Date: 07/30/2020 11:45 am
Date: 08/20/2017 01:34 pm
Date: 10/24/2019 01:43 pm
Misc pinto parts 71-73 2.0
Date: 05/05/2020 11:56 pm
Date: 01/23/2023 02:22 pm
1972 Pinto SCCA BS race car
Date: 10/23/2018 04:01 pm
1980 cruising wagon ralley
Date: 07/12/2019 01:41 pm
Date: 08/08/2017 01:44 pm
  • Online today: 600
  • Guests: 432
  • Total: 432
ThunderPinto gets a rear end job.
Started by High_Horse, February 10, 2008, 09:15:21 PM
Feast your eyes on a brand new set of leaf springs...These were hand built by the spring shop to Ford oem specs.......original springs have 5 leafs...notice the sixth leaf that extends over the front mount leaf and back to past the halfway point. Eliminates spring wind and the need for traction bars.
Spent most of this weekend  processing parts....meaning cleaning them coating them and meticulasly painting them. Here are pics of some rearend parts before they go into the oven after being anti-rust coated. It is very important to know the load raiting of ones oven rack before placing rearend parts into the oven.... ;D Her Highness_Horse asked what was cooking...I told her Hog Nose..... ;D
Yesterday I took the axles in to have the bearings removed...$50.00. I then went to the parts store and bought 2 axle seals, 1 pinion seal for the hog nose, 2 axle bearings, 2 rear brake cylinders, 2 springs kits and 2 star adjuster kits...180.00. Today I took my leaf springs in to have them duplicated...and with a special front spring addition to eliminate the need for traction bars. I am increasing the u-bolt diameter from 7/16 tp 1/2. A new set of stock shackles and all the stock rubber grommets...325.00. Nothing to take a picture of yet.
Hello HH,
Finally got to see some piccys!!! 8)
Do you have any of the posi unit???
apintonut
74 hatch soon to be turbo 2.3
73 sedan soon to be painted
stiletto parts(4 sale)
79 pinto wagon & beentoad
Well...I spent a little time in the garage tonight. I gave up trying to pull the bearings off the axles so I am going to take them to the axle shop tomorrow. I disassembled the limited slip tonight to see how it looks...and it looks good except I think I am going to use my gears instead of the ones that have been sitting for years...they are a bit crusty where mine are well broken in and smooth. I am also going to take the leaf springs in with the axles and see what I can do to put some beef to them. I am also thinking about fabbing a small rearend skirt to fit under the bumper to cover the gas tank look from the rear. Just throwing it out there. Pics to come.
Finally got my camera battery so now you guys can see what I am doing. The second and third pics show the rear bumper all the way out and all the way in.
Quote from: High_Horse on February 18, 2008, 05:42:59 PM
...Is there anyone with the pre-5mph big bumper...
If I am not mistaken, there is no such thing.  I am pretty sure the 5mph thing started in 73, the year BEFORE the 'big' bumper was installed.  I think you are breaking new ground here bud.  Just go with whatever looks good to you.  Also, from what I understand, there are a couple different types of the 'bumper shocks'.
I wirebrushed the heck out of the brake backing plates...they were in pretty good shape as I last did them in 92. Put them in the oven...dryed them out and coated with extend...tomorrow paint. They should last till there next redo in 2023.... ;D
Today I painted the rear end housing with 100% Stainless Steel 316 L Pigment... ;D...Cough. I also drilled bumper shocks out. They were filled with some kind of white fluffy styro-foam rubber stuff that was dry to the touch and was under pressure. The telescopic assembly retracted 2.5 inches leaving me with 3 inches to the flat that the bumper shroud screws to. Is there anyone with the pre-5mph big bumper that can give me the measurement from the bumper to the flat? (Wagon) I am compelled to move it in another inch so it hugs that body but am curious what the norm is. Yah Pintony...I was waiting for the oil and got Christmass tree snowed.
No camera battery yet...but I pulled the seals out of the rearend housing today and begun to proccess it. Took it down to the local spray and wash for degreasing...had the whole place to myself cause the winds were out of the north at 45 mph and it was a brisk 35 degrees. Whooow!  Got home and took the grinder and wire wheel to it...removed weld platter and ground weld hickeys down then wire wheeled the rust to a smooth finish...cough. Coated the housing with two coats of extend and will paint tomorrow.
You could start a thread called "P I N T O N Y gets a rear end job"
Long Island Ice tease on the Horse.
        High_Horse.
Quote from: douglasskemp on February 11, 2008, 11:33:16 PM
They did... :amazed: ...it's called ChevyLover's Anonymous, also known as 'Friends of Tony P'  :showback:
Hehehehehehe!!! Thats Funny!!!!!
Quote from: osiyo59 on February 11, 2008, 11:03:24 PM
I think we should create a forum called ASK PINTONY! ;D Youjust have an answer for everything! :read:
That is NOT true!!!
I do not have any V8 answers & very few Turbo-2.3 answers. :-\
osiyo59
1966 Mercury M100 Custom Cab 5.8L EFI/AOD
1973 Pinto Wagon Daily driver (For Sale in Classifieds)
1973 Pinto Squire 2.0EFI/Turbo
"Man is not FREE unless Government is LIMITED!" - President Ronald Reagan
BC92724
RAYBESTOS Professional Grade Brake Cable $35.17
Brake Cable; Rear ; 2 Per Car; Years: 1976-1979;Qty Per Vehicle:1;
F38604
WAGNER Parking Brake Cable $17.18
Brake Cable; Wgn ; Services Cables Up To 75 ; Fits Most Models; Years: 1975-1979;Qty Per Vehicle:1;
F38603
WAGNER Parking Brake Cable $19.90
Brake Cable; Wgn ; Services Cables Up To 120 ; Fits Most Models; Years: 1975-1979;Qty Per Vehicle:1;
F86389
WAGNER Parking Brake Cable $30.68
Ok....Tonight I ordered a camera battery first thing. 12 bucks ebay.
Removed the rear bumper and my trailer hitch...I would have done the drill thing but I had to get that flap out of there....removed the rear shocks which were Motocraft Sure Trackers...Heavy duty. I can't remember putting them in but they work like brand new. I think I am going to pull the tank.  OH YAH...Where can I get a new emegency brake cable setup..mine is rusted stiff.
Hey Mike,
Drill a 5/16 hole in the shock. Move the bumper in untill you are happy with the alingment and drill a 2nd hole through the first hole.
drill the hole to 3/8 and install bolt.
The first hole you drill will make oil squirt out so be carefull.
If killed in accident this post will be dis-avowed...
Post will self-destruct in 15 seconds....
From the ChevyLover
Alright....it is rearend time. I got an 8" limited slip carrier and this is a good time to give the rear suspension a good inspection,rejuvinating and painting. I spent the early part of the day pulling everything out...left the shocks hanging though because I had to clean the piles of rust dust and gear oil mixture and didn't want to lay in that and unbolt the buggers. I fail to have pics at this point cause my camera bat is dead and I need a new one. I will commence with photos as soon as bat arrives.
Two questions....When I was looking at my rear end from the side still setting on the leafs I noticed that the carrier opening seems to aim upward a bit. When I pulled the rear end out it is clear that the carrier opening and leaf mounting flats( or what ever they are called) are not 90 degrees apart. Is this normal or wasn't my rearend mounted in the jig right when they welded them on at the factory?
Also...Has anyone removed the rear 5 mph bumper mounts and mounted the bumper closer to the body like on the older cars instead of having it stick out so far? It looks like it would fit ok closer?
