I need a 1976 hood
Date: 12/19/2016 06:02 pm
77 Cruising Wagon Front Seats
Date: 04/12/2017 12:37 pm
convert to stick
Date: 05/19/2018 09:26 pm
Date: 11/11/2019 04:49 pm
Front grill for '72
Date: 03/02/2022 12:09 pm
Date: 01/23/2023 02:22 pm
1975 Ford Pinto
Date: 01/13/2020 11:02 am
Hood Hinge rubber boots
Date: 09/28/2018 05:49 pm
Intake manifolds
Date: 03/06/2021 03:04 pm
  • Online today: 826
  • Guests: 595
  • Total: 595
1977 Pinto- project in the works
Started by r4pinto, April 07, 2008, 07:54:57 PM
I'm sure you'll be fine Matty. Just the same, happy head examining!
Matt, how long has the carb been sitting, a year? It might have some varnish built up in it.
Congrats on getting it running.
Her shocks are the originals from 1977 so I know they are shot. The exhaust is bottoming out because it is too low to the ground. I just have to adjust it to get it up higher.
Thanks for the kind words Becky, now off to get my head examind lol.
How are her shocks? If she's bottoming out her shocks probably are shot.  Anyway, good for you and Harold II!!! I had faith in you two!!! ;D
IT'S ALIVE!!!! ALIIIIIVVVEE!!! MUAHAHAHAHA!!!!!
Now that I am done with my frankenstein moment, it's true, the Pinto is alive once again. I blew out the fuel lines, installed a brand spankin new fuel filter, reinstalled the sending unit with new filter on the end, & put 5 gallons of fresh unleaded in her. She stumbled a bit at first but after the gas got to the carb she started up! Now she runs very, very rough at first but once I rev it a couple times she smoothes right out. I'm certain it's an adjustment that needs done with the carb.
I did see there was a little seepage at the carb at a cap on the left side near the fuel filter, so I am going to see if I can get that to stop leaking, otherwise it's off to the auto parts store to get a rebuild kit for one of my spares.
After I go get my head shrunk I am going to work on cleaning her up & out, so she looks better as she is sitting in the driveway.
Next thing planned for her after cleaning is to adjust the exhaust, as I bottom out everytime I hit a bump. I repaired a broken piece last year & think I just need to shorted the main pipe a little more to accomodate for the sleeve joining the two pieces together.
The work has started... Hook the battery up to the battery charger... Check. Disconnect the rubber hose from the fuel pump... Check. Find out why the dome light won't come on with the door open... Check & fixed.
Dummy me. The dome light problem was caused by the simplest of problems... The plug was disconnected from the switch. Plugged it in & she works. Now I am going to blow out the fuel lines, reconnect the line to the pump, & reinstall the sending unit, along with the replacement strainer I bought a year ago. We'll se if she runs good after that.
That's what is wierd... I have a radio that has power all the time since it is digital. With that I really don't understand why the battery still has a charge since there has been a drain on it.  Oh well, no complaints there lol.
Quote from: r4pinto on July 19, 2010, 08:49:57 PM
Went to the car yesterday but it was stormy to work on the car. It has been over a year since she has been started but the battery still holds a charge! Although drained I could still listen to the radio!
The headliner stitching is gone so I will need to fingure something out to get that rigged up for now.
Matt,
Your battery sounds like a couple of mine.  Neither my '72 Pinto nor my '83 F-150 have anything on them option-wise that would drain the battery.  The battery in my truck was installed new in March of 1998 and still starts under its own power, although it admittedly sounds a little weak during the Winter months!  lol
Well,
I got moved in & have been too busy to work on the car. That is going to change, hopefully in the morning. I am planning on getting some fresh gas, blowing out the fuel lines, reinstalling the sending unit, & evicting the bees from the outside mirrors.
Hopefully after tomorrow she will run. Gotta make sure I have the key to the Omni GLH, as she is parked behind the Pinto. Can't move the Pinto if I can't move the Omni.
It's alright Matt, we got hit hard with that same storm today. :(
Quote from: r4pinto on March 25, 2010, 10:41:13 PM
JuJu no good today  :( It rained all day long so I couldn't work on the car. We will see what happens soon.
That darned Becky... she sent you mechanical Ju-Ju without weather Ju-Ju (weather Ju-Ju never occurs to those California girls :lol:)
Here's some Ju-Ju from Virginia for mechanical prowess AND good weather!
I got you covered Matty... Good JuJu headed your way! C'mon Harold II!
Quote from: r4pinto on March 24, 2010, 10:02:45 PM
Wish me luck! tomorrow I will be working on getting her running, and this time stay running. We'll see what happens.
Best of luck, Matt!  I have faith in you AND in Harold II!
rctinker
1977 Crusin Wagon when I was 16
Update:
It has warmed up so on Thursday or Sunday I will be reinstalling the sending unit. I will also be blowing out the fuel lines, putting gas in her & seeing what happens. If all goes according to plan she will run soon.
Thanks Becky,
I expect her to be there as well. If all goes according to plan she will go to Carlisle the next two years! Going to blow out the fuel lines to make sure there is no rust (or water) hanging out in them.
Darn Dads! Sometimes when I straighten up a room or the garage I inadvertently do the same thing- to myself! That's why I avoid straightening up! lol.
Matty, Harold II's issues will work themselves out in time. As a Pinto Mom whose Baby is somewhat in the same boat- but with more issues I know how frustrating not having funds or not having- or finding- the essential part you need can be. All I can tell you is hang in there. You have to keep plugging away at her. I expect Harold II and yourself to be there at Carlisle in 2011. Don't despair. You'll find a way.  :)
Months have passed, and the car still sits without a sending unit in the tank. This week I plan on getting the sending unit back in the tank, provided I can find the ring to hold it in. Dad rearranged the whole garage, and now I know where none of my tools or parts are. More to come soon.
Matt,
The Harold II project is sounding better all the time!  Keep up the good work!
That's awesome Matt!!!!
Hope the carb adjustments do the trick and you have a confident driver!!!!  ;D
Well, I got the temporary patch job on the floor & also got the interior back in the car. It's been such a while that it looks wierd to have an interior in the car lol. I also installed the replacement seat belt on the passender side of the car. After that I took the car on a drive & she seemed to do alright. The carb does need some minor tuning so I'm gonna make the adjustments tomorrow. The choke doesn't want to set so I'm gonna get that taken care of. She did seem to do alright on the freeway but we'll see what happens tomorrow after the adjustments.
The carb I got off ebay arrived today so I ripped off the old one & bolted on the new one. At first the car seemed to have the same boging problem, but when I took her for a drive it shortly went away. I also adjusted the driver door so I could open it & close it with no problem. Tomorrow I am gonna bolt up the driver fender back on the car & also make sure the lights are working. I will also be patching the rear floor & reinstall the interior.
No more leaky engine!!! I installed a new oil pan gasket & that solved the problem. When I installed the old one it apparently slipped off inside the pan. That caused me to lose oil. No problem, all fixed.
I also took the car for a drive & noticed I could not get on the gas for anything. I am thinking it is because the carb is junk since even the previous owner had problems with it. I will be looking at it tomorrow after I get home from my uncles place. Fixing his brakes.
We'll see what I can find when I tear into the carb. At this point that is just about the only thing that is gonna prevent the car from driving to Mentor, Oh for the Pinto meet, and that will get fixed one way or another.
Got a little done to the car today..
It was supposed to rain so I didn't want to worry about the oil leak the car has. Instead I went ahead and worked on fixing little things that drove me crazy.
One thing I looked at was the key buzzer. It worked when I bought the car but not since. Found the buzzer itself is broken so I gotta get a replacement. The seat belt buzzer also didn't work so I tracked  down the connector & did some investigating using the 78 EVTM manual. On my car the light would work but not the buzzer. The book said to look for continuity at the seat belt buckle connector. I went to do that, only to find it was unplugged! I plugged in the connector & it worked. I also went ahead and tried to figure out why my washer pump would not work. I push the button & get nothing. It worked when I parked the car in 2007 so this puzzled me. I had an old washer pump pig tail so I used it to bypass the wiring & switch. The pump worked with no problem. I'm gonna investigate further tomorrow.
The blue kick panels I got from Phils Toys also went on the car. They look 100% better than the old, chipping nasty black ones that used to be green. Lastly, the radio. I bought a cheap radio from Pick N Pull over a month ago, and since I got the car running I went ahead and hooked it up. For a 13 dollar radio it actually sounds decent, although the LCD display for the channels keep flickering. It's only temporary until I can get the 8 track back in there, so I don't care too much. It's got a wood grain trim piece around it, so it actually goes with the scheme of the old interior. Tomorrow I plan on fixing the oil leak and the dome light. It woks when I turn the knob but not when I open the door.
Thanks
I was hoping to have a different carb on the car before my trip to Mentor, Oh in about a week but oh well, can't cry over spilled milk lol.
Hey!!!! Do you know how many things I haven't won on Ebay for my Pinto????  Anyway, I'm sure a new carb will come up soon, and you'll get a great deal.  Look forward to hearing about more of your progress.....Larry :police:
