Date: 06/05/2018 09:13 pm
Date: 04/15/2017 05:14 pm
1971 Pinto
Date: 03/04/2017 11:28 pm
rear hatch back louvers
Date: 04/18/2017 12:44 pm
1979 Pinto Sedan Delivery
Date: 06/15/2019 03:30 pm
Date: 11/12/2020 08:28 pm
79 pinto driveshaft
Date: 08/18/2018 02:03 pm
Date: 08/16/2018 08:54 am
Date: 10/01/2020 02:00 pm
  • Online today: 548
  • Guests: 274
  • Total: 274
Cosworth Engine Ready for Installation
Started by cossiepinto, February 08, 2012, 06:25:20 PM
cossiepinto
Here's a little progess on the Cosworth Pinto.  The rear valence replaces the huge bumper and shortens the car by about 10 inches.  It completely covers the bracing behind the fuel cell, and gives the rear a pretty clean look.  Also, the license plate is frenched in.
That's why I haven't made much progress on my own stuff either. Too hot outside until 7pm+ and it's too dark by 8:30.
Keep up the good work...whenever it cools off enough to do so.  8)
cossiepinto
Reeves1,
Aren't we all?
Nothing posted lately about the Cosworth Pinto.  I've pretty much taken the summer off.  It's so hot in West Texas that staying in the shop to do tedious wiring is just brutal.  It'll cool off soon, and I'll get some work done.
Thanks for staying interested.
Paul
FYI ....I took an intake to be hot tanked in town - Westlock AB Canada.
One (new ?) guy working there had worked for Cosworth in England !
Guy is a 4 cyl nut case  ;D
77CrzgWgn
Haven't been around in a while so been a pleasant surprise all the dedicated work that has gone into these sweet looking vehicles. Nice work. And attention to detail is impressive.
1967 Cougar XR7, 1969 Mustang Coupe, 1970 El Camino SS396
1977 Pinto Cruising Wagon, 1979 Mustang Turbo
1996 Lexus 300ES (daily driver)
2002 Suzuki Bandit 1200S
fozzy
What a fantastic build!!
Looking forward to seeing more as you post up progress.
Fozzy
cossiepinto
Thanks, guys.  I'm still hooking up gauges and stuff.  Today, after spending a couple of hours monkeying with the cable-operated brake bias adjuster, I decided it was more trouble than it's worth.
I removed the whole thing, and am going to put a key-operated ignition switch (on-off only) in the space.  The brake bias cable apparatus is just not necessary.  I can still set the brake bias with a 9/16 wrench and an allen wrench, and that's enough for my purpose: set it once and for all and forget it.
I'll try more update photos soon.  I've done a lot, but just not posted in awhile.
Scott Hamilton
Paul- fantastisch!
Your Project is One I Always Look forward to Seeing Progress..
bbobcat75
just was wondering how this build was going!! looks great keep up the great work!
1975 mercury bobcat 2.8 auto
cossiepinto
Making some progress.  I'm putting the instrument panel together now.
The last photo is a manifold I thought up for the oil pressure gauge.  A hose runs from the engine to the manifold, then another hose to the gauge, using dash-3 hose and fittings.  Then a pressure switch is attached to the manifold for the warning light, and another switch is a fuel pump cut-off, should the engine stop.  I have a toggle switch that overrides this circuit for starting/priming the carbs.
cossiepinto
Progress report:  Wiring is finally underway, with a target of mid-February to finish up.  I found a local wiring expert who will help me with this final hurdle.  He has me on a strict schedule to get all the pieces into place that require wiring, so I'll be posting pics of some of these soon.  I installed the wiper motor and cranks over the weekend, and put a fuel level sender in the fuel cell, for example.  I climbed up in the attic and retrieved the inner fender pieces and installed them in the front fenders, too.  They were in great shape when I put them up and after a little armor-all, they turned out just fine.
I got a little carried away with the headlight buckets.  I had them powder coated instead of painting them with a rattle can, which would have been more than adequate.  See the pics...nice!
I also replaced the Flaming River standard rack with a quick ratio rack.  The standard rack has never been used, so if anyone is interested, I bet we can make a deal.  The combination of the standard rack and the steering quickener would have made the steering way too heavy, I'm afraid, so I decided the new rack would be better for me.
cossiepinto
Thanks Flygirl.  No, it never gets old.
I'm getting the brakes plumbing all figured out now.  I decided to use all AN plumbing instead of the automotive stuff, since it would have been a hybrid of AN/automotive anyway.  I've been using up 3/16" brake line trying to get all the bends, etc., just right.  So far, I'm not satisfied with the results, but every try looks better than the last.  Yesterday I drilled out the rivets that held the plate to the firewall in this picture.  I changed my mind about using automotive fittings, so I had to remake this plate.  This time I put in rivet nuts and bolts instead of riveting again so if I change my design again I won't have to drill rivets!  As you can see, it's a little tight down in there now, and I didn't want to remove the carbs, fuel lines, etc., so it was slow going.
Thanks for your interest.
Flygirl62
I just saw this thread and—you're probably sick of hearing it—just, wow.
cossiepinto
Thanks for checking, bbobcat.  Reeves notified me today, and the parts will be on their way soon.
bbobcat75
just was checking the forum and saw my last post!! totally forgot to look, go ahead and send them Reeves1, I don't have them and forgot to post I am sorry for the delay!!  here I am holding up progress on a great pinto build!! lol
take care
cossiepinto
Thanks, Reeves1.  Let's give bbobcat a little more time, since he spoke up first.  I'll definitely let you know if he doesn't have them.
If bobcat doesn't have them, I do. They are one my 72 parts car. Free. I'll even pay the shipping !
Canadians are such nice people  ;D
bbobcat75
cossiepinto
Yes, bbobcat75, I still need those brackets.  Let me know if you find them and what you want for them and a money order will be on the way.  Thanks!
bbobcat75
WILL CK MY PARTS CAR FOR THOSE BRAKE LINE BRACKETS IF YOU STILL NEED THEM, LET ME KNOW
THANKS
WARNING : Prolonged viewing of this Thread can lead to Mental instability, and even a possible PDE-5 inhibition effect that may lead you to a therapist for extreme Pinto Lust. Prolonged exposure in excess of  4 years can cause serious financial and perceptual damage to your Psyche. You'll know it's too late when you begin imagining your household Plumbing with AN fittings and Earls hoses..
See your Life for what it can be , and build your horse to suit! :o
cossiepinto
Well, I'm still working on this thing, and judging from the hits I'm still getting, not everyone has lost hope that it'll ever get finished.
Here are a few pics of recent activity:
1- I had to redo the breather/filler tank for the mini quick change rear end, because the under-the-floor tank was so low it wouldn't refill the rear end quickly enough.  I mounted a different one (mini-sprint type) on a vertical plate in the trunk, next to the fuel filter.  You can see some plumbing there as well.  The fuel pump is inside the cell, so that makes for a much less crowded area.
2- Yesterday I attached the calipers to both the front and rear.  I only had to machine a tiny amount off the RR caliper to get it centered on the rotor.  Everything's a tight fit with new pads, but that fit was just too tight, so I spot faced the caliper ears a smidge and all's well now.  Funny, none of the other calipers required machining or spacers.
3- Just a look-see at the front caliper. Note how the hubs match front and rear.  Speedway Engineering had matching stuff that I really liked.
4-  HELP!  Check out the red arrow in the last pic.  What's missing?  The brake hose tab, that's what.  It's also missing on the other side.  I spent a couple of hours fingering through all my stuff and they are either playing a masterful hide-and-seek, or just plain gone.
If anyone has a couple (I'm pretty sure right and left are the same), I'd gladly buy them from you.  Please let me know.
johnbigman2011
1oldtimer I spoke with Mr Cossie just the other day, and he stated that he is down to running wiring and such.
I'm going to make a point to go by his place on my way back from Idaho in May.
It is an awesome build for sure.
1oldtimer
I know this is an old post but any more news.......I'm hooked. Now I want to find a Cosworth head for my 2.0.
'72 2.0 in a '28 Ford.
cossiepinto
New Weber condoms came in today.  I hope I don't have to keep covers on much longer, but these fit nicely and should seal out dust better.  Can't wait to put the filters on and light it up.
cossiepinto
You're welcome ponyrancher.
I've become more "capable" as time goes on, making mistakes and do-overs.
Four hundred horsepower from a naturally aspirated 2 liter YB Cossie is possible, but it'd be awfully rude and waspy in normal street use. Turbocharging would make that horsepower more easily, but it's still costly.  I've seen claims of 700+ for race-tuned turboed YBs.
This little engine is tuned to about 200 horsepower, should idle normally, and will rev to about 7800 if it has to.  I have set the rev limiter at 7200 rpm to start with.
Paul
ponyrancher
Just setteled a fight between my grand kids  and found your thread.  I had always dreamed of putting a cossi head on my pinto (1973 mini mark IV) after I saw the advert for 400 horses @ 8000rpm.  Of course I am incapable of doing the work you have done let alone the quality you have done also.  So thanks for letting me live my dream in an alternet universe.
cossiepinto
I try my best not to make her miserable....been married too long not to have learned that lesson!  ;)
