Date: 08/13/2017 02:01 pm
SOME PARTS FOR SALE
Date: 01/11/2017 10:45 am
Date: 10/04/2019 08:43 pm
McLeod Clutch
Date: 04/12/2017 12:08 pm
71-73 Hood
Date: 12/07/2018 06:22 pm
Anyone scrapping a 1980
Date: 03/13/2020 08:46 pm
1971 Pinto Parting out
Date: 07/06/2018 01:11 pm
Deluxe Steering Wheel
Date: 10/16/2017 08:13 am
74 pinto
Date: 09/11/2016 06:32 pm
  • Online today: 548
  • Guests: 289
  • Total: 289
Whats under your hood?
Started by pintowagon77, February 05, 2010, 10:53:55 PM
NoForKin
how about a 302 dart block 4.125 bore 8.2 in deck height
13.5 to 1 comp
  world alllumium heads
  tunnel ram with 2- 650 double pumper barry grant  carbs
  780 lift cam.  ect.ect.
   9.89 @ 135.60 mph qtr mile
   6.27@110.50 1/8 mile
Starliner
73 Pinto 1600 4 speed - 42 miles per gallon
Original engine never rebuilt.
21% overdrive by using tall 15 inch tires, electric fan, electronic ignition with recurve, re-jeted carb (actually richer), cleaned up exhaust manifold passages, Mobil-1 & platinum plugs.
70 Pinto 2300 automatic (wifeys car)  Terrible mileage & power   :lol:
I need to pull the motor this summer and fix all the oil leaks.   (namely rear main seal)
1973 Pinto 1600 - Sold!
1979 Pinto 2300 - Sold!
cromcru
my 78 station is stock. 2.8 v6,c3 auto with 8 inch rearend 3.40:1 ratio. my 74 pinto station wagon is a stock 2.3 liter with c3 auto with 6.75 rearend 3.40:1 ratio. making changes to it.full electric choke,serpentine belt system, rerouted heater hoses,4 wheel disk brakes.4 speed trans, larger radiator.upgraded suspension.. hoping to add a 75 sedan into 2011.one just has to wait and see
Just added New edlebrock 61699 heads (direct bolt on cleveland aluminum heads for a 302 windsor, Boss baby!) New manifold, cam etc.  She right now is a american racing headers getting a custom set made.  Had to refab the shaker for the fourth time tog et it to fit the latest rebirth.  Should be running around 400 hp when done, not bad for a street driver.
302 out of a mustangII , Here is the before pic from a few montsh ago.
What's under my hood..... Spiders and spider webs lol.... as for the engine it's the stock 2.3 4 cylinder, recently rebuilt.
marksm
Quote from: Pinto Pro on February 10, 2010, 12:32:15 AM
It wont be under the hood, but rather, behind the drivers seat!!
this is a Caddy 500 cu. in. with a TH425 transaxle that will be installed in the rear of this Pinto Wagon.
I had that idea too. Too much modification for my skills. Good luck with it, I look forward to seeing the results.
1972 Pinto Wagon with Cruisin panels on it
1973 Ranchero Squire
2006 MX5 Sport
2007 Buell XB9S
Nwstal
80 currently stock 2.3 pace setter header egr. Block off c3 trans 13" stock wheels tiny tires... Parts aquired so far:  Eaton M90, 9in rear, FMIC, Megasquirt ecu, 24lb injectors, f250 throttle body big block dual bore type...
Hmm OK,
Former IMSA RS Balanced blueprinted 2.0L , doweled crank , Esslinger Cam & Crank pulleys, 10:1 TRW flat top, Norris 4.50 lift 288 duration 108 degree cam. Weber 40 DCOE x 2 and Hooker Super Comp 4into 1 header. 4 Core radiator built from Pinto stock model. Mallory Unilite Distributor and Coil.
  Clutch/ flywheel in transition to Tilton. 4 Speed Ford Hummer box close first- second ratio.
  8 " Traction Lok equipped rear with 3:40 gears.
Front coils Mustang V8, rear leafs Chrysler. Competition M2 Front&Rear Sway bars
Panasport 13X7 all corners with racing slicks of various brands
No glass in doors, Lightened doors . No heater or ducting.
About 1900 lbs with Glass hatch & Windshield
Pintosopher... A Cone Killer and Twisty bits Horseman
78txpony
Stock 78 2.3L, 153K+ miles, never rebuilt.
Original clutch (adjusted once).  :o
Original tranny, all the way down to the oil.  ::)
Original 6.5" diff (oil and cover gasket replaced at 100K miles).
Just how long will this thing run???  I promised to keep this car until it falls apart or I cannot keep up with the repairs.  For over 20 years I've been waiting.........
-Rob Young
1997 H-D Sportster
1978 Pinto Sedan (base, one step up from the Pony)
Stock 2.3, head has never been off
Stock Holley 5200 carb with electric choke
Stock 4 speed, clutch and 6.5 rear
14" American Racing Outlaw II (I think) rims
GM delco am/fm/8 track (well, I guess that doesn't affect how it runs, but it's fun!)
It's just a driver.
Quote from: pintowagon77 on February 12, 2010, 09:29:39 PM
Would love to see a go at 1/4 mile with turbo toy and smallfryefarm. Maybe 1/8 mile
Its always fun, not sure what my times are going to be, im very impressed with the little car, its far the fastet combo ive put together yet, but man let me tell you, Turbo toys car 6.61 103 mph in the 1/8 mile man that is freaking flying!!!!! i mean that is going to put alot of big boys on the trailer.
71hotrodpinto
Quote from: Turbo Toy on February 13, 2010, 07:10:28 AM
71hotrodpinto-----I have to admit that the thought of a turbo V8 has crossed my mind many times and there is no doubt that it would kick my 2.3's butt. However, there is nothing quite like the look on the face of a guy when he realizes he has just had his butt handed to him by a 4 cylinder Pinto. :surprised:
Hehehe, youd hand me my butt also! (Id be lucky to pull down 13s with my combo as is). LOL! Just funnin wit ya. That is an awesome running machine!
However when i win the lotto, im gettin me a World Engine crate 460 all almunium. Hey its only $16,000
then id keep up with ya!!
Cant help it. Im a V8 Man. I tried the 4 banger thing once with the orginal engine. Now that i got 8, everythings great! LOL!
B303,1.7 Rockers,beehives
'68 port/polish heads
Coated Must II headers
Edelbrock Airgap
Holley570,Msd dist,CraneHI6
Mil
Since everyone's going bigger, I'll be different with the SMALLEST engine in a pinto...1965 1500cc Kent Pre-cross flow engine from a Cortina that I'm using as a temp slave engine to sort everything out before the Lotus 1600cc twincam goes in. It takes a real man to admit you have the smallest one... :hypno: :lol:
Turbo Toy
I'm good for 6.61 at 103 in the eigth mile. Haven't had a chance to stretch it out in the quarter since we don't have any in my area. This little car is a BUNCH of fun on the street and still gets 17 MPG with the C4. I was getting 23 with the T5, but couldn't keep a clutch in it. I just picked up a 53 Henry J and I'm thinking about putting a 2.3T in it just for sh!ts and grins. In reality, it will most likely get a 331 inch Boss 302 with mechanical injection and a Doug Nash 5 speed. It's all about having fun.
an all aluminum, OHC, 210ci, in-line 5 cyl
oh, wait, it's not a Pinto!
71hotrodpinto
Quote from: Turbo Toy on February 10, 2010, 07:39:07 AM
Move along folks, nothing to see here.
V8 slow it down huh?
Hmmm but, what about a Turbo V8?? Hmmm Hmmmm???
However i suppose theres only so much 2 tires can take!! LOL!
Edelbrock Airgap
Mil
pintowagon77
Contact any time for info or parts.
Quote from: 71pintoracer on February 09, 2010, 07:14:50 PM
Mine's pretty much stock... ::)
Hmmm thats funny Jimmy.
Mine has a griffen alum rad with dual electric fans
fresh 302 forged pistons thumper cam, Victor Jr alum heads hooker headers 780 holley carb
MSD dist, MSD ignition with soft touch and two step.
5spd trans with center force dual friction clutch and billit flywheel.
alum driveshaft, 8" rear with 462 gears and ladder bar suspension with coil over rear shocks.
20 gal aluminum fuel cell in the trunk with the battery  front disc brakes, drum rear.
Drag lite wheels 15 by 7 on the front with 15 by 10 on the back
front tires 205/60/15 rear 26/12.50/15
and al dressed up in 71 pinto red, with new interior.
But other than this its all stock.
Turbo Toy
Mine is still under construction but this is where it is at and I will include what is getting done this year.
Car: 75 runabout
Radiator: Stock w/ electric fan on 185 on 165 off relay
Motor: '85 2.3 t-bird turbo long block with clean up porting and a roller cam,  adjustable pully
Intake: Offy dual port that has been modified.  :look:
Carb: throttle body EFI
Exhaust: Ranger header to a 2 1/2 collector and 2 1/2 exhaust back to a turbo muffler.  Actually it is mostly at 2" at the bends not mandrel bends
Clutch: nope all gone
Trans: C3 with quarterstick shifter
Axle/diff: Mustang II 8" 4:10 gears with posi
Shocks: new
2" dropped front spindles.
Subframe conectors along with a 6 point roll bar w/ swing out door bars
Wheels: Centerlines satin finish
Tires: Big and littles.  no sense listing sizes as I am sure it is going to change but they are 15s all around.
78 Sedan - Stock motor other than the .024 overbore during the rebuild, 92 Mustang roller camshaft, EGR valve removed, K&N air filter, catalytic converter has been hollowed out and a Mustang II clutch cable w/adjuster tube now in use (the Pinto style cables kept tearing through the firewall).
73 Wagon - Stock 2.0 motor. Not just stock, but all original parts to! All I have changed are electrical components, U-joints, belts and it got a new muffler and flange gasket yesterday! :)
Pinto Pro
jugalo777
1978 hatch / calypso coral orange
sbf. 8.2 deck 323 cid. /  afr 205s head / solid roller .760+ lift
super vic.intake. 1000 cfm carb
griffin rad / csr remote water pump
hooker super comp headers 3 inch exh.
c4 trans / 6200 stall conv.
stock suspension / slapper bars / 8.50 chassis cert
8 inch 5.43 gear
155/80-15 fronts / 275/60-15 d/r
weld drag lites
what was i thinkin !! :lost:
mrpinto73
73 trunk model 2.0 nice cam carb has been jeted its in paint shop now i posted pics  weld wheels back is 15 by 10 front is 15 by 3 and a half have all new rubbers for doors trunk hood all new seat headliner carpet dashcover waitin too put back together
Buford & Teresa Jaco Registered Ride #253
Just like Bluepinto's cars, my 1972 sedan is pretty much stock.  1600 cc/4 spd combo.  Still riding on stock 13 inch whitewalls with dog dish/beauty rings.  76000 allegedly actual miles (considering the way it runs, I'm a believer).
