McLeod Clutch
Date: 04/12/2017 12:08 pm
Date: 08/22/2018 09:23 am
$300 Pinto for sale
Date: 04/19/2017 10:24 am
Date: 07/17/2018 09:49 pm
Date: 09/12/2018 12:33 pm
77-78 front grill
Date: 04/07/2017 12:35 am
Date: 01/24/2017 12:36 pm
Rally spoiler wanted
Date: 05/04/2017 01:32 pm
Date: 08/20/2017 01:34 pm
  • Online today: 125
  • Guests: 130
  • Total: 130
The Baby (aka the copper queen)
Started by blupinto, November 28, 2008, 09:41:14 PM
Becky ,
Probably another Pinto.
The other day after running around town in Baby I noticed after I parked her she made boiling-water noises in the radiator area. Today I bought a thermostat and gasket and will be installing them tomorrow. Meanwhile things are starting to come together for the Fab Fords thing. I wonder what Miss Pintogirl has up her sleeve... ;)
I'm no mechanic, hubby is, but if your mechanic friend seems to think it will be ok, then I wouldn't see a problem driving it! He is there to hear the noise and if he thought it was something real bad, I'm sure he would advise against driving it! If you say the sound is going away, then I would be lead to believe that the Lucas stuff his working. I know when a 80's period VW Rabbit or Jetta sits for a while, when first started they will tap. They just need to be driven for a bit for things to clear up!!
After what I've already done for her I've convinced myself I can do this.  Thank you for the vote of confidence.
The problem now is, the Rodeo's down so Baby is the only transportation for now. What can happen if I run her before I get the work done?
It was my neighbor/mechanic who turned me on to Lucas oil stabilizer. He swears by it. He has a mobile mechanic business and he himself worked on cars since he was 14. That's not to say the Lucas oil is the answer, but that's why I tried it.
The tapping noise is almost not heard til I accelerate, which is a change from when it tapped all the time. A change for the better?
Becky,
I did some reading up on the Lucas Oil stabilizer. It's not likely to help much unless your lifters are worn out and bleeding pressure down to allow them to not hold adjustment. It's primarily for Engines with worn rings and valve guides that consume too much oil. Regarding the cam lobes look at the portion without the "Hump" and if you see chatter marks or scoring grooves ( Not smooth shiny metal) then it's too late to save the cam and followers. Then it's decision time after you look into the Lifters and oil supply at the head. If you have no scoring or chatter marks, then you still need to remove those lifters and verify oil pressure to them. If that's OK then you might get by with new lifters if the followers haven't beat up the Valves tips.
Jump In , it's all a learning curve, and you'll be able to help someone else down the road. ;)
Best wishes ..
(hands clamped on head) AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA!!!!!!!!!!!!! lol.
Ok time to consult Jerry and the books!
How long do I give the Lucas oil before I know it's not sticky lifters?
You Know,
You may be right about no Spray bar on the 2.3L. It's been awhile since I had one opened up. But the 2.3l Does have 4 cam towers , maybe the extra oiling comes from these. But if this motors knockin' your right, something ain't getting oil pressure.
Check out those lobes, followers and look for loose ones when the engine is at TDC for the Compression stroke of that cylinder.
If I'm not mistaken, isn't the spray bar only on the 2.0? I've never seen one on a 2.3. The early 2.3's did not have a groove in the center journal, that was another cause of cam failure. Way back then we used to machine a groove in the new cam. Finally Ford caught on and since then all new cams (even aftermarket) have the groove. Also, the 2.3 is hydralic so there is no adjustment. If it's tappin' something's wrong!  :(
Becky,
After removing the ( stock ,if you have it ) air filter  assy, label those plug wires with the cylinder # remove over to the left side (distributor) if you still have the timing belt cover, that's coming off too. There may be an EGR tube that interferes with the back of the cam cover, by the firewall cowl, it needs to move a bit. 8 bolts to remove.
If you see a lobe that is scored then it's time for a cam change with lifters and followers Plus a new spray bar. This can be done in the car, but the motor has to be lifted to allow clearance for the cam to come out over the radiator.
  It's also a good time to change those cam bearings too.
I've abbreviated some of the operation as it has a lot of steps.
:surprised: :look:**** The real important thing to do before you disassemble anything in the cam area , ( providing you don't see a scored or flattened lobe ) is to actually look at the spray bar while someone cranks the engine. There should be a spray from a hole over each lobe. If everything is getting oil then you have to identify how many lifters and followers have excessive clearance****.
It's possible to have multiple seized lifters and that translates into too much lash/ clearance at the follower where it touches the cam lobe. If that's the case, you would still need to remove the lifters and verify oil pressure in the bore where the lifters sit. This has to done without ANY followers installed to avoid engine damage while turning over the engine (**as a precaution with the timing belt off only*)
I'm assuming all the lifters are able to be removed with the cam in Place.
If you find plugged orifices in the lifter bores, it's a crapshoot that you can clear the plugged port. Removing the whole cylinder head with all of its procedures is the next phase.
And we stop here, You now have to decide , if it's plugged up, there no way of knowing how bad the oil supply issue is in the block and head.
Rebuild the Engine to assure that any future issues won't crop up. Or replace the engine with a rebuilt or  good used engine.
This is a diagnostic procedure, with solutions provided as you move through the process. It's not pretty but it is reality. I personally went through this on my 74 and the engine was cored out for exchange.
  Good luck , I hope it's not worst case scenario.
Quote from: pintosopher on March 13, 2009, 05:05:42 AM
Becky,
If the lucas oil doesn't quiet the lifter on your 2.3L , you may have a spray bar for the cam that's plugged up. The bad thing is, if it's not dealt with soon enough, the cam will wear out beyond the Lifter Hydraulic range of adjustment. (flat cam syndrome) Only pulling the cover can confirm this. If the oil wasn't kept clean ,the early 2.3 litre would starve the cam for oil and wear out the lobes and followers.
This assumes that your car (what year?) has the 2.3L motor. Kim's car is a 2.0L engine , totally different , and requires valve adjustments every 5K to keep it quiet and running well. If your car is a '74 with a 2.0L motor, then you need to have a manual valve adjustment too. In that case the Lucas oil won't quiet the engine down.
Sounds confusing, but the stock 2.3l engines have Hydraulic lifters to keep the maintenance to a minimum, BUT you must change the oil religiously to save that cam and lifters from oil starvation by sludge buildup.
My first pinto was a 74 with a 2.3L and I lost the cam and followers to poor maintenance by previous owners. Sounded like a diesel but ran poorly.
Follow up on this ASAP.
Yah, Becky has the 2.3!  Becky your are a lucky bummer!! I wish I didn't have to adjust lifters every 5000. Changing the oil every 3000 is alot easier!! LOL Oh well, guess I get to relive my VW Bug days again!! LOL ;D
Thanks for the info Pintosopher, I was just looking at the book, not really reading the 2.3 info, just saw a pic of them adjusting the lifters on it. That was probably done for a worse case senario!!
Thank you dear Pintosopher!  :tgif: ;D ;) :)
Baby is a 2.3 '74. I cannot account for her previous owners (I think I'm the third owner.) I do know the lady who sold her to me added a bottle of No-Smoke to her already-to-capacity crankcase (bad!)
     After all the stuff I tore off Baby the valve cover should be relatively easy, right? But I will enlist the help of Jerry to identify the spray bar and see if there's "flat cam syndrome" going on. I don't know nuthin' about cams! lol.
Becky,
Sorry to hear about your technical problems! I have Comcast, and it's been pretty weird/slow lately too.
Yes indeedy she os off and running! Thank you all for your support and help and kind words. Because I've never adjusted lifters or whatevers I'm not gonna touch those just yet! My neighbor/mechanic told me to give the Lucas oil a little while if it's the lifters that are sticking. If the oil doesn't do the trick, then plan B will happen (lifter adjustments I guess!) lol.
So you're all up and running now?  That's soooooo awesome!!!!!!!
Awesome!!   Your tapping may just mean it needs it's valves/lifters whatever they are called, lol, adjusted!! Hubby adjusted mine and she is quiet as a mouse now! LOL, ok not a mouse, but she is quiet! Just need to figure out how to stop the vibratie exhaust manifold tin noise at certain RPM's!!! LOL
 :lol: No more clattering!
I'm convinced it was the fan blades hitting the hose. I made darn sure the blades were nowhere near the new hose! The cover is on good and tight. Now Baby has just the tapping noise in her upper engine compartment. Hopefully the Lucas oil will work that out soon.
It looks like Baby is transportation #1 now- the Rodeo's brakes are bad.
If your car still deisels when you shut her off, just leave her in Drive, or Reverse! That will make it shut down fsat with no embarrasing deiseling!!  ;D
Sparks? Scary! My rubber spacers are intact and rubbery (as opposed to spongy and crumbly!) And I notice it only clatters when I'm idling or the car "diesels" when I shut her off. I've pulled her hose off and removed the timing belt cover. So far I see no wear. When I get the new hose I'll connect it and see, or hear, what happens with the cover off.
yea,I could tell it was the fan hitting something.  just before that i did have another noise  that cam from the timing belt cover being to tight  the cover has rubber spacers in it and they had deteriorated and i did not realize it  until i herd the noise and was sparks. i made new spacers from some hose that slid over the bolts they were just a bit longer than the ones  that were there. and put the cover back on.
Phil- was the noise you heard on yours a loud clattering noise?
Yeah, I'm glad too it was just a hose!  ;D
Shewwww, I saw your sad face first and I thought for sure something real bad happened!! Glad it was just the hose!!!!  ;D
that almost happned to me when i replaced my upper hose.but i cought the noise befor it cut the hose. to solve the problem  i rotated the fan till it hit the hose then losened the hose clamp on the radiator and twisted the hose  untill it was far enough ayay.  good luck.
You know, sometimes I am grateful to be so close to WallyWorld...
My wayward nostril (because it's possessed! long story.) wouldn't stop sneezing- therefore chronically running, I ran out of toilet paper and thus had to go to WalMart to restock. I opted to take Baby. Maybe this is a good thing in disguise. WallyWorld is only about a mile away. Before I pulled into my stall (interesting choice of words... Pinto, stall,.. get it?) I smelled the unmistakeable smell of coolant. I opened the hood... it was all over the place.  >:( I'm thinking... crap, I need a new radiator. This was all I needed. I bought another bottle of antifreeze and my other items and made it home after I replenished the coolant. I know this is risky and all, but the radiator wasn't missing all that much so I opted to go for it. After I got home (it was dark now) I took a flashlight to find the source of the leak. It was the upper hose! Apparently the fan was clipping it. All this time I've been looking for the source of her clattering and didn't see the fan hitting the hose. I certainly looked hard enough. I'm just thankful this happened only a mile away! Tomorrow: new top hose.
Those would be the ones!
     So what's keeping Hubby from saying "Drive South"? Tell him there's interested parties wanting a rare glimpse of the legendary Brown Ghost! lol.
Woooooooo Hooooooo!!!! You mean these? LOL
Congrats on the Baby finally going and getting back up the hill!!!!! I'm so excited to hear of this great news!!!!
Oh, and I"m still working on hubby. Things just arn't going in that direction yet! But I wont give up!!! LOL
 ;D :lol: :D :) :-* :happy_bday: :drunk: :2fast4u: :laugh: :police: :hypno: :read: :smile: :fastcar:
Kim, did you send me some Pinto love? C'mon now..
SHE RUNS!!!!!!!!
Kim, I need to borrow your great emoticons.
This morning, after a rough and kinda scary start The Baby ran! I didn't even have to feather the pedal once the engine was going. Then it was off to a series of tests... will she make it down the street and back? Will she make it up the hills she previously stalled at? Will she make it to the gas station and back? Will she complete a 14-mile round trip to my friend's place? YES!!!!! She passed with flying colors! She didn't stall once. I was so happy and so proud I was in tears and I'm not ashamed! I guess I had overfilled her radiator because at my friend's house the overflow tube spat out coolant. She does "diesel" a bit sometimes when I turn her off and she makes a most dreadful clanking sound (the noise that appeared after the timing belt was replaced) but she starts right back up. Now there's just some little things to do before the 19th. Oh. Did I mention that it looks like we'll make it to Knotts!!! Thank you THank you Thank you all for helping me and Baby get to this point. Right now my happiness knows no bounds.
Got the fuel pump installed- no mean feat. There was so little room and I needed a third arm! I got covered in gasoline and still reek of it now. But the pump is in. In the process of getting the new pump in the area I accidentally pulled a couple wires so off to Jerry's I go tomorrow. Also check for leaks. Then I'll see if the Baby will fire up. Foo.
I change my fuel filter about every 5000 miles (2-2 1/2 years). My tank was dry when I got the car. I didn't clean it, went thru a fuel filter about every month, and rebuilt the carb after about a year, haven't had any problems since with clogged filters (often causes bucking on acceleration, and need to 'feather' the pedal). You don't really want to be messing with the fuel filter more than you have to, the carb body is much softer than the threads on the filter, and if you're not careful, you can strip the hole.
