  • Online today: 553
  • Guests: 226
  • Total: 226
Cosworth Engine Ready for Installation
Started by cossiepinto, February 08, 2012, 06:25:20 PM
cossiepinto
One more pic, from underneath the Escort.
cossiepinto
Ranchero,
Me too!  The supplier says the outlet of the header is above the frame rail, just about even with the exhaust ports on the head.  Then the pipe that bolts to the collector follows the same path as  other headers do.  The advantage appears that no matter what kind of motor mount/starter/clutch (in right side drive England) you use, there's no interference.
My biggest worry is that the pipes may kick out a bit more and bump the inner fender shelf where the battery tray used to be.  I removed the tray (rust) many years ago, and am now kicking myself for rebuilding the shelf instead of just pointing the inner fender wall directly down to the frame.
In case you missed the pics, here are a few of the headers.  The first shows how snug they fit in an Escort.  One of the others shows an optional tailpipe extension that takes two bends follow the firewall and get horizontal under the car.  I got one of those, too, hoping I'd be able to use it.
fast64ranchero
Please keep us up to date, I'm interseted in how the new header fits, the header I got for a MK1, look like they will not fit... I'm hoping yours drops right in..
72 old V-8 parts Pinto
73 pinto, the nice one...
johnbigman2011
Paul, very, very nice. I know that I have a road trip planned for my 72 early next Spring. So whe you here a swarm of angry hornets coming your way. Don't run it will be the YF and me coming to see that amazing Cossie.
cossiepinto
Bigman,
It won't be long before I start the wiring.  I'm dreading it, especially with summer coming on.  I do have a Painless Wiring fuse box that will help, and many of my gauges are mechanical (tach, oil press, oil temp, water temp) so the dash wiring won't be too bad, but still the most tedious.
Paul
johnbigman2011
Paul,
That is one of the cleanest engine compartments that I've seen.. ( I hope to get mine looking half as good as yours) I can't wait to see how your going to run the wiring.
cossiepinto
Got some plumbing done this afternoon.  All's I have left as far as oil lines goes is the oil supply line from the tank to the pump.  That involves getting under the car, and I'm feeling too lazy this afternoon.  Sounds too much like work.
Here are a couple of plumbing pics so far anyway.
cossiepinto
Bigman,
The fuel lines are AN-6 (3/8 inch) from the pressure regulator to the carbs.  The fuel supply line from the cell is AN-8 (1/2 inch).
Give me a little more time to get the headers in the car before you make the trek across Texas.
The headers haven't shipped out of England yet. The guy said it'd be two weeks, and it's been a week already.  I sure hope they just fall in without any fuss.
johnbigman2011
Now that is state of the ART for sure.... Just look at the size of them fuel lines. I for sure will have to make a trip and see that setup for sure..
cossiepinto
Ok, Pinto'ers,
Here's an update on the Cosworth Pinto.
I got the radiator mounted for good today, as well as the oil cooler.  I had to remake the oil cooler upper left bracket because of a radiator change awhile back.  The cooler sits slightly off-center because the radiator was off center to begin with, and now it's a little more so.  I'm going to leave it that way and call it "art."
I made sure the oil tank was thoroughly clean and mounted it for good, as well.
Next is to clean out all the oil hoses and mount them up.  They've been sitting for so long I'm sure they need a bath.
Take a look at the two pics, one of the cooler and one of the carb plumbing.  The -3 hose on the firewall lip with a little yellow cap  is a bleeder hose for the internal clutch slave cylinder.  I have to get some anti-chafing sleeve so those hoses won't try to eat each other once the engine is running.
More soon...
Scott Hamilton
Paul,
Yes- I'll PM you back now. I have several that I have not responded to due to time constraints.
Thanks for reminding me,
cossiepinto
Scott,
Different forum, but did you ever get my message about the alternator bracket?
Paul
Scott Hamilton
Nice Pipes?- I have heard THAT in different circles...
Ohh, come on- I'm sure you have too.  ::)
cossiepinto
Hanto,
Nice pipes!  Yeah, before I started doing my own welding, I took the Pinto to a friend's shop to do a few things.  Three YEARS later, I got it back home!  He did some great work, and the price was definitely right, but now that I'm welding I can do so much more.  If I don't like what I did, I can just redo it, no harm no foul, no hurt feelings, no wasted cash, and no settling for something that I didn't quite have in mind.
The headers are same story:  our first attempt didn't turn out so well.  There are pics somewhere of the headers bolted on the mocked-up engine, and although they are nice enough, the front pipe hits the alternator, and they are so close to the inner fender that I have to loosen the motor mount to fix them in.
The new ones are a better bet.  They fit the MkI/MkII Escorts, which have the same dimensions, frame rail to frame rail as the Pinto.  And you're right, the exhaust on the passenger side helps a lot.  My first choice was a BDA, which has exhaust on the driver side, and I'm sure it would have been a custom job as well.
I still have some concerns, but I think these will work with little to no mods.  I'm keeping my fingers crossed, though.
you guys are both heroes!
how ya doing charles?
Quote from: cossiepinto on March 12, 2012, 06:59:24 PM
I've thought about having headers custom built here, but the idea of towing the unfinished car some distance and then going back weeks later to pick it up wasn't too appealing.
Paul, great project! I was in the same position with my pre-cossie twincam. Because of the super tight fit on the driver's side instead of passager side exhaust as you have, I HAD to go custom. I delivered the car and was told 2 1/2 weeks...4 months later, I got the car back. BUT, the guy did a fantastic job fitting equal tube headers where there was NO room. Your lucky you can go off the shelf. All and all, mine cost me about $800 plus a can of heat resistant silver paint.
cossiepinto
Been busy here, and the going is slow, fitting everything together.
My latest snag is getting headers.  I found some in England that, after quite a bit of communication back and forth, look like a good bet they'll fit with little to no mods.  Here's one of the pics I sent the guy in England and one of the pics he sent back.  There are lots more pics with these headers in a Mk I Escort, which I discovered has the same frame to frame measurement as my car.  Like I said, I hope it just goes right in, but if not, at least it can be made to fit pretty easily.
Regards to all,  Paul
fast64ranchero
cossiepinto
Another pic of the oil tank bracket.  Don't know why it didn't pick up the first time...
cossiepinto
Ok, I made some progress this past couple of weeks.
I finally got the oil tank and radiator mounted and not interfering with each other.
I also widened the inner fender to give the alternator a bit more room for adjustment.  The alternator bracket is "dropped", which is cool, but it makes fitting the thing a hassle.
Also, you can see there's not much room for the oil tank to clear the alternator pulley.  After lots of fiddling, it now does, with about a half inch to spare.  Now I don't have to cut on the tank...I didn't want to do that!
Here are a few pics to look over.
cossiepinto
Busy weekend.  I "widened" the engine compartment enough so that the alternator fits, mounted the radiator, and am still fitting the dry sump tank.
I am fabricating the tank mount now, and it looks like it'll all fit without my having to modify the oil tank itself.  That's a relief.
Maybe a few pics soon.
cossiepinto
Ranchero,
I'm in San Angelo, Texas, which is probably out of the way for most Pinto Groupers.
Yes, I realize I got a deal for sure compared to today's prices.  At the time I bought this engine, it was still in production, so parts were readily available and plentiful.  Now the aftermarket is the main source and their procurement/stocking situation has understandably driven costs up.
I must say that the folks at Cosworth have never allowed me to feel like a "little guy" when dealing with them.  I have had a great relationship with Ken Jacobs there.  He's sent me bits I've needed from his old stock from time to time, too, from seals to an ARP stud kit.  His supply of YB parts has dwindled since they've moved on to new stuff, but he's become my first choice (even over ebay) when I find I need something, and he's so well connected that I'm sure he can find anything I'd ever need.
The last (and only) time I visited Cosworth in Torrance, I was really impressed!  Not only did I lay my eyes on a YB for the first time (it was being readied for someone's sprint car), but they had a whole shelf of Olds Quad-4 engines all built up for someone's race team.  There must have been 3 or 4 of them.  Cosworth should be on the itinerary for anyone traveling that way.  It's an impressive operation and they're really friendly.
fast64ranchero
Cossie, I can say, if you only paid $7,500 for your entire engine kit, you got a deal by todays prices!  where are you located? I'm hoping to have the new head on for my June Vacation, I was going to go to the Fun Ford Weekend in Spokane June 9th, but it's not on the schedule anymore....
cossiepinto
Sorry Ranchero,
But the damage is done and the Cosworth's in your head now!
They aren't cheap, and I'm so glad I bought this one when I did...if I had to do it again it'd be tough to do.
Paul
fast64ranchero
Cossiepinto, I wish you would have never started this thread  ;)  I searched and found a used but complete "kit" with a 4x4 Cosworth YB 16V head, complete with Rally Solid tappet cams, adjustable cam gears, mellow porting, Escort MK2 big tube header, Weber intake, Cosworth rods and Cosworth forged pistons. not cheap but it sure will look good  ;D
cossiepinto
This is true.  This engine is all over the UK and elsewhere (but here) in wrecking yards.  It's used in "YAC" form in SCCA Sports Racing cars, too, so there are builders here in the States.  Companies like Burton Performance sell parts, and you can find lots of bits on ebay.  I found things like the dropped alternator bracket from an aftermarket company in the UK on ebay.  Of course, that's opened a can of worms with clearing the inner fender, but it'll be worth the effort when I'm done (I hope).
I'll have plenty of leftovers from this kit when I'm done.  For example, Cosworth provided a fuel pump block-off plate, but this engine block didn't need one.  They provided a heater hose plate, but I fashioned my own and didn't use it.  That little piece is bringing $$ on ebay right now.  I'll be ebaying stuff like that myself soon.
Cosworth USA is selling an aluminum block now for $6,000.00. Ouch!  That'd be about $100/pound of weight savings...out of my league!  But it does indicate continued interest in this engine.
Note you can still get the parts from the U.K. and Ebay is still your friend. Also for that matter try a little north of U.S. yes you can if you can pay...
cossiepinto
I talked to Ken Jacobs at Cosworth on Friday.  I asked him if Cosworth still sold these engine kits.  The answer is no, but he can put together one if need be from individual parts.  He said it'd be much more expensive than back when I got this one, though.
Update:  Today I built the radiator mounts.  I had AFCO build me a custom radiator awhile back, and of course it doesn't fit the original spot.  It only took a couple of hours and now all's ok.
I also discovered that with the "dropped" alternator bracket, I'll have to run a much shorter belt and keep the alternator tucked up closer to the engine to keep it from bumping the inner fender panel.  I might just cut a bit away and make a new panel with a little more room.  Of course, the adjuster arm's too long now.  No biggie.
Same thing goes with the dry sump oil tank.  The alternator pulley is a bit too close for comfort, so the tank's going to get a slight modification for peace of mind.  It'll lose about a pint of volume, but it's a 10 quart tank, so I don't think it'll miss it.
I knew all this was going to happen, but didn't have a clue as to what to do until the engine was in the car.  Now I know.
beaner
Quote from: fast64ranchero on February 19, 2012, 06:24:50 PM
Nice! Very Nice..
By the way I priced a Holbaytwin cam head conversion "kit", you can still get the head conversion kit, but it's out of my price range only $14500.00 before shipping....
for that price you can get one for each of your cars :o :o :o :o :o :o :o   jk  ouch :'(
brad :)
fast64ranchero
Nice! Very Nice..
