Date: 01/23/2023 02:22 pm
Date: 08/24/2018 02:50 pm
1976 Ford Pinto Pony
Date: 09/06/2018 05:40 pm
Hoard of Pinto parts
Date: 12/17/2016 04:14 pm
Date: 02/25/2017 08:45 pm
Wheel cap
Date: 04/25/2022 11:21 pm
78 windshield trim
Date: 02/01/2020 08:46 am
1980 Pinto Wagon
Date: 02/29/2020 07:01 pm
78 pinto wagon
Date: 06/04/2020 12:42 pm
  • Online today: 529
  • Guests: 307
  • Total: 307
Blue 72
Started by Reeves1, April 15, 2012, 11:45:09 AM
Had to replace the dash on my 79 a few years ago because the owner before me made a mess trying to install a few more gauges , drilled out the rivets and got some steel pop rivets and put them in a small vise and use a small file to put the rosette look, buffed them with a wire wheel and pop them in, them I painted the whole dash to look new and installed it , looked factory
You have been busy.  The 72 front suspension arms should be the same for both disc and drum brakes.  Your DMV may not be picky about the type of rivet for the VIN tag, suggest calling them.  A friend had his dash replaced but the repair shop forgot to transfer the VIN tag.  My friend made a plastic Dymo label VIN and it was accepted.
Edit: For the rivets try a image search on "ford vin tag rivets" using Google or Bing.  Click on image like your rivet and then click on "visit page" or "view page".  They can be expensive and out of country sourced.  Based on the lack of stores selling them, I am wondering if there is a law discouraging it.  Changed description to "rosette rivets" and found the link below.
http://parts.smartcarguide.com/rivet
All shocks gone.
Loosened all ball joints, pulling coil springs today.
Pull the rack.
Rad support corner braces have been removed - will be making my own to replace (or maybe pulling the ones off of Ugly Yellow).
Front left of inner fender needs about 2" of rusted out metal replace.
Right side is good. Sand blast & new corner support.
Cut the battery tray area out. Have to pick some new metal up to weld in.
Box under windshield cowl is good. Couple small surface rust areas are fixable without removing the cowl.
Will likely cut the firewall / trans tunnel today.
One small area of the right floor pan, about where the arch of a persons right foot would rest, will be cut out today. Maybe 8" x 8".
Will measure the swing arms (drum brakes on the front) and compare to the ones on Ugly (disk brakes).
If the same : good. If not, no big deal: use the ones off of Ugly.
I have a real nice set of disk spindles ready to go.
Dash. Here is a problem. Windshield seal was badly cracked up & leaking for years. Rusty.
Along the inside bottom if a support, spot welded in. Rust behind & under it.
The dash from Ugly is in real good shape.
Wanted to just swap & swap the VIN back to stay with the car.
Made calls (lots) and found the place that can help with this.
I'll be calling to find out costs......no rush. Be a while before needed.
Special rivets - sort of hex headed.
I have a new rotisserie this car will be going on, in time. Will save me tons of time / work when the final sand blasting & sub frames are installed etc.
dianne
Vehicles:
- 1976 Mustang II mini-stock
- 1978 Mustang King Cobra II
- 1979 Ford Pinto Runabout
- 1986 Chevy K5 Blazer
- 1997 Suzuki Marauder
dianne
Quote from: Reeves1 on July 27, 2015, 06:17:41 AM
Over the last few days I've stripped almost everything off the car.
Moved Ugly Yellow out to the pole barn & tarp it up well. Due to my age (& money) , being a hatch back, I'll never get it going.
Blue is in the shop , next to the B2 car. Like trunk cars !
Trunk lid is good to go. Just a couple small surface rust areas to fix.
Hood will need to be split, blasted & epoxy primer. Put back together with some wet primer in the seams.
Ugly yellow????   :(
Well I love that blue on. Trunk model too! Sweet!
Vehicles:
Two intakes I bought: http://smg.photobucket.com/user/DerrickJB/library/Blue%2072/C90X%209424%20B?sort=3&page=1
Left click the first picture. It will come up bigger. Then use the next button (right side center of picture ?) to see the rest big.
Went through parts I have & put into bins for safe keeping.
I have most of the (new) suspension parts now.
I have a good start on the engine parts I'll need.
I have a set of 1969 closed chamber heads that will be sent out soon for (heavy) port work & big valves.
Have not decided on a solid roller cam of HYD yet.....
SFI cert on my bell for the B2 is now out dated......(I hate engine builders !), so likely use it here ? Have to see if it will work with the T-5 I have.
More parts slowly being collected.
Picked up a set of glass fenders.
NOS bumpers.
NOS grill with signal lenses.
4 like new windshields.
In for a penny , in for a pound... started collecting stuff for it.
Picked up a couple other small items as well.
The tray thingy for under the dash / on trans hump & a "sport" (?) mirror for the right side.
The trick is to pick the right numbers, wife says she "always" picks the "right" numbers but they always refuse to pull the "right" numbers.. ;D ;D
Hey, I promise I will build Dwayne, Art, and Reeves1 a garage if I win the lottery.
Now, all I need is for someone to start buying lottery tickets for me.
Quote from: Reeves1 on August 17, 2014, 09:42:14 AM
Now to win the lottery so I can build yet another shop / storage barn  ;D
Now THAT'S a plan if ever I heard one!!!
Dwayne ;D
Had some "extra" time this morning.
Pulled the fenders etc except for the hood.
Wanted to see all areas better , to get a better idea on any bad areas.
Good news, the windshield cowl will not have to be removed !
Looks 97.2 % good under it.....one day I'll have a better look with my remote view camera.
Battery tray area is the worst. Hole I can easily put my fist through.
No big deal : I can fix that.
Lots of surface rust though. It will require a 100 % sand blast to clean it up.
Not sure yet if I'll use Por15 after , or a good epoxy primer.
I think even the fenders can be repaired.
Left one has a hole at the bottom and lots of surface rust areas.
Right is just surface rust issues.
Front bottom valance (?) is bent up. No big deal : gets replaced with an air dam like the white car.
The next one up (forget what it's called) is OK , except for some surface rust areas.
Splash shields are good.
Will need all foldover nuts & bolts.
Quote from: Reeves1 on August 11, 2014, 07:05:38 PM
Worked......I went back 3 times ! LOL !
I love redheads. I had no choice but to look  ::)
Quote from: russosborne on August 11, 2014, 12:00:31 AM
I went thru all the pictures too.
Maybe this is a trick to get us all looking at the pictures? ;D
Could very well be, LOL.. ;D ;D
Quote from: Pinto5.0 on August 10, 2014, 10:08:09 AM
Ditto! I went back & looked again incase I missed something myself  :o
Ditto here too.. :-\
Quote from: Reeves1 on August 10, 2014, 07:23:32 AM
Huh ?
I don't see what you are seeing.
Quote from: chrisf1219 on August 09, 2014, 01:51:29 PM
hi I checked out your car on photobucket and I  say good luck on your project. I don't have any energy for that much work.that said if I was looking at the redheaded woman in the red leather outfit I'm afraid I still wont get anything done expect maybe the girl!!! ;D chris
Huh ?
chrisf1219
Quote from: Reeves1 on August 09, 2014, 07:27:41 AM
It's going to get crowded in my shop....
Isn't that the way it's supposed to be, been that way for me as long as I can remember and still is, lol... ;D ;D ;D
Decided to completely strip this car , so I can really look it over in detail.
Next couple days will be spent doing this & trying to find the room to store all the parts !
Hate to take the head liner out, because it looks in perfect shape. But I know mice can get into them & want it 100% clean above it.
Will need to find a new windshield...... good luck to me on that ! LOL !
Looked at my two with disk brakes, and the drums ones.
That backing plate attachment area is different.
In time I'll find new spindles...no rush on that.
Quote from: Reeves1 on August 06, 2014, 03:22:37 AMQuestion.....a re drum brake spindles the same as disk ones ?
Everything I've read says the spindle is the same as far as using the same bearings as a disc. The difference is how the backing plate attaches compared to the caliper bracket. I know the Wilwood kit has holes in it's caliper bracket for bolting it to the drum spindle.
Don't scare me ! LOL !
Question.....are drum brake spindles the same as disk ones ?
Quote from: Pinto5.0 on August 05, 2014, 06:41:54 PM
Oh the times I've been brought to my knees after uttering those words LOL
I think we've all been there at one time, LOL..
Quote from: Reeves1 on August 05, 2014, 05:10:29 PMI can do this !  ;D
I crawled around under the car a couple weeks ago. Looks better than expected.
A few areas I had first thought was too far gone are not.
I can do this !  ;D
