1971 2 lt Cam
Date: 10/10/2020 06:27 pm
Date: 02/03/2018 11:28 am
$300 Pinto for sale
Date: 04/19/2017 10:24 am
1970-1973 Gas Tank/Blue Dash
Date: 02/07/2019 11:57 pm
1971 Pinto 5.0L
Date: 12/02/2017 12:23 am
WANTED Hood Prop Rod
Date: 01/17/2017 02:47 pm
Date: 09/03/2018 08:58 am
Date: 11/05/2020 06:32 pm
2.8 Engine mount brackets
Date: 12/28/2016 11:42 am
  • Online today: 2,457
  • Guests: 560
  • Total: 560
Radio installation question
Started by r4pinto, January 01, 2008, 09:36:54 PM
The radio is mounted to the bezel by the radio control shafts (volume and tuning knobs). If you pull the chrome knobs off, you will see a small nut that goes around the base of the shaft. This is what holes the radio to the bezel. After removing these you can take the radio off the bezel. Deep sockets work best for getting to the nuts but sometimes they are still to shallow. Otherwise use a set of long needle nose pliers.
So the trim doesn't need to bolt to the radio? It has never been fastened in there properly so I'll fabricate some type of bracket for the rear of the radio since I can't seem to find any old Fords in the junkyards.
Quote from: dave1987 on January 02, 2008, 02:11:13 PM
...There are two more identical holes on the bottom of the trim on the bottom of the bezel face, right in front of the center console...
You might have to remove the console to get to them.
Okay. If you look up towards the ceiling at the bracket, there are two screw holes right above the volume and tuner knobs, they use coarse self threading screws.
Last but not least, there should be a bracket on the radio or a bracket left in the car that is connected to the inside of the dash. There is a mounting hole on the radio that screws to this bracket and holes it still. It should be located dead center on the rear of the AM/FM radio. If you do not have the bracket, you could manufacture something out of a small section of sheet metal or go hunting around at salvage yards.
Hey guys, I'm just trying to get some questions answered before I forget them again. Anyways, last year I got the am/fm radio trim off ebay and am trying to figure out how to fasten the radio to both the panel & the car. When I bought the car it did not have a factory radio in it, but some $20 pos with no brackets at all. I got a 77 Pinto & am trying to get my am/fm 8 track radio to stay in the dash.
I found a pic of my car when I had a different radio in it, with the radio trim I'm referring to. If anyone has any info on what I need to do to mount the radio in my car I would greatly appreciate it.
