Date: 02/16/2019 10:46 am
Date: 01/20/2018 07:51 pm
Need Interior Panels
Date: 07/09/2018 04:59 pm
1971-1975 Pinto
Date: 01/09/2017 04:14 pm
Date: 08/09/2018 11:09 am
Date: 01/06/2017 11:42 pm
Date: 03/06/2017 01:24 am
78 pinto wagon
Date: 03/03/2020 01:07 pm
1977 Pinto for parts
Date: 10/10/2018 06:25 pm
  • Online today: 531
  • Guests: 434
  • Total: 434
Body parts interchange?
Started by wedge446, December 14, 2007, 07:25:26 PM
coyvan
I have a fiber glass rear hatch that will fit.  $100.00, located in middle Tennessee
They are right about the door frames being different.  It is my understanding that the rear of the window frames are bigger due to different shape of the body.
As for mounting older parts to your car, well anything is possible but realistically it will take a lot of doing to make it look right.
But having said that, it is your car so do what makes you happy.
Quote from: wedge446 on December 14, 2007, 10:08:11 PM
Window frames are diff... Can they be changed ease?
I`m also looking at some fiberglass bumpers for a 72, is it hard to mount them on a 75?
I would think you would need to know if a stock frame or a custom one is used in the F/G door and go from there. The frames don't seem to be easily removed from a stock door.
The problems you have with the early bumpers will be is that you will need the front and rear valence panels to fill the voids under the bumpers, and the radiatior support will get in the way of the front valence panel. One other thing; the gas tank will hang down below the rear valence and look odd.
wedge446
The sheetmetal, from the doors forward. HOWEVER, the window frames are different on the wagons.
wedge446
Yes,I`m still learning about the pinto... I`m trying to lighten up my 75 wagon and was thinking of fiberglass body parts but all I`ve found is for a hatch or trunk models.. Nothing listed for the wagon..
What will fit between the hatch/trunk car and wagons.
