Date: 10/24/2019 01:43 pm
Date: 04/12/2017 08:15 am
Date: 03/21/2017 07:47 pm
77 Caliper Bolt
Date: 08/21/2018 04:02 pm
Pinto Fiber Glass Body Parts
Date: 01/06/2019 06:53 pm
Date: 05/19/2018 04:56 pm
1980 Ford AM radio
Date: 12/22/2019 11:57 am
Need 2.3 timing cover
Date: 08/10/2018 11:41 am
1971 Pinto
Date: 03/04/2017 11:28 pm
  • Online today: 614
  • Guests: 557
  • Total: 557
My New Pinto
Started by Cookieboy, July 25, 2006, 07:22:30 PM
Thanks 71hotrodpinto, It didn't require a special order oil filter... I just called to make sure they had in stock...
engine mounts do look weak and I have been wondering where I might get replacements.
rear gear lube is on the list of things to check... needed to get it running well enough to drive first  ;D
I still have a bunch of work to do before the snow starts falling and it's coming along nicely.
71hotrodpinto
Niiicceee. Too bad about the rust though.  Also i cant help but wonder about the "special order" oil filter?? Its an off the shelf PH8A or equivalent Or what was it? Hell if it was the air filter K&N has one that fits the stock air cleaner housing.
As far as maintenance goes though id also check the engine mounts,as they love to come apart. And dont forget to check the u-joints and rear-end gear lube.
I have to say my original 2.0 ran for nearly 200,000 miles and would've kept going if the dam oil pump hadn't come apart and lost oil pressure.
Have fun!
B303,1.7 Rockers,beehives
'68 port/polish heads
Coated Must II headers
Edelbrock Airgap
Holley570,Msd dist,CraneHI6
Mil
after a few more tricks/tweeks got it running much better  ;D
still a little rough to start but a lot better... needs to be warmed up a bit.
once warmed up it runs really good and I feel a whole lot better about driving it.
if it wasn't raining so hard here I would still be driving around having fun/testing.
:( stupid rain.... and looks to be doing it all day long
Hey Joecool,
some updated pics of the 2.0 motor with some of the parts painted... Shiny!
finally got it back from the carb guy, he changed and set the points and rebuilt/adjusted carb.
runs much better but carb is still in rough shape... may have to get a new one but I still have a few tricks/tweeks left to try.
I did time it a little better thru trial, error and test drives and it helped too.
almost ready for prime time...
caravan3921
Sounds good; We'll be in touch, Brian! Always good to talk pintos with other pinto drivers. We'll e-mail you and get you John's cell phone number.
joecool85
Quote from: Cookieboy on August 06, 2006, 04:39:24 PM
Thanks Joe and no the tires don't rub and lots of clearance from what I see
Cool, good stuff to know.
Life is what you make it.
http://www.thatraymond.com
joecool85
Oh man, I lust for your car.  Do those tires rub at all in the front?  Must be close from the looks of it.
Sandy and John, He is one of a kind and yes here in Hibbing... been hard to get the pinto into him as I had to wait for a carb kit and his busy scheduale during the racing season. He's been working on mine inbetween the racers and I can't wait to see what he does to it.
Once I get it back I still have a bunch-o-work to do... I still have some under the hood stuff and parts to replace, not sure how dependable this pinto is yet, interior is all torn out and I have to take all the heater vents out (mice moved in last winter... and well the stench is horrible) and I'm not to sure I'll be taking it to the cities, as much as I would like to I have 2 other bodies to bring with me and they do love the comfort of my air conditioned van during this hot and humid season.
Even if I don't bring it down I wouldn't mind meeting a couple pinto people and wouldn't mind looking yours over...
My email is brian at cr-computers dot net and if you get me a phone # I'll be sure to make some time and perhaps we can get together and swap some stories
Brian
caravan3921
is this carb and tune up guy up in Hibbing, MN?  We're looking for such a guy....
caravan3921
caravan here: yeah, perhaps Labor Day we could meet up and share Pintos.  I will e-mail you and give you cell phone number.  Our pinto needs some carb work as well.  Hopefully, we can get her in the shop sometime in August.  She sometimes starts real hard, but other than that, she is solid as can be.  We purchased it a year ago on ebay and had it shipped to Mpls.  Sandy and John
caravan3921
oops, this got posted on the wrong thread.  sorry!
caravan3921
SRT,
I passed that on to the "carb and tune up guy" and he said makes sense but he did check for leaks there and found none. He said that my points were almost closed and carb needs serious attention.... needs a rebuild and some bushings are bad. The pinto did sit unused for a few years. He has the carb apart now and thinks once he is done the little pinto will run real nice... I trust this guy as he IS!!! the expert everyone turns to... even the racers in the area. I've had him do this to 2 of my cars and have been extreamly happy with the results... I hope to get the car back Friday or Saturday but told him time isn't the issue for me... running good is and he keeps as long as he wants.
take the 'decel' (deceleration valve) valve off at the intake manifold, tap the hole into the manifold to IIRC 3/8 pipe insert a plug lfush and reinstall the decel valve.  eliminates a potential vacuum leak and helps the engine rpm settle back down to idle after acceleration and between shifts
and a couple more for ya Joe...
valve cover gasket was leaking bad so have to replace... took some pics and painted a few things...
I'll post painted images later when I have it all done...
a work in progress....
Caravan... I'll be in Rockford, MN the weekend of the 26th for a family reunion and again for labor day to go to the Renaissance.
Hope to drive the pinto but... never know... Haven't got it running good enough to consider taking it out of town yet :o)
but the Tuneup and Carb expert here in town has it w/instruction to do what necessary to make it purrrrrr.....
and... don't let the pics fool ya to much... has quite a bit-o-rust on the back quarters and I have the interior gutted
But the paint sure did get Shiny!!!
OK Joecool... pics of 2.0 liter engine coming right up
joecool85
Any chance we can have some more engine shots?  I've been studying pinto motors and don't have one I can look at in person.
caravan3921
I meant to say... meet other pinto owners in state of Minnesota!
caravan3921
If you ever in the Mpls. area, stop by and we can admire each other's Pintos!!  It's nice to meet other pinto drivers in state of !  And congratulations; she's a beauty!
they are 14's and they sure do look good on the car... pics just don't do it justice.
the couple times I've had the car out it sure handles nice...
suspension feels real tight, shocks are good and thoes tires sure help
joecool85
Wow, those aren't 15s huh?  Like I said, looks great!
New Firestone Firehawk P205/60R 14" on American Racing Wheels  ;D
purchased in 2002... I have the receipt... tires still have the little knobbies... just like new...
The pinto was in storage after the tires were purchased and not really driven...
I also have the origional wheels and tires w/half tread + the bias ply spare.
all the tires and wheels came with the car
joecool85
What size tires/rims are you running?  They look great!
ran out of parts to install so... time to make it Shiny!!!
rubbing compound, beffer, elbow grease and wax...
2 nights and a little work the next day and... SHINY!!!
nope... valvoline for oil and tranny...
I think I should be able to adjust/check the tranny/bushings
joecool85
Well, you can do the oil change, clutch adjustment, check you bushings, and tranny flush yourself.
going in at 5:30 tonight for the oil change and tranny flush at Valvoline...
I called to see if they had the filter first... gotta custom order about half the parts for this car and some I can't get  >:(
needs the fluids changed and I hope that's it but if not I'll have it looked at to see what the problem is...
I'll pull out the manuals tonight to see what I might be able to do myself.
joecool85
Could be shifter bushings/linkage, and/or poor clutch adjustment.
Hey Joecool, one of the things on my list is tranny service...
likes to grind going into reverse and after a little driving it shifts a little smoother but that could me getting used to the clutch on this car and it is running much better now  ;D
