Date: 02/28/2024 02:07 pm
Date: 06/28/2019 09:14 pm
Front grill for '72
Date: 03/02/2022 12:09 pm
72 Runabout Sprint Edition
Date: 04/25/2018 02:51 pm
Date: 08/09/2018 11:09 am
Date: 06/30/2018 09:48 am
1973 Interior parts wanted
Date: 01/02/2017 11:02 pm
1980 Pinto for sale
Date: 11/24/2016 06:32 pm
78-80 Windshield
Date: 10/29/2021 03:11 pm
  • Online today: 600
  • Guests: 392
  • Total: 392
carbbed turbo
Started by 80bobcat, November 16, 2004, 04:37:40 AM
there is a fellow at www.turboford.org who sells very nice custom made turbo headers for the pinto that will allow it to be moved further forward if your interested.
80bobcat
Well after banging the metal in the fender area to make room for the turbo..exaust,etc.. the engine sat back even further and now I know why the heater motor is removed entirely..it`s just in the way...so while I`m waiting for the strut bushings (1st 2 were sent back..only sent the male part (Moog)) I opted for TRW..but I`m told they own Moog..anyways hoping to get the set this time..I`m not looking forward to doing this part..I just don`t bend like I used to....lmao   ;D
Look Officer..it`s a Pinto would YOU stop short?
Looks like your heater will blow REALLY hot air! Most turbo conversions do away with the heater all together. When you get this working I'd love to see it. I'm betting a heat shield is in order to keep the blower motor from literally burning up!
80bobcat
oops this is the too close but gonna try it
80bobcat
80bobcat
trial fit
80bobcat
whats going there...in da place
80bobcat
the place it`s going
80bobcat
the doner
80bobcat
Hey all....anybody put tubular control arms on?..mine are supposed to be direct replacements but I`m having trouble. the  strut bar that attaches to the lower control arm the nuts wont fit to secure it.. the arm itself gets in the way of threading them on..all I can think of doing is popping the studs out putting in longer ones then using a spacer..then I looked at the old one and see a bracket that circles the ball joint and reinforces this section..where the strut bar attaches..I`m thinking I have to do both..reinforce this section and use longer studs with spacers. anybody do this? any hints?  am I on the right path?.......thanks
80bobcat
Thanks `77 I`ll try that.....the stud I`m referring to is on the exaust turn down where the rest of the exaust connects to...it`s sitting on the inside fender right now but the scratches will leave me a nice mark as to where to drill...for now though I gotta try and get the new spring in and then paint the engine bay..mayby play with the camera some...lol
I just set my camera at the low quality setting and it works fine for posting. What stud?
80bobcat
Thanks for the hints Pintony....Well I got the engine in..it`s not sitting proper yet though..needs the hole for the exaust stud..and the exaust turn down just clears the hvac motor..so mayby I can leave it in ,..I figure after i drill a hole for the stud I may get more clearance there...the heat will cook the hvac motor but either way I wont have one..
On another post I read that i have to resize my pics to get them posted here..I`ve searched everywhere..pulled every pull down I could find on any and every screen and still can`t find how to resize my pics...any hints? It`s probably real simple but i`m so puter illiterate that I wonder how i get back here sometimes..
Hey 80 bobcat,
When doing the cherry picker thing.
Sometimes it helps to deflate the front tires.
Gives a bit more clearance.
Also do not use the hook at the end of the crain.
Take the hook off and put the chain attached to the engine through the bolt
at the end of the arm.
80bobcat
Hey all....thanks for asking... the tranny was sent out.. shift kit and some extra clutch plates going in ..so in the mean time I figured the tubulars can go in ..but the spring refuses to fit..as soon as it get close to position the whole car lifts off the jack stand..I probably need the weight of the engine..so with that said I think I`m ready to trial fit the motor and get the spring in also..I only did the r/side so it looks bad with the sag..started to clean and degrease the engine bay..but this stuff (release all cleaner) is taking most of the rustproofing off .one more cleaning and that`ll be enough..the hvac motor still needs to come out but I`m gonna try to sit the motor down on the mounts...I know I`m not posting many Q`s yet.. but I read the posts of those like you who blazed the trail before me and find most of the info I need..on another note..Tues. I pick the tranny up ..put it into the wheelbarrow ..place it in the pick-up drive to my buddies place..put it on his bench..get back home..bend over to tie my shoe and bam!! throw my back out...go figure..oh and i got me a digital camera took some pics but can`t post them..best i can figure is that the files are too large..I know it can be done but how?.....later
80bobcat
 ;D  finally got some time...engine and tranny is out..oh and bringing the cherry picker to the car...bad idea..got everything half way out and reached the limit on how high the picker would go ..it sunk in so we couldn`t pull ..so the tranny came off in a very akward position..best to send it out for a look see..now I gotta see what i`ll need.. get it off cleaned and put on the turbo..some suspension work then I`ll see about fitting the turbo...slow going and going slow..I`ll get there just don`t know when...lol   ;D
80bobcat
 ;D  I think Darwin`s theory is working in reverse for me...went to remove the turn down on the exhaust and 4 of the 5 bolts broke ..no he-man stuff they just gave way..better to find out now rather than after..idle hands.. now I gotta beg borrow or steal some tools..1st weekend I`m off.. the motor in the Bobcat is coming out then I`ll get it into the garage
Darwin has a theory about this thread.
Hey, I thought this thread was about "carbbed turbos................ ;D Jeff go to chat
pic.  Not as bad as it looks, really, very easy. Note my kick down, hooks to the stock arm on the tranny.
pic Turbo and heat sheild. The sheild is about .5" away from the firewall.
80bobcat
Thanks Bill....well I`m just sitting here collecting parts etc....gonna go with tubular arms..they arrived Tues.  ..I put the pully`s on just to see and noticed right off that they didn`t line up so I mixed and matched them.. looks like it`ll work Alt. bracket is coming from the Bobcat.. had to cut & grind a little off a corner to get it clear of the intake. Since I can`t move the car I`m bringing the hoist to it... It`ll be easier to pull outof the field after I get the engine out.The Merkur is also just sitting out there..a friend of my son wants it..I told him to wait..make sure i got all I need first.I gots a few Q`s to ask but they`ll wait till I get to that point where I need to know.lol..cause when I look at the whole project..nope..1 step at a time....lol...I started to look at the center mount header to clear the heater motor but the exaust turn down look like it`ll interfere with it..with our damp humid summers here even a summer only car needs air flow to the windshield. This weekend i`ll start taking the rest of the parts off..just hope it`s not windy..
Good luck with the project. There is not much to hook up with the harness. Do you still have the donor cars? I did mine less than a year ago, I will give you pointers if I can, just ask.
80bobcat
Just a quik update..engine is almost done..but I parked the Bobcat in the field.. no hood..it snowed.. now won`t start..turns over real nice ..just won`t catch..not that it matters it`s still socked in with drifts..warm days just makes it soggy out there and the car..she`s a sinking...what can go wrong will!!!!
80bobcat
hi all..quite the absence..been busy though.. just not on the bobcat...lol..seemed like everytime the car went out it got dinged or banged or something so my priority was to get the car off the road..so after finding a car then getting the saftey etc...and so on...well anyways now that the cold has settled in probably for the remainder of the winter I can now turn my attention back on the swap..so with a rebuild kit ordered I still have to replace the head..and now with the bobcat parked I can start getting it ready for the transplant.
SVOwagon
I'll take some of the wiring and of the vacuum lines. I know that most of my vacuum lines are no longer the way they were when the motor was in the thunderbird. Mostly got rid of lines that are not needed. I'm also going to take pics of my trans mount and crossmember. When putting in a T5, these parts have to be modified. I'm thinking that all these new pics will be added to my site and I'll let you all know when that is done.
SVOwagon
80 2.3 EFI Turbo Pinto Squire Wagon
91 Mustang LX 5.0 (93 Cobra clone project)
82 Mustang GT (built 460)
89 Mustang LX coupe (built 302)
83 Ranger
http://www.cardomain.com/ride/2167062
80bobcat
SVO..thanks and I`m with Tigger.. more pics would be great!!.. and because i broke most of the vacumn conectors  I`ll be looking at those...I`m getting the engine back tomorrow...he says i got a cracked head(wife tells me that all the time  ;D) but the rest checks out good..wants $1200. to replace repair and assemble .a little steep so i`ll get it back and see what i can do..our plant is shut down the 1st week of the new year so i`ll have time to look around for some deals...so with that i`ll wish everyone Happy Holidays
