Date: 03/17/2019 10:15 pm
Date: 02/25/2017 08:45 pm
Date: 08/09/2018 11:09 am
Date: 01/24/2021 07:54 pm
Date: 02/21/2022 11:11 pm
2.8 Engine mount brackets
Date: 12/28/2016 11:42 am
79 Wagon with many extras
Date: 07/08/2020 04:18 pm
Beautiful 1980 Pinto
Date: 04/13/2020 11:53 am
FLOOR PANS
Date: 06/12/2020 07:24 pm
  • Online today: 484
  • Guests: 511
  • Total: 511
Whats under your hood?
Started by pintowagon77, February 05, 2010, 10:53:55 PM
 ;D ;D ;D
Quote from: entropy on February 06, 2010, 03:39:15 AM
Car: '72 Runabout
Radiator: Whopping huge custom aluminum with a Porsche electric fan
Motor: 1968 289 with ported and polished 5.0 heads and a lumpy roller cam
Intake: Edelbrock 7121
Carb: Holley 650 doublepumper w/ no choke
Exhaust: Hooker headers with x pipe into Flowmaster 40's
Clutch: Yup...got one, thanks
Trans: T-5
Axle/diff: Ford 8 inch with 4.11 posi
Shocks: Four of 'em
8 point rollcage
Wheels: Centerline AutoDrags 15x7 (I also have a set of 15x4 fronts when I want 'em)
Tires:  Inadequate...  ( front are some generic 225/50 15s and rears are Mickey Thompson Drag Radials in 235/60 15)
entropy
Car: '72 Runabout
Motor: 1969 302 with ported and polished 5.0 heads and a lumpy roller cam
Carb: Holley 650 double pumper w/ no choke, K&N X-Flow aircleaner
Trans: T-5
Shocks: Four of 'em.  Pretty sure KYB made those.
10 point roll cage
Wheels: Centerline AutoDrags 15x7 (I also have a set of 15x4 pizza cutter fronts when I want 'em)
Department of Overkill:  NOS Cheater nitrous plate system.  Currently jetted for 70hp, but I have jets all the way to 250
1972 Hoonabout
SBF swap
-308 cid
-CNC ported Brodix heads
8" rear 4.11 posi
G-Force 5 Speed
10 point rollcage
Car: '73 wagon
Radiator: Later model Pinto stock 20" w/ electric fan
Motor: '88 2.3 Turbo Coupe with roller cam
Intake: Stock (turbo/injection)
Carb: Stock injectors and F350 fuel pump
Exhaust: Stock Turbo Coupe - extension after muffler out rear of car
Clutch: Stock Turbo Coupe
Trans: T-5 world class
Axle/diff: 8", 3:00
Shocks: Unknown gas
Wheels: Depends - currently Mustang II 13," Optional 5 spoke 15" aluminum
Tires: Currently 175-70-13's    Future 205-60-13" OR 195-60-15"
Lots of fabrication for a rather clean install.
1975 Mercury bobcat wagon:
Tires rear are 245/60/r14 i think
Front are 195/70/r13
Engine is as of now a stock 2.8l with 425k on it.
Transplant motor is a S/C 3.8 out of a 1996 Thunderbird Just need to get a trans for it
Mine's boring!  My '73 has stock 2.0 and 4-speed manual transmission. I have gone through three differential pans!  :( and the girl has astroturf over her faded carpet! My '74 is pretty much all original with 2.3 and 3-speed (I think C4) transmission. She does sport a new timing belt, water pump, plugs, plug wires,... ;D Both have 13 inch tires and stock hubcaps ('73 deluxe, '74 dog-dish and beauty rings).
pintowagon77
Wondering what people run, from raidiator to tires. Looking to find what's an advantage and whats problematic. This is a very broad topic but may be interesting.  Guess I'll start with my daily driver:
Car: '77 wagon
Radiator: Stock w/ electric fan on 185 on 175 off relay
Motor: '80 2.3 with roller cam, esslinger adjustable pully
Intake: Sheffield D42E9425A with port and polish and
Carb: Weber dgv 32/36 5a
Exhaust: Hooker p/n 6703, with exhaust holes on block pluged, 1 5/8 the rest
Clutch: Centerforce 8.5 dual friction
Axle/diff: 8.8 w/ 3.89 gears
Shocks: Koni 550lb?
FlamingRiver rack and pinion
Subframe conectors to keep it tight
Wheels: Summit Star series 15x4 1.75 b/s front- 15x8 4.25 b/s rear
Tires: Goodyear 155 80  front Falken 215 60 rear
and a leaky valve cover gasket :(
Very low geared but snappy.
Contact any time for info or parts.
