Date: 01/28/2019 05:15 pm
Date: 03/16/2017 10:00 pm
1980 Pinto taillights
Date: 12/26/2017 03:48 pm
2.8 radiator
Date: 10/25/2019 04:10 pm
Date: 06/19/2018 03:58 pm
Date: 07/04/2017 03:26 pm
Date: 03/18/2020 01:30 am
Rally spoiler wanted
Date: 05/04/2017 01:32 pm
Date: 01/12/2019 10:19 am
  • Online today: 362
  • Guests: 325
  • Total: 325
carbbed turbo
Started by 80bobcat, November 16, 2004, 04:37:40 AM
80bobcat
Thanks for the vote of confidence.......lol.cause other than oil and plug changes..I aint done nothin that comes close to this... :o.......but i`ll keep reading
Look Officer..it`s a Pinto would YOU stop short?
Now thats  the ticket... ;D Yeap, that will be your best bet. Good luck.
80bobcat
thanks all for the input...but....I found an 86 turbo coupe....ad says it needs a head..going there sat. he wants $500. ...I`ll offer $300 and go up from there..and best of all there is plenty of info on doing this swap...
The other possible issue with the Capri set up is that the turbo is on the intake side of the car. I'm not sure if the steering would get in the way. The exhaust comes off the manifold, then around the back of the bellhousing and up into the turbo. Then the turbo exhaust needs to go out the back from the same side. Its a lot of plumbing on the intake side.
You would need to upgrade your pistons, rods and rod bolts to be able to pour some boost to it. Your best bet would be to get a motor from a T-bird turbo coupe or other turbo charged car and start with that. Cast pistons will not last long with boost.
80bobcat
Hi all...while out wandering the local junk yard looking for a roller cam..i came across a Capri turbo and noticed a carb on it.............sounds to me like an easy upgrade...(for my limited mechanical skills)..anyone try this?  is it as easy as I`m thinking it is?(no wiring..I hope)...I`m going back Sat. to get a better look at it..thanks for any thoughts or ideas.........
