1980 Pinto Wagon
Date: 02/29/2020 07:01 pm
KYB shocks
Date: 02/08/2017 07:09 pm
Wanted early pinto
Date: 10/03/2019 02:42 pm
74 Wagon Interior
Date: 01/22/2017 06:38 pm
Date: 08/02/2019 04:18 pm
1971 2.0 valve cover
Date: 01/25/2019 07:09 pm
Lower Alternator bracket
Date: 08/26/2017 05:11 pm
71 72 front bumper brackets
Date: 06/10/2020 10:55 am
80 pinto original
Date: 08/04/2019 10:45 am
  • Online today: 238
  • Guests: 423
  • Total: 423
Twin turbo 383w build (two 1/4 mile videos added sept 15th 2010)
Started by 78pinto, September 24, 2006, 10:38:22 PM
Original74
Let me be the first to congratulate you Jeff! We need audio! LOL. You know, I felt a little rumble and heard some whistling a couple of hours ago, must have been the beast firing up!
Dave
Dave Herbeck- Missing from us... He will always be with us
1974 Sedan, 'Geraldine', 45,000 miles, orange and white, show car.
1976 Runabout, project.
1979 Sedan, 'Jade', 429 miles, show car, really needs to be in a museum. I am building him one!
1979 Runabout, light blue, 39,000 miles, daily driver
tonight at 10 pm the Pinto fired up for the first time! Need to set the timing...deal with some small exhaust leaks...yada yada all the little things...but it runs!!
just what i thought, i had water pump issues. The pump and timimng cover didn't match up, leaked like a sive.  All fixed up now but i'm having trouble with spark or lack there of. MSD or coil....i'm testing today.
positively think positive thoughts....whew.  i know what you're going through....it seems that you have obviously thought things through...is there anyone you know that can take a look at the situation from an uninvolved viewpoint?  sometimes someone who is totally distanced from the project will look at things from a different perspective...and "see" things that may have slipped by you
turbowagonman
Quote from: 78pinto on July 12, 2007, 08:52:51 AM
thanks guys! srt, i like what you said....however i'm sure it'll be more like this!
I can hear it now....the starter grinds (not shimmed proper) the motor backfires (plug wires in wrong order) a low rumble the revs build while the exhaust gaskets start to leak filling the air with unburnt fuel....the turbines begin to spool up....apparent by the sounds of the impellers scrapping the compressor housings...the sound is worse than that of nails down a chalkboard, i stand there, listening...mesmerized by the sight of pooling oil as i relize i forgot to hook up the oil lines to the turbos.
I like your description much better! Lets go with that one. Dave, i'll get it all on cam if posible and post it to streetfire.net
LMFAO!!!!!
That's so good, unfortunatly I know the feeling of just envisioning the worse.
turbowagonman
Quote from: Original74 on July 12, 2007, 07:39:52 AM
Hey Jeff,
Can we get a conference call going and you just set the phone down close to the car while you fire it up for the first time? How about a webcam? Technology and twisted minds, scary! Testosterone!
We are so rooting for you man. Good luck and be safe.
Dave
that would be cool
Original74
Hey Jeff,
Dave
I can hear it now....the starter whines....the motor caches, alow rumble then the revs build while the unburned fuel makes its way out of the system...the turbines begin to spool up and the sound that emanates from them is better than sex as the revs climb while you stand there and listen..mesmerized...and looking for leaks!
turbowagonman
last two. It has three 10 inch fans (a real bugger to fit) two behind the rad and one down infront of the intercooler.
more
thanks guys!  A few pictures to post in it's near final form. The pipes off the mufflers are a bit too low for my liking, i'll losen off the clamps and turn them up a bit more so they don't hang so much.
pintojoeII
Quote from: 78pinto on July 10, 2007, 04:34:00 PM
Today i turned on the battery for the first time....no smoke...no flames, all is good in my world! ;D  With the exception of the headlights and turn signals, everything works.  Didn't get a chance to look for the problem but i'll get to it.  I'd like to start it on Friday...i should be set to go!
wish you luck this weekend
71hotrodpinto
Hey i can relate. I re-did about 40% of the wireing and added another 25% with electric this and that, relays, fuse board, and even after checking and double,triple,quadruple checking when i hooked up the battery, i cringed. The next cringe was when i started adding fuses and checking each circuit. then one of the last tests, cranking her over, WHEW!! that was a pucker factor of 10.
Glad you had no Smoking Issues.
Hope you get the headlights and such worked out.
B303,1.7 Rockers,beehives
'68 port/polish heads
Coated Must II headers
Edelbrock Airgap
Holley570,Msd dist,CraneHI6
Mil
Quote from: pinto_351 on July 02, 2007, 09:32:16 AM
The ford motorsports water pump does save alot of room but you have to buy a special pulley set to go with it.  Ford racing doesnt sell the kit anymore but they give you a guys number who bought out all ford had.  I just got done installing the water pump and pulleys on my car.  If i remember right it saves an inch and three quarters.
already have the motorsport short pump and pullies....it was about 1/2 an inch between the pump snout and rad before!
Yea i though i had it figured out too! I'm going to buy two 9inch Spal fans as pullers (behind rad) and one 10 inch infront of the intercooler for the lower part of the rad as a pusher.  I got the clearance to just over two inches from the pulleys, the fans will be side by side closet to the top with the 10inch pusher infront blowing through the lower portion of the rad. The fans widest (at the motors) is 2.05 inches....i should be golden.
pinto_351
pintojoeII
Quote from: 78pinto on June 30, 2007, 05:06:15 PM
i've pretty much got it ready, a few minor things to button up before firing.  My latest dilema....fan clearance, i'm at 1 3/4 inch between the rad and the water pump snout.  The lowest profile fan i can find is a Spal, and it measures out at 2.05 inches deep so i'm looking for a bit more room. It's a Pinto with a V8 and twin turbos....even .3 of an inch is hard to come by!!  Fret not Pinto peoples, i'll "get er done"!
ford motorsports has a short waterpump and pulley setup for the streetrod guys .if i remember right its 3/4 or 1 inch shorter.
71hotrodpinto
could you do two small fans diagonally to miss the water pump snout?
Just a thought.
Edelbrock Airgap
Mil
71hotrodpinto
Im confused? I thought that you already had a fan setup before the swap? The engine didnt move forward did it?
Well as far as my little setup goes, i went to the remote water pump and a straight belt right to the alt. However im sure your fed up with fabrication and modification at this point. Im not sure anyone makes a fan setup thinner than 1.75 and even then your still rubbing. Ill poke around the inet for you for a bit see if i cant find somting.
Edelbrock Airgap
Mil
no they are right.....i do have a few screws loose ;D :hypno:  Thanks for making my day!
stever
Some of the guys at raceway park {INDY}had a chat about youre car today.Said they saw it on a turbo site.Thought you had a few screws loose.People without a pinto just dont understand.They think all fords should be mustangs.
yes i am from whiteland indiana,and no i dont know the gliddens.
It does way on the mind. But you are not doing stock work and it may take a week just to figure something out. But it is worth it in the end. Hang in there!!!!
yes, but at least that stuff can be done at home in my driveway!  If you can believe it....the vacumme hookups/lines (the vacume port in the intake is just about under my carb, and the stepup/stepdown fittings are driving me NUTS...took me a week to find 1/4inch barb "T" fittings) are giving me the most headacke right now. LET IT END!
71hotrodpinto
You must have esp. i was just here wondering what was going on..
Your tired? I bet! This kind of project is massive for us "average joes".
Just think you are still going to be tuning it for a few weeks after as well, and chasing down the little bugs here and there...  :lol:
Just trying to make you feel a little better LOL!  :rolleye:
Edelbrock Airgap
Mil
