windshield
Date: 04/14/2018 08:53 pm
Cruiser Dash Gauges
Date: 12/04/2016 11:50 am
74 Wagon Interior
Date: 01/22/2017 06:38 pm
Deluxe Steering Wheel
Date: 10/16/2017 08:13 am
Date: 01/21/2023 04:19 pm
Date: 11/11/2019 03:38 pm
Date: 01/24/2021 07:54 pm
WANTED Hood Prop Rod
Date: 01/17/2017 02:47 pm
Date: 08/24/2018 02:50 pm
  • Online today: 536
  • Guests: 351
  • Total: 351
what transmission do i have?
Started by Trent, January 17, 2008, 01:48:38 PM
Quote from: krazi on January 19, 2008, 02:47:07 PM
if the trans oil pan has 11 bolts, its a c4. if it has 13 or so, its a c3. or is it the other way around?
You were correct the first time.
I don't think he stated if it's an auto or manual.....
krazi
yeah, I'm Krazi!
I think Tony meant to say the code for a C3 is " V " not  "W". The codes for a manual trans are " 5 " or " E "
Quote from: Trent on January 17, 2008, 01:48:38 PM
I have a 1980 ford pinto pony. it needs transmission work as i believe it has lost 1st and second gear.
need to know what kind of transmission i have, and what would be the cheapest solution to fix it?
Thanks
Hello Trent,
Look on your drivers door  body near the striker post there should be a sticker.
Where the sticker says TRANS. there should be a letter.
IF the letter is W then you have a C4 automatic and if your letter V you have a C3 tranny.
Not sure what the letter is for a Manual trans But is considered the Hummer 4spd.
Find a suitable replacement from the breakers yard is my advise...
IIRC the 4spd in the Pinto carries the designation SROD.
dave1957
I have the one out of my 79. Shifter is a bit worn you can have it if you want it located in wyo zip 82601
1979 bobcat
1974 red stinkbug
Trent
Thanks
Trent
