front end parts
Date: 03/30/2018 12:48 pm
Date: 05/13/2021 05:29 pm
1979 PINTO PARTS--FREE
Date: 09/13/2022 02:05 pm
Weber dcoe intake 2.0
Date: 08/01/2018 01:09 pm
Date: 01/30/2017 01:48 pm
Clutch Cable Needed
Date: 04/03/2017 11:03 pm
Date: 10/24/2018 07:35 am
Date: 12/10/2017 01:14 pm
Date: 02/28/2018 09:33 am
  • Online today: 826
  • Guests: 566
  • Total: 566
1977 Pinto- project in the works
Started by r4pinto, April 07, 2008, 07:54:57 PM
0 Members and 3 Guests are viewing this topic.
There is something special when you can fire it up and hear it run.  it just re-charges you to keep going.  Hang in.
Well, I got a little bit done to Harold II today. I started off by pulling off the carb so I can clean it out & adjust it. Found about 1/8" of rust in the bottom of the bowl. Good thing I dropped the tank to fix the leak. Gave me a chance to flush it out. I also got a new vacuum line that goes from the bottom of the air cleaner to the vacuum air heater valve mounted on the hard part of the duct. Nothing else, as I wasn't home too long & had to pack my car of any tool I need for my grandma's a/c repair. I'm still planning on firing her up this weekend. Just need a few little things so she can run. Hopefully more will happen Wednesday. I might get the carb back together & on the car tomorrow evening, might not. Depends when I get done with my grandma's a/c.
...with padded walls! lol!  :lol: :lol: :lol:
lol.. True, true. And yet nobody knows why. We better behave before they tell us to get a room  :lol:
You are.  :devil: But for some strange reason we love you anyway!  ::)
Nah.. I expanded in the coed section :lol:  ;)
I am rotten
Yeah... for you and Robert! lol.  ;D
There's room for two in there now. I expanded.  :lol: :angel: :evil:
there you go with that crazy talk again. Do I need to lock you in a padded room?  ;D
Hmmmmm.... Okay, works for me. For payment I will take one of your Pintos off your hands  :lol:
Yeah right, like that would happen. I couldn't take them away from you. :laugh:
Good for you Matty! You're kicking butt! I know all about tripping over the tools. I finally cleared them out of my living room for the same reason... :o ::) :rolleye: Now come out here and fix mine! lol.  :lol:
Not much happened to the car today. The heat and humidity was up there today, and I had to clean my work area, so I could work on the car. It was literally so bad that I couldn't walk 6 inches without tripping over something.
Anyways, I did get a little done to the car. I had a problem with a stripped out bolt hole on the egr valve. I took a look at it & found that just the first few threads were gone, so I found a longer bolt in my collection & got the EGR to tighten up with no problem. I also got the ignition module bolted back to the car and the top of the radiator painted with semi-gloss black engine paint.
While cleaning the garage I found the missing lighter and ashtray so I got that back in the car. I also cleaned up the driveshaft & got it ready for the new u-joint. More to come soon.
Got the gas tank done!!!
I got new fuel hoses, as well as a fuel strainer for the car. It isn't the correct one for the car, as I could not find one at this time, so I bought one from the parts store, cut it in half, and clamped it to the sender. It is on there snug, and does not interfere with the float arm. I also installed the repaired float to the arm. Hopefully the repair to the float works, but to be honest I'm not gonna hold my breath.
After I reinstalled the sending unit I got the tank back under the car. I made sure to clean off the driver side strap of any rust to make sure it didn't rub the repair the wrong way. I did put about a gallon of gas in the tank & so far all is dry. I have some pics of the gas tank repair, as well as the sending unit mod & I will get them up as soon as possible.
Next I plan on installing the muffler I got from Phils Toys, as well as making a couple temporary patches for the floor. While I did get a replacement passenger floor from Phil I don't have the time or equipment to weld it in. The patch will be temporary and will do for now. I also plan on getting the ignition module mounted on the car, instead of just sitting there. If all goes according to plan the car will be ready to fire up by the end of the week.
More to come later.
Well, I cleaned out the tank & had lots of rust come out of it. I rinsed the tank three times and had lots & lots of rust & sediment come out of it. There is still a little in there but I have done the best I can on this tank. After I got it cleaned out I filled the tank with some water to check the repair on it.
1/2 hour later no water had dripped from the repair. I drained the water and tomor I was able to row I will be fabricating a strainer to replace the old, dead one. I am gonna buy a strainer from the parts store, cut it, and use a clamp to hold it to the sending unit. That would work until I can track down the correct strainer. According to Ricart Ford the strainer is part of the sending unit, which I don't believe as back in 2006 I was able to get one but chose not to. Stupid move, and now I am paying for it.
To make things a little worse I found the sending unit float has a tiny, tiny pin hole in it. The hole is so small I can't even see it until the fuel seeps out of it. I am gonna see if I can fix it with a little JB weld, especially since I replaced it back in 2006.
That'd zoop. I have all the body parts I need. Good thing I plan on installing some high quality seats out of a Mercury Topaz coupe.. mmmmm power driver seat  :)
...or anyway with the synthetics in the seats you'll grow another body part in an inappropriate place.  :o
You know it hun.  :lol:And for fiber I chew on the worn out driver seat  :lol:
Guess that's one way to get your iron... iron oxide.  :cheesy_n:
Nah... No grease under there.. Just lots & lots of rust  :'(
She will live, hopefully by the end of the week  :D
I know you'll do it! Too bad I can't be there to help... then again we'd laugh so hard we're bound to knock off some dirt-grease-oil chunks from the underside of HII and they'd fall like snow into our howling mouths. Yuck!  :P :D :lol:
LOL.. Good thing she is unconscious at the moment. Soon she will live for the first time since early 2007.
That poor lil' car... if she could blush in embarassment she would.  :embarrassed: :laugh: :o
I couldn't help myself  :lol: It really looked like she was peeing.. And she took a while too. Good thing she had a paper to read  :read:  ;D
Quote from: r4pinto on June 16, 2009, 02:52:35 PM
It's official on the tank. I removed the driver side strap and she started peeing in the drain pan I put beneath her.. Hmmm driveway is to hospital bed as drain pan is to bed pan  :lol:
Anyways The gas looks very nasty, I think from all the rust in the tank. It still smells fresh but looks horrible. I will be donating that stuff to the lawnmower. Next I will be dropping the tank and turning it upside down so I can attempt to patch the hole. It will be a temporary patch so I can get her going, and I will be replacing the tank. More to come soon. Gotta see if she is done peeing
Leave it to Matt to stuff a bodily function comparison in there.  :P :o ;D
What I used whn I cleaned mine was acetone (like for paint.) I believe it breaks up the varnishy residue in the tank. Then soap 'n' water it.
She quit peeing so I removed the other strap. That was not fun at all but I will say that was the easiest gas tank I have ever pulled, not to mention the lightest. I did forget to remove the gas cap so the cover snapped off it. I hammered on the lip & screwed it back on. It's all good.  I used some of that Permatex gas tank patch putty & will be letting it sit overnight. Next will come the soap and water to clean it out, as well as the chain to remove some of the rusticles from the inside of the tank. That will be happening tomorrow, as well as putting new rubber hoses up there. They weren't that old but I got lazy & cut them to remove the tank. No problem since it's cheap to replace it.
Nah... I been saying that for years about this car. I must save her.
Well, I ran water through the radiator & got it all cleaned up. I also used some 200 grit sandpaper on the top of the radiator to clean it up. Looks better & is ready for a little paint. I did use some metal polish on the radiator cap, and it is very shiney now. I installed the washer bottle I got off Phil & it holds fluid nicely.
Unfortunately the gas tank is shot. I didn't get a chance to pull it, but when I was getting ready to install the license plate light I noticed the gas tank was wet. It was gas. I now need to replace the gas tank before I start the car. If it isn't one thing with this car it's another.
Things seem to be turning around for my car! I was looking for a place to get my radiator repaired, but struck out every place I looked. I was at the end of my rope so I decided to look in the yellow pages at the junkyard section. I called the first place that specializes in older car parts & they had a radiator in stock for $50 with exchange! Just got it home & fit it in the car. It needs cleaned off as it is quite dusty but that doesn't matter to me. I'm gonna clean the tank up since it is exposed & also run some water through it to make sure there is no crud in it that could cause a problem. It looks clean inside but I want to flush it out since it was sitting around for a long, long time. One more thing I like about it... It is an original Ford radiator. It has the insignia plain as day on the top tank, along with the part number. Now for that pesky gas tank!
