylinder skirts need to be notched for clearance of the rod bolts.
CHEAPRACER
Oh it's GONNA twist, it already did seeing as it left on the rt rear tire the way it did. In the gallery is a friend of mine's car. (in racers under Pete's Pinto) He's got a built 351 on nitrous in it. (a SOLID 10sec car) When he launches the passenger window frame separates from the body a good 2". He just cut holes for his headers to pass thru.
yea i thought of that.....but if i do twist it, it will give me a reason to build a tube chassis ;D  Here is what it looked like when i bought it. :-\
Yes Jeff, it looks wide open, but is there enough structure there to keep the chassis from twisting? I'd try to find a way to tie the firewall to the rad support. The 408 may be a bit too much for just the "frame rails" to hold up to. Welding in an angle iron brace from the top of the firewall to the rail just where it meets the rad support would not only return strength, but give you more area to attach your expanded metal "fenderwells" If you used aluminum angle you could polish it 'till it's SHINEY  ;D
for the inner fenders, i think i'm going to use 1/4 inch expanded steel sheet to fill the void, and that will let the hot underhood air escape and yet fill in the shape of the engine compartment so it doesn't look so wide open.
here is the completed wiring, the voltage regulator will be mounted up under the fender out of view (have to make a bracket)
trust me.....ive handled them all at least once! I just love electrical. Rewiring is done, post a picture Monday.
HMMMM is it just me or does the harness run right thru where the block will sit?  ;D
Maybe you could cut each wire & add 6" to it?  ;D
then you'd have handled each & EVERY wire at least one. I know how much you LOVE electrical Jeff  :P
