Alloy Harmonic Balancer
Date: 07/10/2020 12:17 pm
Date: 01/24/2017 12:36 pm
Clutch pedal needed
Date: 01/11/2024 06:31 am
Date: 11/04/2018 02:34 am
Date: 01/18/2017 05:35 pm
75 wagon need parts
Date: 05/28/2020 05:19 pm
Date: 01/28/2019 05:15 pm
1979 Pinto Sedan Delivery
Date: 06/15/2019 03:30 pm
79 Wagon with many extras
Date: 07/08/2020 04:18 pm
  • Online today: 535
  • Guests: 518
  • Total: 518
Blue 72
Started by Reeves1, April 15, 2012, 11:45:09 AM
Built the rear car brackets. Used the drilled & tapped to 7/16" lower bumper bracket hole as one attachment point. 1/4" plate used. (likely over kill)
Under the car, mounting point(s) are the rear of the leaf spring mounting point.
I had to laminate two together to clear the back metal that is the back panel (don't know what it's called).
So, three 7/16" gr 8 bolts & the most forward long one is 3/8" bolt. Total 4 bolts , each side.
After that I welded the 2" x 2" tubing on the spinner. I still have to make & weld on gussets from the point I welded onto the mount brackets , back 3/4 the way to the spinner.
Got called back to work & couldn't finish it.
Only tool I'm missing is a plasma cutter.
Been using zip blades to cut 1/4" plate.
Takes time & blades.......good thing is I not often have to cut thick metal.
Spent yesterday drilling out the back bottom bumper bracket bolts. Tap over size to 7/16 NC.
Also removed the diff / springs.
Will start on the rear brackets today.
mightyss1
wow, nice work...nice garage and tools as well.....!!!!! ;)
Front "spinner" done / mounted.
Rear is assembled. Need to build mounting brackets now.
As mentioned, fire wall lip & sides done. I have not ground the welds yet - putting the rotisserie together  ;D
Work on the box will have to wait till I have the turner done !
My 73's cowl was definitely much worse & I saved it but only because the rest of the car around it was in good shape. Plus I'm making it into a driver for my stepson rather than a show car so perfection is not critical on that car.
Looking forward to seeing this. 8) 8)
;D
Lots of work yesterday.
The fire wall lip & sides are welded in.
Had to take it off the jack stands & move it over tight to one side - making room to get the white car out & load onto the trailer this AM.
If I have time this aft I'll do some grinding (sanding disk on grinder) & take pictures.
After that I have to sand blast the box (goes under cowl) & repair some rust out areas.
At the start of this I was spooked, big time, about opening this can of worms.
Once started (the longest step) it isn't so bad.
Cannot help but wonder how many cars in even better shape, ended up in scrap yards.
Hope this topic helps yet another car to be saved......
Glad you are posting your progress and photos , mostly in the cowl area , which a lot of pintos have a problem there, now people can see what in it and know what to look for to stop the damage and rusting out , which also later leads to water getting under the carpet rust out the floor pans , most end up scrapping the car because of it, good job , hope your knees get well from working on the floor , or praying too much  :o
Drivers side behind the wheel seam done.
Will post pictures later.
Next up will be the fire wall lip. I have it marked out for cutting on the new metal.
It is up on 4 jack stands. Front suspension is off. Due to the Header building for the B2P is going forward, I have to put the suspension back on, lower it & roll it out of the way to load the white car up for transport to the welders place.
While the white car is gone , I'll get this one on the rotisserie. Need the room to set it up.
Next few days will be busy !
Yes, it is (shakes head at self  :o;D
Had a look at the 10 lb (?) roll of mig wire..... gonna need more - soon ! LOL !
I did use it on other projects though.
Not sure how much I'll get done the next couple days. Right knee swollen up & hurting.
Kneeling on concrete ?
Man that's a lot of welding. I'm getting lazy in my old age LOL.
I know I said yesterday for the right side to be done......other stuff to do & I wanted to head scratch some more.
Cut just under 1 1/2" out.
Cut a new piece out of .060 metal. 1.5" - wanted a little more there for the spray skirt attachment.
All welded in. Need to do some grinding / sander disk & re-blast & prime (remember, all primer will be gone when the car goes for the full blasting / epoxy primer).
Welded both sides.
Note the door post weld. All seams on this car will be welded, both sides where I can.
There WILL be no LEAKS on / in this car !
79prostreet
I do believe that most (not all) of the younger generation have what i call the ''McDonald's syndrome'' need it right now!!  A lot of us had to wait for what we wanted, and so when we work on our cars we understand things take awhile. I can't tell you how many people could not believe I spent 4 1/2 years building my Hot-Rod,didn't seem that odd to me. As for myself I enjoy pushing out from the dock and then figuring out what I'm going to use for paddles.Rememb er if it was easy everyone would be doing it!! From all that I've seen of Reeves work he works on the slow and steady plan,and I look forward to the finished product.
79prostreet
Welded up an angle iron cross brace....just to be sure nothing moves when I cut the right side wheel well seam out. Which should be done today.
Attack the left side & fire wall lip tomorrow.
With the .125 plate welded in the floors & rockers, nothing should move.
Maybe so but there has to be talent there too, I been fabbing stuff all my life too but when it comes to body work, that's a big fat 0 for me, LOL.. ;D ;D
Wouldn't call it so much "talent", as cheap & bullheaded  ;D
However, I've done lots of inventing & fab work all my life. Grew up with my Dad's heavy const. co.
Worked for lots of others that had me inventing & building stuff.
Even though I've never done this type of work before, I do not fear it. Mostly.
The part / area I'm unsure I can deal with is in front of the rear wheels / rear door post bottom. Looks complicated.
Will know more after sub frames are in & the inner wheel wells removed.
Quote from: dianne on October 17, 2015, 07:42:48 AM
I look at Reeves car and I say to myself what a wonderful car. It's going to be awesome when he finishes it with the love his is showing it.
He also has the "talent", that's what makes it..
dianne
I know, I used to like it before, just not as interested as I was. But now I'm doing more and more bodywork on the cars coming into the lot :(
Vehicles:
- 1976 Mustang II mini-stock
- 1978 Mustang King Cobra II
- 1979 Ford Pinto Runabout
- 1986 Chevy K5 Blazer
- 1997 Suzuki Marauder
Quote from: dianne on October 17, 2015, 06:57:25 AM
You can, you just don't like bodywork ;)
Nope, been down that road before if I do body work it comes out worse than it was before I started, just ain't me. Missed out on quite a few cool cars/trucks because of rust. :( >:(
dianne
Quote from: 74 PintoWagon on October 15, 2015, 07:18:24 AM
Looks good, wish I could deal with rust. ::)
You can, you just don't like bodywork ;) I had to lose a tech (well let him go because he was soooooo slow and made too many mistakes). We're sitting around for lunch and the new guy says he wants to learn ahahahaha everyone laughed and now he's gonna be grinding some rust and banging out dents ahahahaha
Vehicles:
Mig gas down to 500 lbs. Get new spare bottle so no stopping mid way on stuff. Check
Shop fridge full of beer. Check.
Pick up a small sheet of 18 ga (.046 ish) metal for replacing seams. Check.
Read on a Mustang restoration site, that to remove the sprayed on tar stuff under fender wells (etc) is cheaply removed with the go joe type non grit hand cleaner.
Apply a heavy coating. Power wash off the next day. Supposed to work good.
So I picked up 4 lb 5 oz jug of the stuff.
Pink. Must have been made for wenches ?  ;D
76hotrodpinto
I love it! I'm very interested in your projects here. I like it when people stop talking about what they want to do, and post pics of what they've done. Just shut up and grind!
Box removed & the areas I'll be cutting and welding sand blasted.
The lip / seam across the front & going back on each side about a foot will be cut out & replaced.
The seams behind the front wheels, going down to the rockers will be cut out & replaced.
Weird hole in the heater snorkel. It was under a gob of seam sealer. May be perf under it - will know after sand blasting. I have it removed now as well.
Perf through the left vent hole.
Cowl off. Glad I am doing this : more rust than I thought. All fixable though.
76hotrodpinto
Quote from: Reeves1 on October 13, 2015, 08:12:22 AM
Wish more people used this site , over FB.
On FB a "post" quickly is gone. Info all mixed up, all questions / answers in one place.
I couldn't agree more. I refuse to be a part of that mess.
Cowl & box removed in a couple hours.
Need to pick up thinner metal today. Stuff I have right now is .060 (or was it .055).
Need to pick more gas up.
From what I can see, it's not that bad. Perf in some seams & one spot in the heater snorkel (or whatever it's called). Weird spot for it to rust......under a thick gob of seam sealer.
Pictures later..
More time off.....started yesterday. Means drilling out what feels like a million spot welds.  :o
I have the inner fender supports off. By days end (today) I'll have the windshield cowl off & the box under it.
You know the seam that goes down from the box, behind the front tires ? Connects to the front / top of the rocker.
Don't know it's name.....but I have to cut out the drivers side to about 1/2 way down. Right side all the way to the rocker. Already have the plan in my head on how to replace.
Pictures - later.
