Date: 08/26/2018 06:23 pm
Date: 03/05/2017 03:27 pm
Date: 12/04/2018 07:40 pm
Date: 08/06/2021 02:23 pm
Date: 01/23/2023 02:22 pm
77 Caliper Bolt
Date: 08/21/2018 04:02 pm
Date: 02/05/2017 09:45 am
Front sump oil pan
Date: 01/02/2017 06:54 pm
Rare parts for sale
Date: 09/10/2018 08:38 am
  • Online today: 536
  • Guests: 334
  • Total: 334
what transmission do i have?
Started by Trent, January 17, 2008, 01:48:38 PM
Quote from: krazi on January 19, 2008, 02:47:07 PM
if the trans oil pan has 11 bolts, its a c4. if it has 13 or so, its a c3. or is it the other way around?
You were correct the first time.
I don't think he stated if it's an auto or manual.....
krazi
yeah, I'm Krazi!
I think Tony meant to say the code for a C3 is " V " not  "W". The codes for a manual trans are " 5 " or " E "
Quote from: Trent on January 17, 2008, 01:48:38 PM
I have a 1980 ford pinto pony. it needs transmission work as i believe it has lost 1st and second gear.
need to know what kind of transmission i have, and what would be the cheapest solution to fix it?
Hello Trent,
Look on your drivers door  body near the striker post there should be a sticker.
Where the sticker says TRANS. there should be a letter.
IF the letter is W then you have a C4 automatic and if your letter V you have a C3 tranny.
Not sure what the letter is for a Manual trans But is considered the Hummer 4spd.
Find a suitable replacement from the breakers yard is my advise...
IIRC the 4spd in the Pinto carries the designation SROD.
dave1957
I have the one out of my 79. Shifter is a bit worn you can have it if you want it located in wyo zip 82601
1979 bobcat
1974 red stinkbug
Trent
Trent
