Wanted 73 pinto squire wagon
Date: 05/09/2020 11:59 am
Looking for front seats
Date: 08/10/2021 09:54 pm
Date: 03/13/2021 12:57 pm
1980 PINTO for sale
Date: 06/19/2017 02:51 pm
Date: 12/26/2016 04:29 pm
upholstery for bucket seats
Date: 10/30/2018 08:44 am
Date: 10/31/2018 12:04 pm
$300 Pinto for sale
Date: 04/19/2017 10:24 am
Racing seats
Date: 10/24/2019 09:41 pm
  • Online today: 531
  • Guests: 131
  • Total: 131
Radio installation question
Started by r4pinto, January 01, 2008, 09:36:54 PM
It actually looks similar. I've done the ash tray already so I'll get a pic posted of how it turned out in semi gloss black.
For my stock radio I used some matte clear coat in light coats and it turned out great. How bright does semi-gloss make the paint?
I ended up trimming the opening. It didn't turn out too bad. I'm gonna give the radio trim a fresh coat of semi gloss black then bolt it back in the car.
Thanks for the help guys.
So you are right. I have the same brochure so I was able to look at it. Only thing I can think of is that the 77 Pinto did not have an am fm 8 track as an option, but only the am fm radio or an am 8 track.
Dunno, still looking at my options before I  cut up the radio trim panel.
losin sux
Matt, I have a copy of the 77 sales brochure and in that is a pic of the radio.  Aeronutronics is actually silkscreened on the dial.
77 HB 2.3 C3 3.40
Interesting. I'd hate to trim teh bezel, but it looks like that's what I'm gonna have to do. I doubt I'm gonna be able to find an am/fm 8 track made for a Pinto
billnall
D5SA-19A168-AD appears to be a t-bird radio. I was looking at the Ford parts catalog and looks like Pinto had radios that were unique to Pinto only. But all the other Fords interchange between each other. So according to that looks like we have special cars.
Ford Parts Man
Well, I didn't have any problems with depth. The radio was sitting in the dash before, I just don't have a way to fasten it to the dash, or to the radio bezel.
lugnut
I tried to do this swap a couple of years ago and gave up.  The AM-FM 8 track i had came out of a 78 t-bird.  My Cruising wagon came with the factory AM (only) 8 Track.  Aside from the shaft length issue, the radio with FM too is too deep I believe.  If you look at the sales brochure in 1978, the radio options that they list are AM, AM-FM Stereo, and AM-8 Track.  Like I said, I gave up on it, which is a shame cuz I have a big collection of 8 Track tapes, and several players.  I'm going by memory here, but there was something in the way behind the radio.
The part that shows to the tip is about 2 3/16" long.
Thanks for the compliments on the radio. Not too bad for $10, and it even works.
As I understand it, the Philco brand was used from 68 till the early to mid 70's.  My 73 sport accent parts car came with a mint Philco AM-FM stereo from the factory.  I have seen the same radio go for big bucks on Ebay.  I have never seen a Philco Radio like yours though, nice find.  The ones I have seen were Aeronutronic Ford.  I pulled a few AM-FM 8-tracks out of some full size Lincolns and Galaxies but I have not paid much mind to the shaft lengths.  I sold my last one early last summer so I am not able to measure it for you.  Just for grins, please post the shaft length of your radio.
There is an Aeronutronic Ford sticker with a model number. It is
6L-D5SA-19A168-AD.   There's also a Philco-Ford Corporation inspection sticker on it, but the only numbers I see on it are patent numbers.
billnall
I would think that is the correct one because the part number for am/fm/tape bezel is D6FZ18842B although there are not enough numbers to cross to a part# just going by the D6  B.
Perhaps the radio is a different year are there any labels on the radio with numbers?
Ford Parts Man
losin sux
I thought that Aeronutronics made the radios for the late 70's model Pinto.  I was pretty stoked to see you found the seldom seen AM/FM 8 track but then I saw it was the Philco version.  With that said the manufacturers difference tween the two might be why yours don't fit.  I will have to keep that in mind as I am still looking for one with a working 8 track.
Steve
77 HB 2.3 C3 3.40
From left to right as they appear on the backside:
D6EF                         18A02     BWA      CAV. 1
The big spaces I put in were present in between the numbers on the back of the bezel.
Thanks for any help you're able to give.
billnall
There are a total of 5 different radio bezels from 71-80.
Are there any numbers on the bezel?
If so I will try to help you.
Ford Parts Man
How can I tell the difference on the bezels? When I got it I ws under the impression it was for use with fm tape.
billnall
There are at least 2 different radio mounting bezels.
1 for radio w/tape player and a diffferent one for without tape.
It looks like the picture on this threat is a non tape bezel.
You have 2 options, cut the center hole larger or get a bezel for a am/fm/tape radio.
Ford Parts Man
I couldn't really tell you what it came out of since I got it at the Ford swap meet at the Ohio Expo Center November 06. The knobs were fine, it's the shafts that are too short for me to bolt the radio to the front trim plate. Do the shafts actually come in differnt lengths?
Is that 8track out of a Pinto? or just a Ford?
Not all Ford radios are the same.  I found this out the hard way when I went looking for repair parts for the AM pushbutton in my 69 F100.  I tried using a volume knob out of a radio from an Econoline van of the same vintage.  Wouldn't you know it, the knobs are SHORTER by about an inch!  So now I have a couple older E series radios sitting in my dad's shed in AZ and can't use 'em.  I know there are a few Econophiles in here, they would get dibs, but the radios are lost in dusty bliss for now.
You could try Ace Hardware, they always have odds and ends like that.
hmmm... looks like I might just be keeping an eye out for them at the junkyard. It's been a few days since I gone to the junkyard so they might have some older Fords in there.
Since Ford went to the single din in about '85 I kinda doubt they still MFG the parts. If you have an OLD Ford dealer nearby, they MIGHT have them as NOS.
Hmmm.... I'll see where I might be able to find some countersunk nuts for the radio. Do you know if they might still be available through ford or if they're obsolete?
IIRC ford had some countersunk nuts to attach the radio. In your situation, I'm not too sure what to do, other than try to find these.
You COULD open the hole so the face-plate of the radio comes through the panel. You can use extra washers and nuts to get the best spacing.
Keep in mind that if your radio panel is plastic, DON'T over tighten the nuts.
I did remove the small piece of aluminum & it made no difference to it.
Yep, it sure was. I took a couple pics of the trim around the radio.
Is the face of the radio flat against the inside of the bezel? If not and the knobs don't reach, there should be a spacer (small piece of aluminum tubing) between the radio and the bezel which you could trim shorter, or maybe even go without it.
What if the shafts are too short for the radio trim? The Ford radio I have fits the trim, but the shafts don't stick out enough to thread nuts on. I'll try to get a pic of what I'm trying to refer to.
