1980 Pinto w/ Trunk
Date: 08/10/2022 04:09 pm
Date: 06/24/2020 06:12 am
Seeking 1971-1973 Rotors
Date: 04/08/2021 12:23 pm
sport steering wheeel
Date: 10/01/2020 10:58 pm
Need 72 pinto parts!
Date: 06/14/2019 01:40 pm
Date: 11/14/2019 04:02 am
Date: 03/25/2019 09:02 pm
Date: 02/27/2017 10:10 pm
Date: 07/30/2020 11:45 am
  • Online today: 899
  • Guests: 525
  • Total: 525
Body parts interchange?
Started by wedge446, December 14, 2007, 07:25:26 PM
coyvan
I have a fiber glass rear hatch that will fit.  $100.00, located in middle Tennessee
They are right about the door frames being different.  It is my understanding that the rear of the window frames are bigger due to different shape of the body.
As for mounting older parts to your car, well anything is possible but realistically it will take a lot of doing to make it look right.
But having said that, it is your car so do what makes you happy.
Quote from: wedge446 on December 14, 2007, 10:08:11 PM
Window frames are diff... Can they be changed ease?
I`m also looking at some fiberglass bumpers for a 72, is it hard to mount them on a 75?
I would think you would need to know if a stock frame or a custom one is used in the F/G door and go from there. The frames don't seem to be easily removed from a stock door.
The problems you have with the early bumpers will be is that you will need the front and rear valence panels to fill the voids under the bumpers, and the radiatior support will get in the way of the front valence panel. One other thing; the gas tank will hang down below the rear valence and look odd.
wedge446
The sheetmetal, from the doors forward. HOWEVER, the window frames are different on the wagons.
wedge446
Yes,I`m still learning about the pinto... I`m trying to lighten up my 75 wagon and was thinking of fiberglass body parts but all I`ve found is for a hatch or trunk models.. Nothing listed for the wagon..
What will fit between the hatch/trunk car and wagons.
