Wanted early pinto
Date: 10/03/2019 02:42 pm
Date: 02/18/2017 04:44 pm
Date: 04/07/2021 06:12 pm
Date: 03/29/2019 07:20 am
Date: 10/24/2019 01:45 pm
Electrical
Date: 03/29/2017 11:37 am
1980 Pinto Pony for sale
Date: 08/21/2021 03:54 pm
Date: 02/11/2020 12:09 am
upholstery for bucket seats
Date: 10/30/2018 08:44 am
  • Online today: 535
73 Pinto Runabout Project
Started by Cookieboy, November 28, 2006, 07:57:20 PM
I'm not a big fan of red... I like brown, green, earthy colors. But I LIKE IT! on the Pinto.
He got the origional paint code off the door... man is that one nice, bright, shiny color of red. Surprising as there is a lot of orange mixed in.
SHINEY!!!!
How do you like the color???
freshly painted engine compartment... ready for the motor  ;D
Thanks High_Horse,  stopped by this morning and got a pic of the new/repaired battery tray. Later he called to let me know the engine compartment has been painted for the motor to go back in. I hope to stop by tomorrow to see and take more pictures. I'll post em' as I get em'  ;D
CookieBoy,
           That's the way I like to see it. Work in progress. Looking good. By the way!!! Good pictures!!!
        The Picture Police
Time for more updates... I have been out of town and with the holidays been about 2 weeks since I checked in w/the body guy. All the new metal has been instaled, carpet removed, glass removed and now time for the rebuilt motor to be installed. If I understood correctly he has some body work and prep under the hood to do before the motor gets reinstalled. Once the motor is in then final body work and paint. He's still thinking it will be finished towards the end of January then I'll get to bring it home to do the interior work. Floor looks real good with a few holes to fix from the non-stock seats that have been installed over the years and one small rust hole was found on the driver side floor... not bad but will be fixed. All in all I was impressed with how good the floor looked. So far the only bad thing that happened was during the removal of the windshield the glass cracked and broke (I'm just not having any luck with glass) but a new one has been aquired and it even has tint on the top  ;D which I wanted anyhow. I have most if not all of the interior parts here at home to cleanup, still need to order the carpet and the dash pad still needs to go to the upholstery shop for a new skin but it's all coming together nicely.
and here's a few pics I took today...
Was a good surprise.... he's working on a T-bird restore right now and only works on mine between other steps on the T-bird. He pulled the engine after priming the T-bird for example. The privious owner of the shop, who is unable to work full-time due to health reasons, still likes to help when he can and has actually been helping w/the Pinto quite a bit and cut the quarters off. I didn't expect any work done until next week sometime so it was a welcome surprise  ;D
Hope that it's a nice surprise instead of a nasty surprise!  :o
Anyway, I have a feeling that the lower doors, the windshield, the front half of the floor boards, and everything foward are the same in sedans and wagons. It's just that everything aft is way different.
Finished up my front speaker install yesterday. Will add to that thread when I'm back down in Omaha.
I'm not sure what a wagon looks like when stripped like this but I'll tell it was shocking to see mine like this.. kinda naked..
He told me I would be surprised when I came to see it today.
Those things are sure built a lot differently behind the doors than the wagons, aren't they?
Hey Brian,
Have been trying to get hold of you about thos parts.
Give me a ring.
What is the body guy going to do about the rust in the innner fenders?
From pintony
more updates... no more quarter panels
Tony, not sure what you want me to tell ya. I'm not the body man he is, I did ask around and he is the one most recommended in this area so I will have to trust his judgement in this. He knows what I want and I can only hope it turns out like I plan.
Hey Cookieboy,
That is what I amsaying Y was the blasting done with the battery tray installed?
Y was it done with the master cylinder in place???
Those are the worst areas to deal with when re-painting under the bonnet.
I wet sanded my Purple Pinto engine bay in under 2hrs after I welded my battery pannel in and got it smoothed with fiberglass. The 2 hrs included removal of the wiring harness and all items on the firewall and innerfenders.
Tony, all clutch parts will be replaced as well as the master cylinder and battery tray. From the looks of it he did cover the front of the tranny as there is no sand in there I could see. I think he was in a hurry as it was almost 40 here this weekend and if he didn't do it now it would be back down to 10 below like it was in the middle of the week. He does the sand blasing outside and this time of year you don't get 40 degree days around here.
I think for thoes who don't like the idea of sandblasting... I see your point, sand is everywhere. But let's keep in mind... I'm not doing this in my back yard with unlimited time to hand sand everthing. I pay him by the hour and he has a lot of work to do.. rebuilding my motor, lot of new parts under the hood, lot of suspension and brake work, all new metal for the rear end, body work and paint entire car inside and out plus the underside of the car. Then when he's done I will need a custom exhaust, front end aligned and new tires. I still have interior work that will need to be done elsewhere, Stereo installed, windows tinted, etc, etc, etc.. There are a LOT! of dollars going into this "little" project. If I saved $$$$ and he saved a week or more in labor doing what he did... I would have given the OK to sand blast.
 :wow:
Y did your bodyguy blast the cowl and engine bay W/O removing the harness and windshield +W/S TRIM
The sand in your throwout bearing and your charcol canister??? + he blasted with the master cylinder and battery tray installed???
SHAKING MY HEAD!!!!! :hypno:
couple more pictures
Fcanon, he couldn't find a part # on the water pump but once it is removed from the motor he will check again.
Sand Blasting - To late to ask.. weather was nice this weekend so he pulled it outside on Saturday and did it. He agrees that sand will be everywhere but unless I have a bottomless wallet I really didn't want hime to take the time to sand it all down by hand. Also said sandblasting helps to show defects that hand sanding will not... anyhow, nothing to be done about it now.
He'll be finishing the Tbird he's working on this week and then it should be time for the Pinto.
fine.. I'll ask him about it tomorrow, I have to drop off some parts anyhow.
and.. I'll try to get that part # for the water pump
73pintogeek
Hey Brian,
I have to agree with Tony on this...if nothing else use a hot pressure washer for the hard to reach spot`s...just my 2 cent`s from an ol` fart that`s been there and done it and learned the hard way...
A one up for Tony!
Rex
A bad day workin` on my Pinto is better than a good day at work!
Hey Brian,
That is the problem if it is just a small area? The sand is still everywhere.
You will be getting sand from the fresh AIR VENTS FOR THE NEXT 30 YEARS.
Unless I plan to blast the entire car I will never use sand again.
How about a wire brush and some METAL-PREP???
Hey Tony, de-grease is done and he did show me a couple areas he wanted to hit w/the blaster. Didn't sound like at the time he was gonna do much blasting, just a couple small areas and some repair will be required for the battery tray.
Hey Brian,
Unless there is a REAL need to sandblast the engine bay??
Your best bet is to spend the time to de-grease it and wet-sand the entire bay with 220 grit paper.
Using lots of dawn DWL and hot water.
You will NEVER get all that sand out...
BTDT
Hey Joecool, long time no see... I can't wait either. So far all looks good w/engine, head was sent out and returned w/a clean bill of health. Didn't even need to be shaved. He's finishing up with another restore and will start in earnest on mine soon. Just got the last pieces need for the motor rebuild so will be bringing that to him on Monday and I should be able to get an update on the time table. First step is to get the engine compartment sand blasted and fresh paint. Then motor will go back in so it will move under it's own power again. Then body work and paint and the interior last.
I can't wait so I found another project to work on for now, more on this later and in a different post  ;D
Fcanon... I didn't forget. Just haven't been out to see the car and get the part # off that aluminium water pump yet
joecool85
Can't wait to see this thing come together.
Life is what you make it.
http://www.thatraymond.com
If that water pump is Aluminium get the part numbers off it I would love to cross referance it....that would be great....the water pump is only as good as its internals...
Frank
www.PintoWorks.com
Thanks Brad....
Tony, I got the distributor off ebay... ain't it cool  8) and I noticed the water pump looked different than the one on the motor, even commented on it to the body guy. Do you think I should have him reuse it vs. the one that was on the block I got from you?
and don't worry... this shop has been around for sometime w/a great reputation. For a project like this I asked around and this was the only place to consider. I wasn't interested in cheap... I wanted the best and he's it for this area.
SOME ADVICE!!!
I do not know how much you gave that shop for a deposit???
BUT Do not give 1 more dime untill the car is finished.
I will never UP anything to a bodyshop again.
Hey Brian,
It is NOT everyday that you see a transparent dist cap for a Pinto 2.0.
I do not think I have ever had an Alumunum water pump for the 2.0 either???
