Date: 08/20/2017 01:34 pm
Date: 05/18/2020 10:22 pm
Date: 08/22/2018 09:23 am
2 liter blocks and heads
Date: 03/28/2018 09:58 am
Two 1978 Pinto Station Wagons
Date: 05/18/2025 03:10 pm
Wanted early pinto
Date: 10/03/2019 02:42 pm
Date: 10/24/2018 07:35 am
Date: 05/03/2024 05:37 am
Rally spoiler wanted
Date: 05/04/2017 01:32 pm
  • Online today: 153
  • Guests: 129
  • Total: 129
The Baby (aka the copper queen)
Started by blupinto, November 28, 2008, 09:41:14 PM
It's kinda like the water line from the ice maker to the wall, same concept. I thought you were going to try it without pulling the radiator? :lol:
Chuck   :afro:
Quote from: discolives78 on February 13, 2009, 07:11:08 PM
Hold the one closest to the radiator and turn the one furthest from the radiator counterclockwise. under the larger of the two is a flare fitting.
Sorry about the crude drawing, I'm a visual learner :)
LOL that is a great drawing!!!!! LOL
Try going to an autoparts store and getting some "Nut Cracker" or penatrating oil! It works alot better and actually works it's way into the threads!!!!
 >:( Grrrr. I'm now at a stalemate. The whole project seems to hang on those two cooling lines, both of which the nuts won't budge. I can't replace the timing belt or put in the new water pumpo because I can't get the fan out because the fan's bolts are too long because the radiator's close to the fan and I can't remove the radiator because those dumb nuts won'd budge!!! I soaked them in WD40 overnight andf spritzed them a couple times today and all I've managed to do was round out the short nut on one side.  >:(
That's a good question. Mine doesn't currently have a leak (knock on wood). I ran her a few days ago to charge her new battery before I started on this daunting journey and leak-wise she was good. My hope now is when I reassemble what I disassembled that the result is the same.  ;)
I wonder how much it costs to have the radiator pressure tested.
My dad and me had mine flushed, sealed and painted before i put my car back together again. I know mine had really trashed fins on it, but I don't recall any leaks. I think it was around $120 for the work done.
I didn't have a chance to work on her today but I did spray some lubricant on the nuts in question to soak overnight. Meanwhile I'll hope for a sunny day tomorrow. I don't have power steering in her but there really is a bunch of stuff. THe 2.0 had miles of room! The lower hose is on order so sometime tomorrow I'll have that, plus I purchased some radiator flush because the fluid that came out of mine had a distinctly brownish tint.
Quote from: dave1987 on February 12, 2009, 05:51:16 PM
I also have access to ratcheting wrenches, which helped immensely when getting to the belt cover bolts around the thermostat housing, and behind the crank pulley. They are made by GearWrench and available at Sears. So far they have proved to be a very worthy investment!
Oh yah, I love those wrenches!!! I have metric and american with the standard and stubby sizes!!!!! Don't leave home with out them!! Well, ok I do, but not when going to wrecking yards!!! LOL
Well worth the money!!!!
When I reset my timing belt early last year, I drained the radiator and removed the top hose. Then pulled the fan and pulley off, and then removed the timing belt covers. Once that was done, it was just a matter of loosening the idler pulley/tensioner and removing the belt. The reverse procedure to put it all back together.
Just went and looked at a 77 Pinto with a 2.3! I see what you mean by not much room!!!!!  :o  I would take out the radiator!!! LOL
I like to remove the radiator so it's easier to get the long bolts that hold the fan on out of the water pump. My car is a 2.3 4 speed, so I have no trans lines to contend with. My car also has no p/s and no a/c so my engine bay is fairly clear of clutter, however I am using a fan from an a/c car for better cooling here in the desert. If you can get to the necessary stuff to access the belt without removing the radiator, then by all means, skip this step. I just like to have a lot of elbow room.
So is it the longer nut that moves and the short one stationary? I've never had to deal with cooling lines before (except to mourn the breaking of the blue Pinto's line) so I'm really dumb about this.
        Well Kim, you should've heard the muttering going on yesterday as I was trying to figure out how to get the AC belt off. the AC belt, naturally, prevents the other belts from being removed. Mine is a 2.3. As I recall my '72 2.0 had WAY more working room (believe me- i resisted the radiator drop. I'm deathly afraid I'll screw something up! lol. ) and I don't remember her having a smog pump and I know she lacked an AC unit. That alone frees up some serious space. Also, that lower hose is crappy so I need to replace it before I go any real distance, much less to Knotts! I can't access that clamp at the engine block, so it has to be done. Plus, I want to replace the water pump.
Quote from: blupinto on February 12, 2009, 12:27:25 AM
I've taken the plunge: I've started Project Timing Belt. So far I was able to loosen the alternator and the smog pump (with a little help from the neighbor on the smog pump) and drained the radiator. I discovered the lower radiator hose looks a lot older than the upper one, so I'll be replacing that. What ground my progress to a halt was the transmission cooling lines. There are two nuts on each line (get your minds outta the gutter folks! lol!) and I want to say that I "hold" one in place while I loosen the other one. Well, it's not working, and I'm afraid to force it. Am I doing this right? I want to remove the radiator as Chuck suggested.
Get some pb blaster and squirt it in the back of the nut wnere the line goes in . Let it soak for a while then get emery cloth (fine sand paper)and sand the line  sort of polish it. Try  to losen the line again  working it  slowly  by loosen about half turn then tighen again loosen  ect... untill it moves freely.
Phil
I'm not seeing a reason to pull the radiator!  ???  I may be wrong on this, because I'm not a mechanic, but I would think to replace the belt all you would have to do is loosen the tenstioner (sp) and R&R the belt! Hubby just "re timed" my car and had to R&R the belt to do it, and he left the radiator in place!!  I have a 2.0 though so maybe mine is different, isn't yours a 2.3? (sorry I don't recall ) I have never seen a 2.3 in person so maybe the belt is different??
I'm glad you are working on the 'copper queen'!! Can't wait to hear you say that you are driving it!!  ;D
I had to sew my headliner back together too. It isn't beautiful, but it keeps it off my head and out of my face!
My back seat is torn in the same place yours is. Mine is too brittle to attempt any repairs on though. :(
I have good rear seat vinyl from the 77bobcat I parted out last summer, I may attempt panel replacement if Chuck would like to give me some guidance though. ;) :P
use a 1500w heat gun or a hair dryer on high to soften the vinyl and make it more pliable. on the back seat, take it out and flip it over, use an awl or small pick to remove the staples from the backside top edge so you can hold up the material and stitch from behind. on the headliner, use a curved needle. I had to stitch a few places on mine, I just used ordinary thread. Don't pull too hard on the material, remember that it's old!
While I'm here I want to ask a couple more questions:
   Is there a way a novice sewer like me can fix my back seat and headliner where the threads are actually coming apart? I have needles and thread (not upholstery thread) but do I need to soften the fabrics before I attempt this? I've kinda tried to pull the headliner pieces back together but I'm afraid I'll rip a hole in the fabric because it's so tight.
BTW, I have to have these stores order the belt 'cause they don't keep them in stock.
It is a good idea and a good time to replace the water pump. My water pump came from Napa the second year I had her, and has about 4 years and 12,000 miles under it's belt.
I had a dream. A friend of mine's dog was having puppies, and I was picking from the litter. I held a white puppy that glowed and that song was playing on the stereo when I woke up. Two weeks later, my friend told me his dog was pregnant, and asked if I knew anyone that wanted a puppy. The rest is history.
A good place to start with the timing belt is removing the grille, draining and removing the radiator, and removing the fan and fan belt.
Chuck :afro:
 ;DAs a matter of fact I saw the new pix of yours a few minutes ago. She's a dandy. Yours reminds me a little of the Pinto I Could've Got (if Mom hadn't vetoed it!) The one I could've had was a medium blue metallic with the whole glass hatch and automatic. The car lot only wanted $750 or something like that in 1989. Mom liked the Yugo there (gag!) but we settled for the '81 Capri. The one that burned up. I'll bet the '78 would still be around if Mom let me have it.
       Tell me about your boy named Sue.
       I was also advised that since I'm replacing the timing belt anyway I should also replace the water pump too.
That's cool info. I probably won't get to the belt till next saturday, I went all out at the u-pull-it. Check out my project thread and my new Pinto pics, and let me know how my baby looks.
Thanks!
Hey Chuck! (I always wanted to say that! lol)
       Kragen and Autozone carry the belt, and it's way cheaper than a T belt for the Rodeo! The belt for the Pinto is a little over $13. I would love for you to post pix. I've replaced a starter (on an '82 Capri), an alternator and power steering pump (on Capri again) plus light bulbs, oil and filter, and other misc. stuff. I even reconnected the speedometer in the '75 Maverick I had so briefly (I never got to see if I did it right). I've never replaced a timing belt- way too major for me. I think I'll do it by myself. Well, with your help!  ;)
I think the lowest ones were like 108-115 or something around there, might have been lower.
Do you remember what the low compression numbers were? The lowest measured on mine was 120. I understand I want at least 120. If I could find that thread on the 2.0 I'll compare notes. Thank you. :)
I know we had a member here with a 2.0 motor in an early Pinto which had issues on inclines. It was due to low compression in a couple cylinders. They did a valve adjustment and it brought compression back up to acceptable ranges, letting the car climb much better.
Thank you Kim! Tomorrow I'm pricing timing belts (the Rodeo needs hers replaced soon too). I just realized... I have a two-car western event! (get it? Rodeo and Pinto) ah well, you had to be there! LOL.
      AS for the car stall issue: does what my mechanic said make sense? Lacks power when strain is on engine because of timing issue and falters and dies?
That sucks about the timing belt, and I am sure hoping that the noise is nothing major. I hope you can get things figured out soon. I am still at a stand still on the Green Machine too. So don't feel bad. I can't get hubby to take her for a spin and I wont drive her the way she is!! So don't feel bad that you can't drive you baby!! I can't drive mine either! They are 2 Pintos in a pod!!!! LOL   ;D
Keep us updated on the prognosis of the engine noise!!
Kim's right... it's all good. Now if mine ran as well as Kim's... And thank you Chuck! That would be swell!
