80 pinto original
Date: 08/04/2019 10:45 am
Date: 01/28/2017 12:30 pm
Need Interior Panels
Date: 07/09/2018 04:59 pm
71-71 speedo cable
Date: 07/31/2021 09:04 pm
Date: 05/22/2018 01:54 pm
Date: 01/28/2021 03:49 pm
Pinto hubcap
Date: 01/07/2017 08:40 pm
Date: 01/19/2020 09:06 am
Date: 11/04/2018 02:34 am
  • Online today: 587
  • Guests: 185
  • Total: 185
30+ MPG w/ modification
Started by joecool85, August 01, 2006, 08:08:31 AM
joecool85
Ok, that makes sense.  Anyone have a dyno plot from a pinto so I can see where I'm aiming for?
Life is what you make it.
http://www.thatraymond.com
robw
I hope you can make some sense out of this mumbo jumbo i wrote.  the reason why your 1.9 liter escort will do 75 mph at 3k and the 2.3 won't is all where the motor makes it torque and horse power,or at least where it really starts coming on strong. you could take a jap car motor that doesn't redline till 8,000 but only starts really making torque at 5000 rpm or a Buick 455 that has 510 lbs of torque at around 1900 rpm. you have to be able to match the speed you want somewhere in the torque curve.bottom line is the 1.9 probably has a broader torque curve then a pinto motor.
joecool85
I was doing some thinking, and like I said, the 88hp escort we had did fine in 5th gear which was 3k @ 75mph, the same this pinto would be.  The escort had a 1.9 CVH motor with 88hp, 108tq.  I checked and the 2.3 is rated at 88hp 118tq for the pintos.  The same hp, 10 more tq, and they weigh about the same.  I see no reason why it wouldn't be fine.  Now, it won't be any speed demon, but it should be totally driveable.
joecool85
My family own 2 1994 escorts, the only difference being tranny.  Also, I have seen MANY stock escort ZX2 dynos, and the manual tranny ones always have at least 6 more hp than autos.  They are 130hp at the crank btw.
Gaslight
Quote from: joecool85 on August 01, 2006, 04:17:14 PM
Then explain to me why an auto 94 escort gets an average of 28mpg, and a 5spd identical to it gets 34 average?  And the same goes for pretty much every car and truck I've ever seen.  The reason is, in a manual transmission, there is less drivetrain loss.  Thats the same reason why on a dyno if you have a 5spd and an auto of the same car, the 5spd will put more power down to the wheels.
 I can't.  And your wrong about the dyno.  I race, build cars.  There are a lot of factors that go into one car dyno'ing more than another.  I have never seen two identical cars with the only difference being the transmission dyno together but I have seen cars close to each dyno way different numbers.  Where did you get the mileage figures for the Escort that shows this difference?
Jake
He just said it was possible, and to that I agree.
There are too many variables that would need to be consitered.
ADDED: Now I see exactly what he is talking about, the difference between city and highway. Yes, I agree with Jake, it is POSSIBLE.
Gaslight
Bill,
  You're right.  That is were consistency comes in and the auto will win everytime.  Also on the freeway the AOD will lockup and you get a 1:1 the same as a 5 speed anyways.  If you look at the window stickers in two identical new cars with the only real exception being the transmission and auto will have a better average between city and highway.
Jake
joecool85
Quote from: Gaslight on August 01, 2006, 04:11:58 PM
Bill,
 Right on the money.  That's why i said average between city and freeway.  Given a AOD versus a manual 5 speed.  Autos generally come out with the better MPG numbers.
Jake
Jake keep in mind that most a/t's are heavyer, and mileage would depend an a bunch of other factors. (like we are talking about)
Gaslight
Quote from: joecool85 on August 01, 2006, 04:11:35 PM
Regardless, this thread wasn't about tires so much as gas mileage.  So, do you think that 30mpg is possible in a pinto?  Thats the big question here.
 Yes.   But your original post had variables in it.  That is what we are discussing.  I think 30 MPG is possible in a Kenworth.  Until you start talking about specifics.
Jake
Gaslight
Bill,
Jake
joecool85
I know what those #'s are supposed to mean; same thing with the EPA milage estimates.
Jake, I agree, there are trade-offs. The only thing about a m/t is you don't loose power through the tranny and t/c, but with a lock-up t/c and highway driving...
Gaslight
That just says what I just told you.  A 60 series tire puts more face on the ground than a 75 series tire.  A 60 series as more rolling resistence.  Just another reason why Bonneville cars don't run 40 series tires.
Jake
joecool85
When I was running in the x-car division at my local track we had to run street tires that were 65 or narrower. I ran 195 65 14's on my car. I would find used ones of different brands and models with tread widths ranging from 5.25" to 7". They all seemed to be much closer in height.
If you are looking for mileage I would think any '80' tire would do better than a '65' with all else equal.
Gaslight
Right.  But a 165/65/14 has more rolling resistence than a 165/75/14.  The less resistence on the road the easy the motor runs the car down the steet.  Also I should have clarified that a auto with an overdrive will get better average fuel economy city and street combined than a manual.  Shifting is more consistent and usually down at peak effciency if all things are working correctly.  You could never shift in the same place every time no matter how good you think you are.  Also depending on the model Pinto you are thinking about getting it will have a pressure ratio and a wind resistence.  I am pretty sure Bill is right and that a 2.3 does not have the horsepower to maintain 75 mph at that RPM.  A fuel injection motor will probably be able to do it but not a carb motor.
Jake
joecool85
First, right now this is theory, I don't own a pinto yet.
Second, the way tire sizing works in P-metric sizing (IE - 175/65/14) is width in mm, aspect ratio, then rim size.
So a 175/65/14 is 175mm wide, 113.75mm tall off the rim (175 x 0.65) and goes on a 14" rim.  Old school tire sizing is like current floatation sizing.  IE -  33" x 10.5" - 15" which would be a 33" tall tire that is 10.5" wide on a 15" rim.
Quote from: joecool85 on August 01, 2006, 11:30:20 AM
...why would a 70/75 series tire be better than something else?
In my experience, better mileage is had with skinny tires (IE 165-175 as opposed to 205 or bigger) run at higher pressure.
That # on the tire is not the really the width, that is the size. Narrow tires like 75's or 80's will tend to give you better mileage over 70's, 65's,...... Taller and skinny would be better for milage alone.
Higher pressures (over inflation) can reduce rolling resistance of the tire and give better mileage too, but sometimes at a cost of tire life and safe handling of the vehicle.
Keep us posted on how the MAX MPG project goes.
joecool85
Alright, Now I'm thinking this is totally possible.  If you look here: http://www.autosafety.org/article.php?did=812&scid=77 it says a 75 pinto (2600lbs) got 26mpg and a 1981 escort (2100lbs) got 33mpg.  The escort was still carb'd at that point.  I'm thinking that one of the lighter years of pintos (71-73) could easily get 30mpg with a 5spd tranny so it has OD, and a modern ignition.  I think even the heavier years, 74-80, could do 30 mpg with the mods I've been talking about.  Definetly worth a shot to me.  I've always considered 30mpg my "baseline" gas mileage for highway mpg in a small car.  My 94 tracer got 32 regular driving and 36-40 highway, and my ZX2 gets 27 regular, 30-33 highway.  If I could almost match those numbers for my 2001 ZX2 in a 70s carb'd pinto, that would be wicked cool!
joecool85
Oh I know FI is way better for MPG/efficiency.  If I go FI I will probably still go with a vulcan 3.0 V6 which gives an auto taurus 30mpg highway, so it should give a 5spd pinto at least that.  But I was looking into carbs to keep in old school, and also I just hate dealing with computers/sensors all over the place.
I think that with a good running 2.3 mated to a mustang 5spd, 4.10 gears, 175/65/14 tires, header, K&N (or similar) filter and an upgraded ignition I should be getting around 30mpg highway, 24 city.  This is assuming a non station wagon pinto btw.  All of that should cost me $1000 or so by my figuring.  And it'd be well worth it if I could get it to all work out.
I was basically wondering what the highest mpg anyone gets in a carb'd pinto.
If it is environmental 'costs' you are looking at, then you need to go deeper into how much emissions the car will put out. A low emission emitting car at 20MPG might not pollute as much has a high emissions car at 30MPG. IMHO, A, EFI would be MUCH better to do that job (thats why they are in cars).
Bill.
ADDED: My (HEAVY) Buick Ultra Supercharged EFI 3.8 V6 will get me 30MPG highway on long trips.
joecool85
I'm not so much doing it to save money so much as to lessen my impact on the environment.  I might do 4.10s in the rear, that would equal out to 3k at 75mph, which was about the same as my 1994 escort did (88hp, 2400lbs) and it did fine in fifth gear.
I don't see it costing more than $500 for the carb (I've seen new ones as low as $300), $50-$250 for gears and the tires etc I was going to get anyway.  So I'd be looking at a min of $350 and a max of $750.  In a year, two years max I'd get back my "investment."  That is assuming I can get 30mpg out of a carb.  I really like carbs, computers are over rated.  Keep in mind this is coming from a New Media major, I deal with computers every day.  Macs, Windows, Linux (mostly slackware and ubuntu) and also I've dealt with computers in cars, what a pain.
**edit**
btw, I just found out that gremlins get about 30mpg highway with a 3.3 I6 motor.  They must have been carbed back in 71.
IMHO: A stock N/A 2.3 will not like fifth gear and keeping the car rolling at that speed doing 2700rpm.  I think you will be shifting to 4th a lot.
There are EFI turbo Pintos out there that get close to those MPG #'s, and do well cruising at that RPM. I have 3.40's in mine, get better than 25 MPG (with my foot in it all the time), and it does fine.
Typically a carb will not get you better milage than EFI, nor will most A/T's over M/T's.
You can try to match up tranny gears, rear gears, and tire size to get the full ratio's you are looking for.
There have been a few posts about MPG increases in Pintos (and other cars). IF you are doing these mods STRICTLY for the MPG, you need to keep in mind what your COST RECOVERY will be (how many miles do you need to drive it to start saving money?).
Example: If it cost you 3k to do the updates, and you get 30MPG VS 20MPG out of the car:
10K miles at 20MPG = 500 Gallons @ $3.50 a gallon = $1750.
10K miles at 30MPG = 334 Gallons @ $3.50 a gallon = $1167.
It would save $583. every 10K miles driven so one would need to drive the car over 50K miles to off-set a 3K investment.
I did not say don't do it, just look at the #'s, and decide what is right for you.
joecool85
The 2.3 is what I was talking about.  Why would an auto get better mileage?  And why would a 70/75 series tire be better than something else?
In my experience, better mileage is had with skinny tires (IE 165-175 as opposed to 205 or bigger) run at higher pressure.  Also, I don't think I've ever really heard of an auto getting better gas mileage than a stick.  Unless we are talking about a stick w/o over driver compared to an auto w/ overdrive.  But the 5spd in those stangs have a .69 5th gear.  Like I said, it'd be around 2.7k RPM at 75mph.  Heck, my 5spd escort revs a tick higher than that at 75mph.
Gaslight
I don't know with a carb or not.  I can put you onto a carb rebuild shop here in California that can still rebuild the carbs right.  I see new Weber replacment units still popping up all over the place it seems.  You will get better mileage with an auto.  Going to a 70 or a 75 series tire will improve mileage.  If you're stuck on a 5 speed you will need to go through all the 5 speed build codes and pick one and find it since they did not all come with the same final gear.  Finding one for a 2.3 would be better I think.  Anything you can do to the motor to help it breathe and get rid of the exhaust easier will improve mileage also.
Jake
joecool85
Ok, at first I was thinking a 3.0 V6 (pulled from ranger) would make a great pinto motor.  And it would, but it would be a lot of modification, plus I like carbs and you'd be losing that.  The thing is, I'd like to be able to get 30 (or close) on the interstate cruising 65-75mph.  Here is my idea:
2.3 pinto (swap if necessary)
new carb
5spd tranny from mustang
3.73 rear gears w/ 205/60/14 tires
From my calculations, the car should be around 2700rpm @ 75mph in 5th gear.
Now here are my questions:
Where can I get a new carb for a 2.3?  I know you can rebuild the old ones, but newer carbs are inherently more efficient.
Will the 5spd from the 2.3 mustang bolt in ok?
Do you think this should yield 30mpg or so highway?
