Date: 08/08/2018 12:26 pm
2 liter blocks and heads
Date: 03/28/2018 09:58 am
2.0 Cyl Head1973
Date: 11/29/2018 12:51 pm
need 1978 pinto guage cluster
Date: 03/07/2021 07:35 am
WTB Cruising Wagon
Date: 12/07/2016 05:35 pm
Date: 01/10/2022 03:41 pm
76 Pinto Wagon
Date: 07/08/2020 05:44 pm
Pinto brake booster needed
Date: 05/08/2021 09:00 am
Date: 11/14/2019 04:02 am
  • Online today: 139
  • Guests: 105
  • Total: 105
The Baby (aka the copper queen)
Started by blupinto, November 28, 2008, 09:41:14 PM
Quote from: dave1987 on February 23, 2009, 02:07:00 PM
Add the what? lol
when you tried demonstrating it changed your "and the" to a link. :P
EDIT: I found the button to do what you are talking about. Adding the [ U R L ] and the [ / U R L ] at the beginning and end of web addresses. All without spaces of coarse. :)
LOL, Yah, didn't even notice that! LOL I thought I checked everything before I actually posted!! Well, you fixed it for me and put what the "and the" was all about!! LOL
Sorry for the threadjack Becky!!!
Wha...? :read: ???  ??? :drunk: :sleep:
I'm obviously computer illiterate. and the ???
Anyway, Dave, are you talking acetone as in nail polish remover acetone or cp acetone?
Also, can I use a long-handled brush (wire) to scrub the stuff out? Because of my elbow injury I'm not supposed to grasp, push, pull, lift, blah blah blah with my left arm.
Money's really tight right now. I'm getting disability but the Governator has effectively cut my salary.
Add the what? lol
I wonder if your globules are water? I know water does bubble up at the bottom!
Kinda off topic, and forgive me if this makes anyone mad, but, did you all know if you add the and the   at the beginning and end of your links, they will become clickable??? I'm just saying this because it is a lot easier to click then to copy and paste!!!  ;D Ok, I know, I"m being lazy!!! ;D
See, like this!!!
http://www.sscenterprises.net/4images/details.php?image_id=89
It also opens the link in another tab, so you can just go back to the original topic easier, them being sent away from it!!!! ;D
When I did mine, I just removed the filler neck (which you will have to do anyway), stuck some vinyl tube in there, connected to a fluid pump (bought at auto parts store), and pumped it until it came out consistantly, then disconnected the pump and let the vacuum of the running fuel pull all the gas out.
Once the tank was empty, I dropped it with the support of a floor jack underneath. Once done, you can tip it over to get the remaining fuel out.
After it's empty, flip it over, and use a brass drift (no sparks) and hammer to turn the fuel sender locking ring, alternating tabs from one side to the other. Once the ring is loose, you should be able to just pull the sender out.
While you have the sender out, inspect the tank for rust, and check the screen at the end of the pickup. If it is still intact, you are good. If not, you can google to find ideas on how to build a screen for it. I think a couple members here have had to do that.
If you find rust in the tank, fill it with a few handfuls of loose gravel and pour a couple cups of gas in the tank, seal it up with duct tape and shake the hell out of it for about 15 minutes. That should loosen up a majority of the surface rust. Then pour some acetone into the tank to remove any film of gunk at the bottom of the tank, and let it sit for about an hour, should be long enough to penetrate anything nasty. Use either acetone or chem-dip parts cleaner for this.
If you decide to have the tank boiled out at a radiator shop, you will need to re-coat the inside of the tank so it does not rust again. I hear that por15 is a God for this!
EDIT: I forgot to include, that you might want to check your vent valve and grommet while the tank is out. It should be above where the filler neck goes in, with some hose coming off of it. I replaced my vent valve, grommet, and the hose on it while I had mine down, as it turned out that it was the source of my gas smell in the car after filling the tank full.
You can find the valve and grommet at sscenterprises.net. You will also need a new fuel sender o-ring. Here are links to the parts you will need.
http://www.sscenterprises.net/4images/details.php?image_id=90
http://www.sscenterprises.net/4images/details.php?image_id=85
Thank you Chuck and Dave for the tint info. Thank you srt for the humor! Kidney stones are no fun from what I gather but if these globules were kidney stones they would never hurt. They look like oil balls at the bottom of the cup with bits of sediment rolled in them.
         So do I need a special tool to remove the sending unit or can the right wrench do the job safely? Or (better still) Is there a way to drain the tank without siphoning or drilling a hole in the bottom?
The discolored fuel sounds like it's bad, or over diluted with additives. The gas from my 78's tank looked like that when I added fuel stabilizer to gas that had sat for five years.
If not that, then maybe srt is right... ;) :P
My 78 Sedan came with factory tint, although it doesn't even look like it has it on it. It has the tint strip across the top of the windshield, but the rest of the windows look clear. I do notice a slight color change when I have a window rolled down part way though, so I know it's there. That and the "build sheet" that I requested from Ford a few months ago states that it was on the car when sold.
Quote from: srt on February 23, 2009, 03:42:49 AM
"..... What does the cloudy globule pee-color mean?......"
:lol:it has kidney stones?
i'm sorry. i have had a recent bout with those and i couldn't resist.  maybe a little humor is the prescription that is needed to make the task go a bit smoother.
How rare is factory tinted windows, at least in '74 models?
The 'sun x' is the factory tint. on cars with optional 'tint' back in the day, it wasn't nearly as dark as the tint film applied today, it usually had more of a greenish glow to it. if you open the door with the window up, and look thru the glass and then at the sky around the glass, you should see a different color.
p.s. make sure your windows are clean before trying this.
Do I need a special tool for removing the sending unit from the gas tank?
I'm curious: In my 1974 Pinto brochure I see that tinted windows are recommended for cars with a/c. The car where this is said didn't look like it had tinted windows. I'm looking at my car now and it looks like her windows are dark. It's overcast outside. I went out and looked at the stamp on her pass. side quarter window and it says Carlite tempered sun-x. Is this factory tinted glass?
I would replace the fuel entirely after Cleaning it out.
Quote from: discolives78 on February 22, 2009, 08:28:52 AM
I mixed up the girls too! Clean out the tank and things should get back to normal (or at least further along). It should be one of the first steps considered when resurrecting an old car. I did it to my Pinto for the same reason, 4 fuel filters in two weeks.
p.s. will be under the hood today
rrrrr....rrrrr....rrrr......w...w..w.w.w.waaaaaAAAAAA.......WWWWaaaaAAAAAAA....POW....wwwaaaaaAHHHHH....POW....wwwaaaaaAAAAHHHHH....POW :mad:
Did you plant a bug on the Baby, Chuck? Because what you just described was the sound coming from the engine compartment. What you didn't include was my pleadings (c'mon Baby! Dammit! Just once Baby! C'mon! !*&$#^!)
    THe filter thing: What a few of you suggested was what was suggested by this cute guy who visits across the street and knows the trials and tribulations of Baby and he said he might be able to secure one. I don't know if it's that bulb thing but Boyfriend (I call him that secretly. He's GORGEOUS! lol.) said it comes apart, so that might be what he's talking about. Hell, I won't mind emptying it out now and then if it benefits the car. Dropping the tank is probably less scary than replacing the timing belt for me, but it's up there.
   Now for an update: In spite of the BRAND NEW THIS MORNING fuel filter installed the Baby will not start. The fuel pump works- believe me. After I collected another sample of her gas I forgot to put the tube back on the filter and when I pumped the accelerator the gas shot all the way to the valve cover.
  THe sample: I collected about an ounce of her fuel and it sat in a cup for maybe 15-20 minutes. When I looked at it again it was really cloudy and had these oily looking globules (is that a word!?) rolling around with the sediment. The gas was pee-colored when collected, and was cloudy-pee colored at this point. The tank had had Sta-Bil, lead additive and fuel booster from before I brought her home to a few weeks ago. What does the cloudy globule pee-color mean?
My 73 that is in my avitar has a tank with a bunch of crud to it. I filled it up before I found out how bad it was.  I had to rebuild my carb and replace the fuel pump even before I could move the car from where it was stored.  After rebuilding the carb and changing the pump, I installed two filters between the carb and pump.  Shortly after bringing the car home, the fuel pump died again.  I replaced it with a new one this time and installed a filter before the fuel pump.  This seemed to work well enough to run the tank down to empty.  Now I am waiting for some time to drop the tank and take a peek inside.  I have a perfect spare to swap in if I need to.
I would just hang in there and fix one problem at a time.  It may be frustrating at times but eventually you will end up having a car you can drive and trust.  I went thru the same issues with my crusing wagon.  It was supposed to be an easy fix but after I really got into it, it turned into more of a project that I anticipated.  I was on the verge of scrapping her because it needed so much work.  I stuck with it and am finally driving it.  All you need to do is get over the hump and you will end up enjoying the car.  Good luck
If they're all in a series, the first filter will be the one doing all the filtering and clogging up. The others will be pretty redundant and useless.
Quote from: dholvrsn on February 22, 2009, 12:40:43 PM
The first filter will just trap 99.9% of the crud while the rest in the series do mostly nothing.
Well, wouldn't that mean the carb would be getting nothing but clean gas? Or does that mean the first filter will catch all the crud and plug up, stopping gas flow??
Have you ever thought of doing something really old school, like put a sediment bulb in before the filter? Still prepare to empty that every few blocks until things clear up.
That's ok that you get us mixed up guy's1!! We're Pinto Sisters!!!  ;D LOL
Becky, I would try getting a longer gas line hose, and then putting several cheapy plastic filters in line with each other. Then once you start seeing clear filters, just go back to you normal gas line and filter. So let's say put maybe 2 or 3 filters in line. That way what doesn't get caught by one, it will most likely get caught by the other. Even if you had to tie the gas line up to something for now, it would probably be a cheaper fix, for now! Or, at least I would think you would be able to drive her a bit more with more filters in line!!
I was just talking to hubby about you having problems with your car, he say's to send up here!!!! I think that would cost more then you pulling the tank yourself though!  ;D
Hopefully the money situation will turn around soon.
oops, my bad!  ;) I tend to get you girls mixed up! Are you sure you're not twins?  :lol:
Sorry you took one for the team Kim!
   I made that comment because I'm afraid I'm becoming maudlin about this whole thing. Kim's too nice to say that, and even if she did I'd be LMAO. So sorry for any misunderstanding overall.
      Well, send your tank guy over! lol. I hope he takes smile payments 'cause the cash flow is all dried up! lol. (it should be col, or crying out loud, but what's the use!) My fear is if I do drop the tank I'll have to replace seals and stuff. I would like to replace the sending unit while it's down but no mon no fun.
       As for reining Baby in, it's not hard to rein a dead horse (or at least a comatose one!) lol.
Quote from: 71pintoracer on February 21, 2009, 09:29:36 PM
Thats just MEAN Kim!!!  :cheesy_n:
Becky, sounds like one of the pulleys hitting the timing belt cover, they tend to get bent pretty easy.
Say "I'm sorry" Kim or you're going to time out!  :lol:
Hey, I didn't say that, she said that to herself!!!! Me and Becky are Pinto buds, we only say that kind of stuff to each other in PM's!!!!!!!! LOL
I'm sad to here you are still having problems with your baby! Sure wish you were closer, I know a radiator guy that can clean out your tank!! Hopefully you can get it out and cleaned soon.
I have confidence that you will have the baby up and on it's hooves before to long!!!! Just keep on reining her in!!!  ;D
Quote from: blupinto on February 21, 2009, 07:33:46 PM
Do you want cheese with your whine Becky?  :lol:
Yeah, I though about just buying a gross of the things but if there's that much metal particles in the tank I'll run out of filters before I run out of gunk. It looks like I need to drop the tank and at least empty it of everything. At this point I can't trust the Baby driving down the street- much less to Orange County and back.  :'(
You should be happier. You know what the problem is and it's an easy repair.
Just keep a few filters on hand until the gunk clears out.
DGH
 :accident:
(this is my earlier euphoria coming to an unceremonious halt.)
My anticipation turned quickly to dismay when, upon turning Baby's key a disturbingly clattery sound erupted from her innards. It sounded like thin sheetmetal hitting more thin sheetmetal. I and a couple neighbors looked to no avail. Meanwhile the sound little by little faded away.
       On her very brief maiden voyage Baby wasn't accelerating as well as she should, but at least she didn't stall on the way up the hill- she faltered and stalled in front of my house. There's gas in the tank (treated with Sta-Bil). This was suspect because she felt like she was starving for gas. Perhaps she is. I changed that fuel filter a couple months ago and didn't get too far since. When I took the line that goes into the filter and what was caught in the collection cup? Surprise surprise... gas and sediment. Lots of sediment. I'm so bummed now.  :'( >:( :drunk:
For the ball joints, the clear sign to replace mine was the boots on them. Mine were torn open, shooting out all the grease I would fill them with onto the wheel well skirts, every time I hit a bump. No point in greasing ball joints if they are going to leak, right? If they arn't greased, they wear quicker, and ball joints are what hold your spindles to your control arms, and tires are mounted to your spindles....you get the point. :)
A good way to check for wear is to jack the front of your car up, then rock the tire in and out with hands on the top and bottom of it. If there is excessive movement, then they will need to be replaced.
If you have torn boots, your spindles will be COVERED in grease, like piled on. I scraped off grease piles 1/2" thick off the driver's side, and yesterday I scraped off grease piles an ENTIRE INCH THICK off the passenger side. I didn't realize the spindles were soo narrow, as the grease build up made them look a lot bigger!
Now my front suspension is nice and clean, and should make it easy for the alignment shop to work on! :D
I haven't had an alignment done on the car since the engine rebuild due to the ball joints. Les Schwab wouldn't give the car back unless the ball joints were replaced due to leaking grease boots.
Good luck on the maiden voyage, and I hope you don't have any unexpected events happen along the way!
I love your emoticons Kim! The cheerleader ones really reflect how I feel right now. I can't keep the smile off my face!
      The Baby's probably always going to be a work in progress. THis was a major hurdle (aside from engine rebuild, ball joints  ::) etc.) Tomorrow I want to explore why Baby's heater hoses are looped (bad heater core I'll bet). To have a car that won't die on me on a minor incline will be so good. Did I mention SHE SOUNDS LIKE A PINTO!?! LOL!
         I want to thank everyone who gave me hope and suggestions. The people who share my Pinto Passion are a great bunch! (not that non-Pinto people aren't) but you all are the best!  :-*
              :drunk: ;D :tgif:
