Date: 03/06/2019 06:40 pm
2.8 Engine mount brackets
Date: 12/28/2016 11:42 am
74 Pinto wagon armrests
Date: 01/18/2017 07:04 pm
Date: 02/10/2017 09:30 am
1973 Pangra
Date: 01/06/2015 02:19 pm
Electrical
Date: 03/29/2017 11:37 am
2 liter blocks and heads
Date: 03/28/2018 09:58 am
front end parts
Date: 03/30/2018 12:48 pm
I need a 1976 hood
Date: 12/19/2016 06:02 pm
  • Online today: 572
  • Guests: 526
  • Total: 526
Cosworth Engine Ready for Installation
Started by cossiepinto, February 08, 2012, 06:25:20 PM
Quote from: cossiepinto on May 07, 2012, 07:05:10 PM
Thanks for the feedback, SRT.
My problem has been that as my capabilities/pocketbook have become more "capable", I keep doing do-overs.  My wife wonders if I'll ever finish.  It seems every milestone uncovers a new challenge.  Right now, making everything fit has been slow, especially with only weekends to make things happen.
methinks your loving wife might be a bit bit more miserable if you weren't able to 'do it right'
cossiepinto
Ok, here are a few pics of what's going on lately with the Cosworth Pinto.
I'm still waiting on the transmission tunnel cover to get back from the powder coater, so I made the engine/oil tank vent hoses up, permanently installed the carbs, headers, radiator, oil cooler, and oil tank.
I also timed the distributor.  There's only one way it can go, since the right angle cap can only point one way.  It's easy to monkey around with it, since you don't have to worry about the oil pump drive falling off the bottom into the pan when you yank the distributor up.  I guess the added expense of the dry sump was worth it!  Haha.
Once the transmission cover is in place, then will come the tedious wiring exercise.  Hours I want to work on the thing are limited now that it's 100 degrees almost every day here by afternoon, sometimes earlier.
Enjoy.
cossiepinto
BigMan,
I bought this car in 1988.  It had a hole in the side of the 2 liter engine and the back floorboard and spare tire well were full of rainwater.  After getting a clear title, the roll cage went in, and I did a few things like putting an 8" rear end in and designing a big brake system for it.  My first plan was to build another 2 liter or possibly buy a BDA (actually a 1700cc BDR) engine, but this plan evolved over time to the YB Cosworth engine.
There were times when the car sat for years (once for 3 years in a row) untouched, especially when we were raising our kids and getting them settled in life, etc.  The Pinto always was last in line when it came to the budget.
Now, we're empty nesters, and time and money are a little more plentiful, hence the upswing in activity and spending.  My wife now wants me to "finish the darned thing", and I'm happy to oblige. It's the Pinto's turn.
Funny thing is, over the years, with the Pinto front end becoming a popular piece for hot rodders who want to put independent front suspensions in, things I never dreamed of are now available: tubular a-arms and brake/hub packages, and nice shocks (although I scored a set of Konis from Racer Walsh years ago), etc.  And, with Pintos becoming popular in mini-stock circle track racing, other suspension bits became available.
So, the short answer is the Pinto's been in the family for 24 years but it's resided in a nice dry garage, untouched for many of those years, waiting its turn.
Paul
johnbigman2011
Paul, how long have you been working on the Cossie Pinto.
cossiepinto
Quote from: cossiepinto on April 29, 2012, 10:15:04 AM
BigMan,
I don't know how high-tech the Pinto is; it has some goodies on it, but they're all pretty old-school.  I do have electronic ignition, though...MSD.  Old school high-tech!
Paul
imho, hi tech means attention to detail, flawless (as much as it can be done) workmanship and the willingness to experiment. i suppose you could throw in some modern technology but 'old skool' is really just a way of saying that you can use your imagination and the technologies at hand to perfect your dream
cossiepinto
Bigman,
That might have worked if I'd have thought about it in time.  I did need a little extra room to get my fingers in, so I could unscrew the thing, though.  A fuel bung might have been a little too small.
Make sure you take a detour and come by San Angelo when you go on your tour!
Paul
johnbigman2011
You could probably use a fuel bung cap like they sale at So Cal. I purchased one for my t-bucket . I think it would fit nice and look custom like the rest of your car.
Just my thoughts.
I do enjoy turning on the forum and seeing new post about your car!!
Keep it up there Mr. Cossie
West Texas has a pin in it for my power tour that the wife and me will be doing, either this Fall or next Spring
cossiepinto
Thanks, Joe, but I don't want you to go blind viewing this project too often!
I'm wrapping up the transmission tunnel mod this weekend.  I had to fabricate a cover and a short stack to clear the oil breather/filler on the top of the gearbox.  I made a lid for it, but am not satisfied, so I'm going to try again.
I need to scare up a 3 3/4 inch diameter aluminum disc to make the lid.  I'll look for something this week.
Right now, the plate is clecoed in place while I wait for my powder coat friend to do a batch of textured black...should be late this next week.
Paul
Paul ,
This is pure Pinto fabrication Porn.. I'm addicted and I don't care who knows it! PM me if you ever want to do this again. Make sure this car is in every Ford mag .. I salute you sir.. ;)
Pintosopher,  Student of the Wizards, Apprentice to the Fab Gods!
cossiepinto
BigMan,
Paul
johnbigman2011
Paul, what could anyone say.  The car is one High tech piece of work for sure.
cossiepinto
So far as I can tell, all is aligned well.  The only iffy part might be the pinion angle, as I'm not using a standard rear end.  When I talked to the guys at Speedway Engineering, we settled on a standard pinion angle for the mini-quick change I bought from them.  I can adjust it as necessary.
The Quaife is based on the Pinto German Hummer gearbox, so the standard Pinto bell housing (2 liter) bolts up nicely.  When I decided to use an internal slave cylinder clutch bearing, I sent the measurements to Taylor Race Engineering in Plano, TX, to get the proper input bearing collar length.
If the Quaife had the standard sheet metal trans cover and no breather stack on top of it, the transmission would have slipped in with no worry.
You can see the mini-quick change in this pic with the fuel cell not yet installed.
Paul
Cool project ! Been watching all along as you go.
The crank/trans/diff is in line well ?
cossiepinto
Ok, here's what's up with the transmission tunnel modification so far.
The Quaife dogbox has an extra-thick top cover (about a half-inch) and the filler/breather stands up about another inch (not including the threads to screw it into the cover).
My first clue that I was out of room was when it was very difficult to bolt the transmission cross member in.
Of course, I ignored that clue.  Luckily, I had to remove the engine again to fit the headers.  This time, remembering how difficult the bolt-up was, I decided to remove the filler plug/breather and put in a temporary plug 'til I got the engine/transmission in.  That worked great!
When I crawled underneath to replace the temporary plug with the filler plug/breather, only then did I realize that I had no room!  I couldn't even get my fingers in there....
Hence the hole in the tunnel, etc, etc.
It's going to work out fine, though.  The plate on top can be removed by drilling out rivets, if necessary, and there will be a cap that I can open to fill the transmission, if need be.
Paul
cossiepinto
Here are some photos of the final fit for the headers.  They fit with about an inch of clearance at all critical points.  The pipe sent with them will fit also, but it'll need to be indexed just right to clear the bell housing.
I'm now working on placing an inspection plate on the transmission tunnel, so the breather/fill plug won't hit the underside of the tunnel. I found out the hard way (almost impossible to bolt up AND then the plug isn't removable with the transmission in place) that I needed some more room.  I'll send out some pics of that, too, when I get it all done.
It's been a little slow going this past couple of weeks:  out of town last weekend and this weekend is my bride's birthday, so no Pinto work then!
Paul
cossiepinto
Thanks for the good words, Starliner.
Cosworth offered this engine in kit form.  They also offered a mechanical valve train engine (YBG), but I wanted a lower-maintenance, more streetable engine, so I bought the YBB.
I like the sound of a naturally aspirated engine sucking air through Weber air horns.
I admit, however, that I didn't have the turbocharger mounting brackets machined off the head!
Paul
Starliner
Awesome project and I admire the workmanship.
That engine is going to sing a glorious sound at full song!
When I am in Hong Kong I always pick-up British car magazines.
I love the magazine "Fast Fords".   Every issue is full of Cossie goodness.   I think you can subscribe here in the states.
I love the British Escort Mexico's and Cortina's fitted with the Cosworth YB'T' engine.
I am curious why you did not go the YBT turbo route?
http://www.youtube.com/watch?v=usbg9DWnvsI&feature=related
I will continue to check in and watch your progress.   Keep us updated, the pictures are great!
1973 Pinto 1600 - Sold!
1979 Pinto 2300 - Sold!
Ahh..... I just get aroused looking at this thread! Rock On Paul! 8)
cossiepinto
OK, the headers fit now, with the slight mod to the frame.
I cut out a small notch in the frame for insurance after I removed all of the porch the battery tray used to sit on.
That inner fender removal gives me all the room I need to work the headers into place.  Now I'll make a panel to re-close the area, but it will still be removable when I need to remove the headers for any reason.
I had to modify the passenger side motor mount slightly also, but that wasn't a big deal.
I did discover why I'd had so much trouble putting the transmission cross member back in place, though.  The extra thick aluminum cover on the Quaife transmission just barely touches the tunnel at the right rear corner.  Also, the little breather fitting sits up against the tunnel solidly, which was making it hard to get the cross member to bolt up.  I'll trim a spot out for those in the coming days.  It won't require removing the engine.  I'll just remove the cross member and let the engine tilt back and the transmission to drop a little.
Here are a couple of closeup pics of the pipes and the mod.
Paul
82expghost
at first glance, it looked like the 4x4 trans out of the euro escort
98 taurtus, now in heaven
77 pinto, weekend warrior
92 grand marquis, daily
cossiepinto
Ranchero,
It's a Quaife-internals 4-speed Hummer, a.k.a. Rocket dogbox, with straight cut gears/no synchros.  2.04 low, close ratio, 1:1 top gear.  1st gear will feel like 2nd gear, but with a 4.11 or 4.86 (I'll try the 4.11 first), it should be fine.
fast64ranchero
Making progress, that's a good thing,  what tranny is that? type 9?
72 old V-8 parts Pinto
73 pinto, the nice one...
cossiepinto
OK, here's the latest:
I cupped out a little area that aligns with the spot where the header gets closest to the frame.  I also removed the step that was once the battery tray area, and am replacing it with a removable piece that allows me to fit the headers in over the studs.  It requires a lot more room than I thought it would, but now I can fit the headers and trim the piece to fit nicely underneath.
Also, with the engine out I went ahead and fitted the headers so I could check for clearance around the bell housing and all is well there.
Here are a couple of hastily shot pics.  Engine goes back in this week/next weekend.
Paul
fast64ranchero
If it was easy everyone would do it!  Your going to end up with a one of a kind setup!!!!
cossiepinto
Well, the headers are here and they're going to need a little work to fit.  I've already started measuring, cutting, and measuring again.  Now they bolt up to the engine, but I still need to put a little notch in the frame so they won't bump and rattle.  The inner fender step where the battery tray was is gone now.  I'll have to flatten it some and relieve the area around the header flange a little also.  This means the engine is coming out tomorrow so I can get to all the area I must cut and weld.  I worried that this might be the case and I've been prepared for it while still hoping nothing would need to be done.
If I'm lucky this won't take more than a long weekend to do.  Pics as soon as everything's presentable again.
Paul
johnbigman2011
Great craft manship there. I'm borrowing ideas as you go along for sure.
cossiepinto
Quiet weekend.  Still waiting for the headers from England. But I did get into the brakes a little.  Installed the master cylinders and a little plumbing.
Kinda wish my hands were on backwards a couple of times!
Quote from: Scott Hamilton on March 13, 2012, 09:03:35 AM
Nice Pipes?- I have heard THAT in different circles...
Ohh, come on- I'm sure you have too.  ::)
oh we all have...at one time or another...but these are like header porn!!!!!!!!!
http://www.fordpinto.com/index.php?action=dlattach;topic=19990.0;attach=39534
johnbigman2011
Iread somewhere that the frame for the two cars are pretty much the same..( I may be wrong) Hopefully you wont have too much troubles.
