1971 Pinto 5.0L
Date: 12/02/2017 12:23 am
Crane Cam
Date: 02/26/2018 07:50 am
Date: 03/07/2017 07:03 pm
78 pinto wagon
Date: 03/03/2020 01:07 pm
Date: 05/03/2024 05:37 am
Date: 12/09/2018 06:59 am
Date: 08/17/2022 06:27 pm
72 PINTO WAGON
Date: 09/23/2018 06:16 pm
78 hatchback
Date: 03/12/2023 06:50 pm
  • Online today: 529
  • Guests: 464
  • Total: 464
Harmonic Balancer Torque Spec?
Started by QCPRC, January 24, 2008, 08:29:36 AM
You got that right, just the BIG bolt at those numbers. The pulley should be less than 37-40 ft lbs.
QCPRC
Thanks a lot.  That spec seems kind of high for the 4 pulley assembly bolts but I'll take it for the Balancer bolt.  :)
 Greetings again,
  Confirmed on those torque specs in Chilton, with  footnote saying "crankshaft damper bolt".  92- 103 ft- lbs
Greetings,
My Clymer manual says " tighten the crankshaft pulley bolt  to 92-103 ft-pounds" for the V6. It does not mention the Harmonic balancer by name.
I'll check my Haynes or Chilton for confirmation.
QCPRC
I need the torque spec for the Harmonic Balancer for the 2.8L  1975.
Thanks,
