Date: 08/02/2019 04:18 pm
77 Wagon rear hatch
Date: 12/04/2019 05:57 am
1975 Ford Pinto
Date: 01/13/2020 11:02 am
Date: 10/25/2019 04:05 pm
Pinto Wheel Well Trim
Date: 03/29/2017 11:35 am
Date: 08/17/2022 06:27 pm
Built 2.0
Date: 10/07/2018 05:27 pm
Date: 04/10/2017 07:30 pm
Date: 05/28/2017 03:20 pm
  • Online today: 500
  • Guests: 394
  • Total: 394
carbbed turbo
Started by 80bobcat, November 16, 2004, 04:37:40 AM
80bobcat
Hi all.. I`m in the middle of a turbo swap and finally after a long long hiatus I`m back on track... I just got the engine to turn over and sure enough it started ( I finally found help).. but everything was kinda jerry rigged ..so now I got to make it look good. .. I know I`ve not been online much.. but I remember that we had pics posted of finished underhood work.. is there a chance I could get some links to them as to give me some ideas on where to mount sensors etc etc... As noted earlier I`m way out of practice on site and having a dickens of a time searching.. I still have a long way to go but FINALLY !!
And to top it all off the guy who came and wired it up is a friend of Map351 who sold me a front valance..that I now can see getting put on........ what a small world we live in.
TIA ........... everyone!
Look Officer..it`s a Pinto would YOU stop short?
80bobcat
The hoods not on.. but there is no way its gonna close the way it is...I`m waiting to get a small scoop for it
80bobcat
 ???.... here`s the hold up....I don`t know how to read  wiring diagrams...
80bobcat
80bobcat
the turbo needed attention(rebuild)
80bobcat
Yea, I think the 77 has the same, works fine.
Mount the pump as low as you can too, they don't like to lift.
Get those fi clamps too.
Thanks tony.
80bobcat
Thanks ........I almost did..thought it would cut down switching of sizes...oh and for those who don`t know...the return line on an `80 is 1/4"....lol...I`m off for more FI hose
Make sure you mount the fuel pump close to the gas tank and not at the engine compartment.
Quote from: 77turbopinto on August 04, 2005, 07:41:54 PM
This is how I did it:
BTW: Tony, I tried to call you again and left a message. Let me know if I should try again. Thanks.
Hey Bill,
Yes, Please try again.
I have a NEW cell number.1-618-339-5047 From Pintony
80bobcat
thanks Pintony.. but thats not the problem...the pump and filter have 3/8 fittings on them and i`m trying to hook up to a 5/16 system...and the fuel rail is 3/8 ..so it seems like I`m going from 1 size hose then back again..just to change back again...so as to use whats there...just thought that was a lot of change ups...hopeing for an easier cleaner way... ???
thanks Bill..got your post as I was typing this one...I guess I am on the right track then....
Vito...
Hello 80Bobcat,
Your 5/16 line should provide enough fuel for a 200+ Hp Pinto engine.
Over 300 HP may require a 3/8 line.
80bobcat
hi all...ok now for more Q`s...fuel pump and filter is 3/8...but 5/16 is coming out of the tank so I`m gonna ?? ( thinking out loud) put an adapter nipple just past the tank run h.p. 3/8 hose to the filter then 3/8 to the pump..mounting it near the front of the car..then to the fuel rail....then do the same to the return line...I gotta stock up on hose clamps or run a lot of rubber hose? any advice,hints,tips would be welcome............thanks
Glad you got it out. I would never re-use one, so I don't mind how I did it.
80bobcat
thanks Pintony...I got it out ..and no it wasn`t pretty till my neighbour came over and seen what I was up to and brought his puller. He`s the type who has everything ..knows how to use them and if you can catch him doesn`t mind loaning them out. Thanks Bill and yes i was on my way to destroying it before the puller showed.
Hello Bobcat80,
IF you had an extra input shaft you could hydraulic the old needle bearing out by packing the bearing hole with axel grease and driving the inputshaft in with a dead blow hammer.
Viola; the bearing will pop right out!
I almost did that myself!!! (removing the roller one is not fun, unless you destroy it)  I did install the oil pan and then had to remove it again to change the dipstick tube/plug (before install).
80bobcat
 ;D..boy do I got egg on my face.......turns out everytime I orientated it to the tranny I would turn it around before I got to the engine...then wonder why it wouldn`t line up...but its not all bad I did find out there is a bearing in the end of the crank that has to come out before I put it together...see 2 steps back and 1 forward... ;D ;D
80bobcat
Hi all...not quite back to work on the progect ..but I did get a rare weekend off..and since the tranny came back I thought I`d bolt it up to the engine..now here`s the problem I encountered..the adapter starter plate from the Bobcat won`t line up with the crank on the engine ( Merkur)..what gives? and how do I get past this? only 1 of the 6 bolts wont line up so I`m thinking of drilling that hole a little larger ...thanks
80bobcat
Hi all...just a quik note to let you all know..everything has come to a halt..and if you haven`t noticed its been awhile since I did any work..I`m going to need time to gather some money and especially time..that has been in very short supply lately and i don`t see anything letting up soon.....so everyone stay cool (hard to stay motivated in this heat) I do keep comming to this site..I'll report in when work resumes on the project.
80bobcat
thanks guys..all good info and tips..I`ve hit another snag on the project..while working on the stuck bolt on the left lower ctrl arm I must of nicked the boot on the steering rod cause I had a puddle of fluid on th floor and I think there isn`t to be fluid there..so off the steering rack comes..get that rebuilt too...need a 24mm and all my stuff ends at 22mm so its off to the hardware store....I wonder if shiney tools count?...lmao...2 steps forward 1 step back..sooner or later though......lol   ;D
billnall
Hi 80bobcat,
You can find the switch on any fuel injected ford at the salvage yard, probably in the trunk.
Just wire it inline in the hot wire to the pump.
Ford Parts Man
I used the harness from an 86 t/c, and the stock pump wires worked all the way back to the side panel (h/b car), and I just lengthend the power ones down to the pump from there(think I put the details on page 3). Used the stock one with the harness for it if you can. On the t/c I had, it was in the trunk, on the right side, under and near the rear deck speaker. Small black box, 1.5"sq. or so, with a white button on the top(been a while, hope this is right). As far as the blower motor, I think i posted that an underdash aasy. for an a/c car, delete the evap., can be used, and it lets you have heat and defog. I just pulled on out of a jy car in MA last weekend. If you do that, get ALL the parts and ducts, as the are ALL different. It is a royal PITA to work with, and it took about 2 hours to remove. I purchased one and installed it, but that was the first time I removed  one. As far as that header, there is not much room for the vam as it is, and moving the turbo forward will not help.
80bobcat
I just read `78`s post on the inertia switch..good point..anyone know if the `87 merkur`s can be wired in? where would I look for it? Or am I looking at aftermarket?         thanks
CHEAPRACER
That's all I used and it works fine. Make sure you use EFI high pressure line & clamps  if your using EFI.
80bobcat
Anybody know if I can use the feed and return line that are on the car now for the fuel system? They look to be in good condition ..then I would only have to find a place to mount the pump.......thanks
80bobcat
this one stuck.. :'(
80bobcat
 ;D...I got one in
80bobcat
Thanks `78...I opted to take the hvac out...and it was a lot easier than I thought..looked like it was out once before...strut bushing came and the right side is back together..but the new coil has a definant curve to it..but everything bolted back up ok..now to find the time for the other side..the tranny sure is taking long..I guess my next step would be to start looking for a fuel pump....I got a lot of work ahead of me but things are starting to come together
