Date: 03/14/2020 01:52 pm
pintos for sale
Date: 12/11/2018 04:29 pm
1977 Pinto Cruizin Wagon
Date: 08/07/2023 02:52 pm
Date: 07/03/2025 04:35 pm
74 4 spd and rear axle
Date: 09/26/2018 03:51 pm
Looking for front seats
Date: 08/10/2021 09:54 pm
Date: 07/10/2016 10:17 am
Wheel cap
Date: 04/25/2022 11:21 pm
Date: 08/24/2018 02:50 pm
  • Online today: 600
  • Guests: 260
  • Total: 260
Restoring my 1971 Ford Pinto Trunk Model
Started by larjohnson, January 13, 2009, 12:59:10 PM
Well found out today the new alternator I had installed was bad.  The switch out is being made today, so hopefully my battery will stay charged up.  They haven't traced down for sure yet, on how to hook the ignition back up, so I can take the push button start off the dash.  It'll be fixed though, they've assured me of that.  The leak....well it's coming from the cowl, which I knew....they can't fix it, but I'll look into it.  May as well get my hands dirty.  Anyway, hope it'll be back on the road soon, I'm going to start driving it for fun, it's warming up around here.
Dave1987... yes, the upholstery shop told me I may need to take the windshield and back window out to replace the headliner.  I told them I wanted new seals put in anyway, if that was the case.  I plan on taking it this month for the headliner repair, hopefully, they'll take care of the problem.  I'm just having the shop check on the leak too, only because Reed had fixed the cowl when he owned it, and knew the leak was still there.  I'm just ensuring there's no further leaking from the cowl area, while they have it.  If it's not the cowl, definitely the windshield seal is probably the problem.  Hopefully, when they reseal it after the headliner replacement, this will take care of the problem.
Tiger....I was wondering about that push button start, that's why I want to replace it.  Plus I just don't like the looks of it on the dash.  I hope they can hook the original ignition up, if so, the button comes off, the hole gets repaired, and the dash gets a new paint job.
Hey guys, thank you so much for the information.  I really enjoy this site, and I've been getting a lot of great tips on my Pinto repair.  You all are awesome.  Larry :police:
You may want to check that push button start.  There may be something with the wiring that is causing the drain on your battery.
If you want the headliner done as original as possible, they will need to remove the windshield to do so. The headliner tucks between the windshield gasket and the roof along the top, I believe it does this around the rear window and quarter windows as well, but i can't say for sure.
Dave1987:
Hey thanks for the tips, I'll let my mechanic know.  I'm having a new headliner put in, so if it's the windshield gasket, I'll have them replace it then.  They think they may have to take the windshield out to replace the headliner, but they wouldn't know for sure until they seen it.  Thanks again.
Larry :police:
For the charging, make sure the stator wire is connected and tight, might as well check continuity for that wire while there. Without that wire it won't charge correctly. While in the charging system, replace the voltage regulator, these are external on Pintos and mounted on the driver's side fender. It's a small square box with four tab connections on it which connect to rectangular plastic connector.
As for the leak, it could be a crack in the windshield gasket in the along the bottom of the windshield. If not, then it's probably your heater core.
Just a few tips for your mechanic, if they haven't already check it (although they probably have)! :)
Sounds like you are getting things going well, hope to see her as a nice driver in the years to come!
Well!!! new alternator, new battery, but for some reason the 1971 Pinto just won't hold a charge :(.  So.... I took it to my brothers tonight, for them to look at.  I didn't realize this, but when I jumped the 71, I turned on the lights to make sure everything worked for the road trip to Muncie, In., and found the headlamps didn't come on :surprised:, so they're going to check those too.  Still have a small leak, coming in from under the dash, one small stream behind the gas pedal and one small stream by the passenger kick panel, so they thought they could fix that also ???.  And last but not least, I asked them to see what it'd cost to take the push button start off, and hook the ignition back up 8).  Hopefully, this all won't be too expensive.  Oh well, it's my baby, got to get her running and looking good.  Can't wait to get her up and running like new...... Larry :police:
Got home from work, nice warm day... so I worked on the Pinto.  I put the driver's and passenger door vinyl panels back on, and installed the window and open cranks, and the arm rest.  They look fantastic.  I took the Sanyo radio out, to prepare the car to accept the original Pinto radio, after I get the dash painted.  I sanded and primed the glove box, it's hinge, the ashtray, and the radio bezel.  Once the primer dried, I painted them black, and they look great.  All I have to do now is sand the dash, prep it for paint, and paint it.  Once I get that painted, I can install the radio, glove box door, ashtray.  The dash will look greeeeeaaaat!!!!!!  I am attaching some pictures of the doors and the before dash.  Hope you enjoy.  Larry :police:
Well.... I went to the junk yard tonight, and purchased some clips to put the inside door panels back on.  When I took the panels off, I didn't lose any clips, but there were about 6 missing.  Found 10 on a 1975 Pinto Stationwagon.  The guy sold them to me for $1.00.  Came home, put them on the door panels, and put some adhesive on each of them, to help hold them in place. I plan on putting the doors back together tomorrow.  I then decided to look at the heater and defroster, as they weren't hooked up.  The baffles seemed to be frozen, and wouldn't move, they were stuck.  I took the unit apart, cleaned some things up, put it back together, and got them unfrozen.  I think I figured out how to hook the cables up from the control switch on the dash to the baffles.  I'll hook them up, once I get the dash painted.  Hopefully, this weekend. I'm happy to have the 1972 to look at, so I better understand what I'm doing.  While thinking about the heater and defroster, I thought it may be best for me to install new cables, rather than the original ones I have.  Just because I really don't want to work on this again, once I get it back together.  I thought new cables would help me in that department.  I was able to find "new" cables in Cincinnati, Ohio, so I'm having them shipped to me today.  Hopefully, I'll get them next week, get them installed, and have the heater up and running like new.    Larry :police:
Oldkayaker:  Hey!!!! thanks for the information on the Corvair club.  I'll forward it to my Buddy, he'll love it.  Thanks again.....Larry :police:
I am hesitant to mention that I have a 66 Corvair also, unique car.  I did FORDify it by putting a 289 in the back seat.  In case your friend was unaware, there is a great Corvair club "CORSA" at http://www.corvair.org/csaindex.php.  Since the Corvair is a decade older than the Pinto, the Corvair club has been around longer than FordPinto.com.
Your 71 is looking good.
Well I love the Corvieke (1966) Corvair too.  My Buddy took it home last night to work on it at his parents.  He drove it to work today, he's so proud of it, but why not, it's a great car.  Anyway, it's great we have friends to share these special times together.  Have a great day...Larry :police:
Wow, Larry!
You're making progress at a breakneck pace! ;D
My local car buddy is a Corvair nut with a twist of Citroen. It's cool to hang with him and work on things! ;D
You guys are inspiring me to do a lot of little things that need to be done.
I'm a Jones, you guys are supposed to be keeping up with me! ;D
Well it was warm when I got home after work, and I decided to sand the runs out of the interior doors I painted yesterday.  Got the runs sanded out, and went ahead and taped off everything and re-painted.  They look fantastic!!!! Runs all gone.... I'm getting really excited now.  I took the vinyl off the interior of the doors, which was difficult. Had a hard time getting the arm rests off.  Anyway, panels were removed, took them into the garage and dyed away.  They look brand spanking new...they are so awesome.  I then took the seat part of the back seat out and cleaned it, then decided what the hey..... may as well dye it too.  The back looked new, why not the seat.  Anyway, the dye job did really well, and now the back seat looks showroom.  I went to my local ford parts store (Paddocks in Knightstown, Indiana), a fantastic place, they have a great car show in the fall.  Got the rubber filler for the shifter notch, and put it in.  WOW!!!! WOW!!! WOW!!!!  This car is becoming more and more special to me, I love it!!!!  Well, I'll be taking her in a couple of weeks for the new headliner, once it's in, I'll finish putting the interior back together.  Will post pix when I can..... Larry :police:
Hey Larry!
Sounds like things are coming along nicely.  Isn't it great how much fun it is to work with a buddy?  My best friend is a co-worker too.  We've worked together, side by side, both at work and with our various automotive projects, for nearly thirty years now.  In our partnership, I'm the junior member... Charlie is twenty years older than me.  He'll be 72 in two weeks and still works full-time, cranks out beautifully built model cars at an astonishing rate, and always, always, always has a restoration project or two going on!  Recent past projects (the past 5 yrs. or so) have included a couple of Dodge trucks (his), a Ford truck (mine), a Cadillac Coupe Deville and a Continental Mark V (both mine), and a Thunderbird (his).  On the agenda next: my Pinto and a second T-Bird for him.  We've both sanded, straightened, painted, tuned, adjusted, sewn, etc. on each other's projects over the years.  Heck, we even finance each other's projects when money gets tight for one or the other of us!  Our wives think we're crazy, but at least we're staying out of trouble!  We tend to park them side by side and then work on them together - time goes by a lot faster that way, plus you always have a second set of hands available if you need them.
The weather isn't quite warm enough here yet... but soon!
Well... it looks like the weather will be beautiful today, so I'm going to work on painting the doors and dash (a little worried about it).  I wanted to get all this done, because I'm taking the car in a couple of weeks to get a new headliner installed.  I don't want to put the interior parts back in, with the exception of the driver's seat, until I get the headliner installed.  My buddy from work is coming over today to work on his 1966 Corvair. Yes... not as cool 8) as a Pinto, but he loves :-* both of mine too.  He wanted a Pinto, and had bought two, but before we could go after them, well.... things just happen (sold out from underneath us, no title, you name it).  He found this 1966 Corvair (we've dubbed the "CORVIEKE"), and we both love it.  He's half my age, (the same age as my youngest son), but we get along great.  He's like having a third son, I'm blessed :angel:.  Anyway, he's going to work on the Corvieke, and I'll work on the 1971.  Hopefully, we'll both make some headway today.  Larry :police:
My Buddy did come over, he got the Corvieke out, and began sanding on one of the quarter panels, and I began working on the  1971 Pinto.  I sanded the interior metal on the doors, cleaned them, then primed and painted them.  They look great, but for some reason the original Ford paint is really thin, got a couple of very small runs, I'm going to re-sand these areas, and repaint this week.  It'll look good as new.  The interior vinyl on the doors now look really bad.  Since I've dyed all the other vinyl in the car, I guess I'll have to do these too.  I had hoped maybe Meguiar's Vinyl Protectant would have taken care of them, and I wouldn't need to dye them.  But, they look really bad next to the new paint.  They're off the car, will be easy to dye.  I also finished painting the new tracks for the seats, they look good as new, and have been installed on the seats.  The seats are now complete, and ready for install once I'm ready to put them in.  The car is taking shape nicely.  My Buddy got hungry, and my daughter came home, so we went for Pizza to celebrate our day.  What a blessing :angel:, had a great time...... Larry :police:
Hey Larry!
Your trunk looks awesome! I can't wait to see pics of the interior. Let's see if I can help you with the picture dilemna. I just did this post last night, if you haven't had a chance to read it, it may help us see what you see! ;D
http://www.fordpinto.com/smf/index.php/topic,11843.msg76513.html#new
Chuck :afro:
Again, for some reason I can post only 2 pictures at a time, so here's my new tailpipe, it looks sweet!!!!!!! :lol: Larry :police:
Well great news :smile:!!!! I was able to paint the radiator last night, and the battery tray today, yoo hoo!!!!!  I also took all the vinyl pieces out of the car today, and dyed them with the black vinyl/carpet/upholstery dye.  All the vinyl looks fantastic.  I also cleaned the trunk area and painted it with the trunk paint you can buy at your local parts store.  The trunk looks new.  Last but not least I was able to purchase a chrome tailpipe extension, and added that today.  It gives the car a great new sporty  :fastcar: look.  I'm posting some pictures so you can see how great it looks.  I'm going to paint the dash and doors tomorrow, if the weather holds out.  Larry :police:
Well...the weather hung around 50 degrees today 8), but I couldn't wait, so I sanded and painted the radiator and surrounding area.  Yes... I know it was probably too cold :hypno:, but the paint seemed to be drying, I'm sure it will.  It looks incredible ;D.  I had earlier painted the fan shroud, so I bought the hardware today to reinstall it.  It'll go on tomorrow, once the paint on and around the radiator is dry.  I have cleaned up all the vinyl pieces, and they are out of the car.  Should dye them tomorrow also.  Anyway, progressing at a snails pace, but it's looking good :angel:.  Larry :police:
Great weather last night when I got home from work.  I sanded, primed, and painted the emergency brake handle, and the arms to the brake and gas pedals.  I went ahead and took the horn off along with the battery tie down, sanded, primed, and painted them also.  I'll not be able to hit the radiator until Thursday evening, but some of the small things are getting done.  From what I hear the weekend will be great, I'll probably get the dying and interior painting all done on Friday.  The Pinto is taking shape.
discolives78:  Yes, you're right, it's all about details.  I just love this car, and am enjoying this great weather to work on it.  I am blessed with a great upholstery shop.  They are not only friendly when I go in, but they also listen very closely to what I need, and they take care of it.  I think their prices are very reasonable, and the quality of their work is superior.  The rims do look nearly new, they sanded and painted up nicely.  I'm going to paint the inside of the trunk this weekend, that is if the weather stays nice.  I hope to go home tonight, and paint the brake and gas pedals, along with the emergency brake handle. If I have time, I want to paint the radiator tonight too, along with the battery tie down.   Hopefully I can start painting and dying the interior this weekend also.  We'll see.
Hey Larry!
Your back seat looks great! The upholstery shops here charge a bit more, so you got a pretty good bargain! That red paint sure took to shining, didn't it! The wheels and jack stuff look great too. It's all about tweaking the details, I've been doing that for almost 6 years now. Car looks great!
Okay...beautiful weather today, around 60 degrees, so I took advantage of the situation.  I sanded all the rims I just put on the 1971 Pinto, thanks to smallfryefarms, primed and then painted them (including the spare).  They look fantastic, as you can tell from the photo.  The rims were the original gray color, with not much rust, but a little.  I sanded the rust off, then put some good primer on them, and then painted them black, like I have on my 1972.  I also took the jack, jack handle, and other accessories out of the trunk, sanded, primed, and painted them, as you'll see in the next photo.  Anyway, didn't take a lot of time, but it needed to be done.  I would have gotten more completed, but my 5 year old Grandaughter, wanted to go to a birthday party, so I took her.  That's much better than working on my car.  Anyway, hope you enjoy the pictures.
Beegle55, if your carpet isn't torn, and is only faded or stained try this.  Go to your auto parts store, and look for something called Carpet/Fabric/Vinyl paint.  This is great stuff, I've used it a lot.  Anyway, it will dye your carpet back to it's original beauty.  It works great.  It should only take about 2 cans, and the cans run about $7.00 each.  Just take your front and rear seats out.  Mask off the rest of your interior to protect from overspray, and just go to town.  Your carpet will look fantastic.  This may even make the other imperfections in your interior less noticeable.  Good luck!!!!!!!! Larry :police:
I'm going to ask around and see what I can find out about having the front seats re-done. The worst of my interior is the front seats. Everything else is nice, rear seats mint, headliner perfect, and the carpet isn't really bad enough to replace so I'm holding on that. Its an old car and people still appreciate the beauty of it and are stunned and on first glance the minor flaws aren't really noticed  :lol:
Hey Beegle55, glad you are enjoying my posts.  Anyway, I know what interior you have, and you know, it's not as expensive as you think to make these repairs.  If it's just your center part of the seats (Indian print type fabric I believe you have), then they can replace only that fabric, for around here maybe $100.00 per seat or less.  I had my complete seat recovered for around $200.00 each, which included the fabric.  The back seat repair which I just had done was only around $5.00 for the Masonite board, and then $35.00 for the upholstery shop to finish.  My interior will look great.  Oh yeah.... I got a new dash cap, for I think around $75.00 which included shipping.  Carpet, well if you go with ebay $119.00 to $150.00 for just the passenger area of your Pinto.  Anyway, hey you're young yet, you have plenty of time, just remember your folks can get you a lot of this stuff for your special holidays, just ask Santa  :lol:  OH YEAH!!!!! I HAVE AN ELECTRIC BUFFER, MAKES WAXING SOOOOOO MUCH EASIER..... Larry :police:
How does your back feel after that??  :hypno: But the car looks great! The work was worth it. Where I live it really isn't worth it because I live out a dusty farm road and have a dirt/gravel driveway that instantly ruins any painstaking wash job you have.  :-\
