Need seals Pinto Wagon
Date: 02/16/2017 05:09 pm
Date: 04/08/2018 05:47 pm
71-73 Front Kick Panels
Date: 04/25/2021 07:24 pm
Date: 10/10/2019 09:42 pm
Date: 04/06/2017 12:13 am
1980 Ford AM radio
Date: 12/22/2019 11:57 am
78-80 Windshield
Date: 10/29/2021 03:11 pm
Date: 12/26/2016 04:29 pm
79 Wagon with many extras
Date: 07/08/2020 04:18 pm
  • Online today: 481
  • Guests: 201
  • Total: 201
2.8L mods
Started by waldo786, April 23, 2008, 10:47:20 PM
waldo786
Very cool lots of good info there.  Thanks!
lencost
Volksnut...Thank you Thank you Thank you for the Ranger station link.
1975 Wagon 8" C4 2.8 V6
David ,
Great to hear of your V6 interest in modding the 2.8. In my library I have a book from 1982 on V6 performance, and it has a Ford V6 section that had all the reasons that the 2.8 was a better engine than the 2.6 V6 that the european ford Capri came with.
Count you blessings, the 2.8 in U.S. smog legal trim is a slug BUT there was a bunch of potential for that motor back then and some of the V6 goodies for the Ranger v6 (non Mazda source) would fit the 2.8.
There was a V6 Ford aftermarket company back in the 90's , for Ranger Pickups. They built a wild 4.0L v6 for racing in the Nevada open road racing series. Unfortunately, I believe they went out of business, and I don't know if they reopened later.
I'll look into it further , who knows ...we might get lucky :amazed:
69GT
   Yes there are several things you can do.
                The poor power rating came from the low compression and mild cam installed with several degrees of retard necessary to make it pass smog in the U.S.
I know there were headders  4-BBL intakes and several aggressive cams (All solid) to choose from. I think Racer Walsh might be a good source of info on where to get these things.
    An aggressive cam with compression as high as street gas will allow with headders and that 4-BBL aluminum intake with a small 4-BBL carb should get you close to 200 HP. Porting the heads will make it a lot more angry. Just depends on what you consider a streetable cam and RPM range. Those motors love to rev so if budget allows good pistons and valves/springs sounds like a fun combo. I really want to build one too after seeing a 70s 2.8 Capri lay waste to an 80 something  5.0 Camaro. My friend had one in his Capri and said it got only 14 or 15 MPG with the 4-Speed, steep gears, and all the mods. I am unsure about things like where to get a good overdrive stick shift (Or auto) tranny that will work and fit a Pinto. And hop up parts are sometimes hard to find.
Hope this helps.
waldo786
Are there any mods that can be done to hop up the 2.8L v6?  What is the main reason for poor power in these engines?  Thanks for any insight on this.  I understand there is an offenhuaser intake for these but would a good mandrel bent dual exhuast and new intake wake it up or..?  Would porting/polishing the heads do anything and do they make headers, etc?
