Date: 03/14/2020 01:52 pm
6.6.75 carrier
Date: 02/14/2018 06:47 am
Date: 10/31/2018 12:00 pm
73 Caliper Retaining Key
Date: 10/28/2021 07:49 am
Automatic Wagon
Date: 06/14/2019 11:22 pm
Wanted 73 pinto squire wagon
Date: 05/09/2020 11:59 am
1978 Squire wagon 6 Cly
Date: 02/16/2020 05:42 pm
Pinto hubcap
Date: 01/07/2017 08:40 pm
Automatic Wagon
  • Online today: 548
  • Guests: 500
  • Total: 500
Ak Miller Turbo kit
Started by HighHooder, June 25, 2004, 01:14:34 PM
Quote from: HighHooder on February 08, 2010, 03:13:01 PM
yes Possum, I do still have this, in fact I'm probably going to sell off all my pinto stuff.. not reasonable offer turned down.
is the equipment as shown in your original posts so long ago?
what do you consider a reasonable offer?  i may be interested in some of the pieces (exhaust manifold only to be truthful).
HighHooder
Proud owner of a 1972 Ford Exploder
volksnut
Ain't nothing wrong with a draw through set-up...I would change the progressive stock carb though to a Holley 350(2 barrel) or a SU carb. I ran easy 13.8's with only 5 psi in my VW and it ran like a stocker til on boost.
Here's my old set-up (vintage Rajay turbo kit) with a 2" SU carb
And a Holley 350 cfm 2 barrel
possum
Hey high hooder, I was wondering what happened to that turbo exhaust manold you have pictured? I would like to purchase it if you still have it. possum43@suddenlink.net let me know thanks.
WVBobcat77
on a 2.3 you can pull the came out the front all you have to do is jack the front of the motor up to clear the radiator.
Bill in WV
1977 Bobcat
1978 Pinto - V6 Sedan
I think once you pull the retainer you can pull it either way. Brad? help me restore my fading memory LOL
bricker4864
Quote from: turbopinto72 on September 08, 2004, 07:17:12 PM
You can get 130-140 hp out of a N/A motor with a few tweeks. Cam, cam pulley, jet the carb, re-work the distrubtor and add a good ignition and header. Just my 2c.
I second that. I had 119 hp at the rear wheel with a cam a fuzz bigger than stock (.484 240* I think), a cam pulley, header, gutted offy intake, msd, and a 390 carb.
Went up to 121 with fuel injection last time I made a dyno run. I think I was making more than that after we tuned it more, but those were the last numbers I got.
If you figure 20% loss from flywheel to rear wheel, that's 143hp for the carb, 145hp for the injection.
Crazyhorse, you mention changing the cam without pulling the head. Doesn't the cam come out of the back of the head? I have always pulled it.
 6 lbs boost on an 8:1 motor will be worse than a banana up the tail pipe. Unless you run a VERY small turbo. Anything under 10 lbs and it will most likley be a bog fest. You can get 130-140 hp out of a N/A motor with a few tweeks. Cam, cam pulley, jet the carb, re-work the distrubtor and add a good ignition and header. Just my 2c.
Thanks for the quick reply Brad. I'm still trying to decide which route to go with my 2.3L. The long block has less than 30k mi on it so I'm thinking 6psi of boost on a 8:1 compression stock motor would be reliable. However, I'm looking to get just 130-140hp from the motor. At that level of HP I could get by with just a good carb/intake/cam/header setup on a n/a motor. A 42HP increase would be just shy of 50%. do you have any suggestions on how I can get  this without opening up my motor? I'm open to a cam change as the head doesn't really have to come off. but I'd rather not pull the head of a good running motor if I don't have to
 There are lots of blow thru set up's out there that work great. In the book " Maximum Boost" the writer swear's by the blow thru set up.
Ok Y'all have covered draw thru turbo setups (and thier lack of intercooling) how about a "Blow Thru" setup?
If I'm not mistaken this would lend itself well to intercooling as the pressurized air is forced thru the carb. BUT how do you keep the carb working? I understand Bernoulli's principle sucking fuel from the float bowl. However wouldn't boost slow the rate of fuel? To compensate you'd have to up the mixture to a point that it'd almost flood off boost.
I'm interested as I've found a cool lil IHI turbo that should make about 6psi of boost that would wake up my Lil' Horse without a major rebuild & investment in parts.
Yes, that would be a great project car. I know that that car is an original Huntington Ford Pangra Wagon ( very rare).
HighHooder
Quote from: turbopinto72 on August 26, 2004, 09:51:08 PM
This is a draw through set up I have on my Pangra. ...
Brad, is your exhaust manifold polished? chromed? or just brushed shiney??? ;D
HighHooder
This is a draw through set up I have on my Pangra. The carb sits on top of a plenum which is attached onto the compressor side of the turbo. The Air/Fuel mix runs through the turbo and over the top of the valve cover into the intake manifold.
bricker4864
I know absolutly nothing about turbos and only a little about roots blowers. Is drawthru carb on top or turbo first?
Priest
for me, i have some experience with EFI turbo setups.......tons of reading, have asked tons of questions, sat around Daves shop (I guy we call turbo Dave) and helped him out......and read even more.  all of it has been gear for EFI and the project i am working on.  I guess if i am going to say anything on carbed turbo setups, i need to stick to general engine work and wait for more experience with the carbed turbo.  At least you jumped in and pointed to where i was wrong so that he didnt start working on following my advice.  if you can point me to where i can read up on carbed turbo setups, i do need to learn them, a buddy of mine just picked up a '79 turbo cobra and i will probably end up working on it with him.
-Matt
Actually, this kind of dialog helps others. Keep asking questions......... :)
Priest
well...that shows that i dont know carbed turbo setups.......sorry for making myself look foolish.
 Matt, You can not intercool a drawthru type set up. The air/fuel mixture gets sucked thru the turbo and pushed over the cross pipe into the intake manifold. A cooler ( with all the cooling fins) would condinsate the gas and turn it back into a liquid form from the mixed ( gas/air) frorm that it comes out of the turbo. As far as the stock intake, there has been a LOT of testing on it and it is widley accepted as about as good as it can get.A plenum would be great if one was going to use a EFI system. I hope this helps.
Priest
i do have a few possible suggestions on improving efficiency in the pictured setup.  if you have a way to intercool the charge air at all, you will be able to throw more boost at the engine before you start pinging.  with an over valve cover setup, an SVO / turbocoupe type intercooler would work well if you can provide airflow over the cooler that does not draw hot air up from the engine.  my second thought is on the plenum, from my experience, reading, and observations, having a larger plenum area than you have before the runners seemes to help more on low end torque.  thats about it for now.  so.....do your thing, get it in the car and lets see how she does.
Matt
 Thanks Joel, I cound'nt have said it better. If I had more time yesterday and a way to post pictures on this new format I would have got real spacific on just how those engines work. So, now to answer the question. How fast?? well the 72 Pangra tested in the 70's ran a 15.6 ish 1/4  mile. I have not ran either of my cars but the box stock car could easly run that. My modifyed car will run in the 13's for sure. The head mods to my modified car is, a full port and polish, big stainless valves, custom crower cam with crower springs and rockers and an Esslinger cam pully. Waste Gate, good question. On ( some ) of the Pangras, they ran a type of waste gate that was basicly a restrictor, in line at the crossover tube. It worked by moving a mechancal cone shape valve that seated it self as the boost came up. It had holes in it to alow ( some ) fuel\air past it. It was about the most restricting thing you could ever do to your intake. Other units I have seen do not have any waste gate. I will not run a waste gate on my modified car becouse I have a realy cool ignition box with a 3 bar MAP sensor, boost retard, timing retard and timing lock out at start.  I will back timing out of it as the boost comes up and deal with it that way.
Poison Pinto
QuoteMy appologies to all offended.
I don't know as anyone was necessarily "offended," perhaps confused is a better description. You were going on the limited information presented on the engine (and I think you were approaching it as a stock Ford application), and others were confused as to why you would say the setup didn't work. I think it was simply a misunderstanding perpetuated by the fact the original, single, head-on photo didn't have the carb mounted and there were other changes from the stock 2.0L (ie remote oil filter application). I mean, your original assessment of the engine (an early turbo app like an MII) seems right on, but you were looking for a fuel intake source (carb or injection) and there wasn't one in the pic.
I just didn't want the discussion to escalate into something ugly and I could see where both sides of the discussion were basing their statements. Just thought I'd play impartial moderator for a sec and try to prevent hard feelings down the road.
HighHooder
you see,  I actually, originally built this motor for a 1953 CJ3-B JEEP
and then switched horses midstream, put a 3.8L Buick v6 in the JEEP and bought a 72 1.6L Pinto...
HighHooder
just some more pictures to make things REAL confusing ;D ;D ;D
samgcpo
Thanks, I appreciate the clarity.
~Sam
Poison Pinto
Uh oh...
Someone poked the bear.
To allay some apparent confusion:
Sam~ That's a 2.0L with an aftermarket AK Miller turbo kit. Thus, your argument about when *Ford* began manufacturing its turbos is irrelevant. Not sure what you mean by "false" turbo setup. It's not factory original, that's for sure, but the term "false" implies that it's a non-working mockup primarily for looks. The carburator issue seems clarified by HighHooder's follow-up post. The question you raise about the oil filter may simply be one of having a remote filter system applied. I don't know about that for sure since this isn't my engine (although I wish it were). Certainly it's a viable explanation, though.
Also if Brad (turbopinto72) says he has 2 just like it, there's no question in my mind that it is a functional system. From the several chats I've had with him, he's not the sort to perpetuate misinformation about the mechanics of the Pinto. It would undermine his authoritative duty as Master Mechanic and it's not in his nature.
I may be wrong about this next point, and if I am, Brad (among others) will certainly set me straight. In the Pangra article in the bric-a-brac section, Pangras (an aftermarket modification of the Pinto) had turbo units applied to their engines. And Pangras were being built before the 2.3L was introduced in the car. So it is entirely accurate for 2.0L turbo engines to be in Pintos (even though these would have been Pangras [EDIT: most probably would have been Pangras, I do believe there were other homespun turbo apps to standard Pintos]). However, these would not have been *Ford* turbos. That's how Brad can have *2* 2.0L turbos with such a setup, (at least) one being in a Pangra. As he said, check out his Pangra project. He has pictures of his engine there.
Huh, you say this Ak Miller setup wont work??  Im confused, why wont it work???
samgcpo
Well , finally a response a previously ignored post.   This interesting engine went for quite a while with no comment.  With only one picture angle of  this mystery engine, I feel that my original assesment would be correct.
Note to future posts.....Identify what you are are talking about.  There are many transverse engines that look simular to the earlier straight- fours that Ford used,  and give a thought to when the first turbocharged  engines were introduced.
Ford did not go turbo with the four cylinder engines until the later 70's.  The 2.0 is a very capable engine, and I would love to see a tubocharged version in action.
Now with that said, this setup, as shown in the pic,  will not work with the draw-through intake system as pictured.  You just can't go top-mount with the carb system.  Injected will work with the proper intake manifold, but the pictured engine requires a fuel injected system to work.  Which precludes the mechanical fuel pump that is pictured.
Physics is physics,  and turnip blood is not  easily produced.  Convince me that this is a bonified operational engine.
~Sam
HighHooder
Quote from: turbopinto72 on July 19, 2004, 03:17:27 PM
I have two of those 2.0 set up's. look at the 73 Pangra project.
so... how fast? what kind of head mods have you made?
also, one more thing... what about a wastegate?  my system has none, should it?
