Deluxe Steering Wheel
Date: 10/16/2017 08:13 am
Date: 09/12/2018 12:33 pm
Date: 05/22/2018 02:27 pm
Misc. Pinto parts
Date: 11/09/2019 04:25 pm
Date: 09/22/2020 11:33 pm
Pinto Vinyl Top
Date: 10/09/2020 10:29 pm
Need 2.3 timing cover
Date: 08/10/2018 11:41 am
Date: 09/15/2019 12:28 pm
Date: 11/23/2017 05:44 pm
  • Online today: 110
  • Guests: 93
  • Total: 93
72 2.5 turbo pinto
Started by turbopinto72, May 12, 2003, 10:38:38 PM
johnbigman2011
Well maybe I will run across it sometime when I'm home. Sure would of liked to had it myself.
Thanks
The car went to a Guy in Texas. I hope he is having fun with it.
johnbigman2011
Brad, where did your car end up going..
I'm surprised that it didn't show up on here as a new members car. ???
fast64ranchero
Good luck on the auction, hope you get a bidding war on it to get back some of your invested money.
Walt
72 old V-8 parts Pinto
73 pinto, the nice one...
This Car is now on Ebay as of 1/10/2013.  Take a look, and tell a friend.
Well, guys............ This Car is now for sale... :o
I will have a bunch of photos to post soon. For now I will post the build list.
Build list 1972 Turbo Pinto
Car: 1972 ford pinto hatchback ( 71 hatch )/ original green paint/ black interior/ Jaz poly seats/ 6 point chrome moly roll bar/ full length welded in frame rails/ Autometer gauges (5" tach, boost, water, oil, volts and trans temp), wheels and tires- front 4" alum w/ 165-15; rear 7" Weld drag lt w/ 275-60-15 t-a radials/ trunk mounted battery in Moroso sealed box w/ master shutoff/ vw Scirroco radiator w/ electric fan.
Stats: 2350#/ 300 rwhp @ 18# boost/ 11.8 @  115 mph w/ 23# boost.
Engine (note- machine work done by Dan Esslinger): 2.5 late ranger small journal, 'o' ringed/ arp head studs/ arp mains studs w/ straps/ Crower billet rods/ JE custom forged pistons w/ 1.2, 1.3, 3.0mm sealed power rings (hand gapped)/ Cord black turbo head gasket/ Esslinger svo alum head w/ #2235 roller turbo cam (234* and 585" lift) w/ Esslinger roller rockers/ Race engineering adjustable cam pulley/ Esslinger adapter head to square ported efi intake manifold/ 70mm throttle body/ 45# flowed injectors/ nos/ bosch in-line electic fuel pump/ Paxton fuel pressure regulator/ large vam w/ k&n cone/ custom chipped pf3 ecu mounted in glove box, wiring harness mounted up under dash/ ported e-6 exhaust manifold/ t3-t4 hybrid turbo (to4b '60' trim w/ t3 stage 3 63 a/r hot side)/ front mount intercooler (2 1/4x25x7)/ 3" exhaust w/ bassani muffler/ 100 amp (1) wire gm alternator/ gear reduction hi po mini starter/ additional Esslinger eng. Items- billet intermediate shaft w/ bronze gear, billet waterpump, billet waterpump and crank pulleys, crank scapper/ cast alum valve cover.
Trans: c4 by Walt built/ full manual reverse pattern w/ brake/ 3400 rpm stall Continental converter/ B&M pro ratchet shifter/ trans cooler/ Ford motor sports alum drive shaft
Rear: 8"/ 3.55/ Strange mini spool/ owner built "Caltrac" type adjustable traction bars.
Note: car has less than 500 miles on full build up.
CHEAPRACER
Thanks for the compliment. I find as I get older I try to make things look " simple" which takes a LOT of time  ;D
Humbled by the Excellence of execution...
I have nothing but respect for High standards of engineering!
  What other Miracles can you perform?
View from the intake side.
The view from the exhaust side.
another top view.
Well, this car has been through a lot of changes over the last couple years but I think this is the final version for this car. Its back to the EFI system.
I've got another video for you all to watch. Its the most recent rebuild of my 2.5 motor after I fried the piston. Enjoy and turn your speakers on.
http://www.youtube.com/watch?v=TK_uK2yTd2k
thanks for the website update Brad.
jbcalhoun
I for one am looking forward to seeing your car running. Nice piece of work! Keep us updated on progress, please.
By the way, it's turboford.net instead of .org .  They changed it several months ago.
How do you think the throttle response will be with the throttle body on the turbo inlet side? I don't know. Just curious.
Thanks
Brad Calhoun
Quote from: 78pinto on December 04, 2006, 10:27:00 PM
i didn't make it that far with mine Brad, i sold all three before i even got to play with them. Find somebody who has one running (turboford.org) and ask for their tables to start out with... thats how alot of people start (thats what i was going to do)
Yeah, I was going to start there. Thanks
Jeff, how hard is it to set the VE values? ( and make it run). I have calculated 2 scenarios and both tables look ( ok ? ) but very different. As this is a speed density unit, based off the RPM and MAP sensor and ( not ) the O2 ( used for idle and cruse only ) I will concentrate on Idle and then Stolic at the different fuel curves. ( How hard could that be............ :o  )   ;D
good luck with it Brad! And what do you mean its all my fault!
A tight shot of the mega-squirt system installed in the glove box. and one shot showing it in relation to the interior. Next, I will be setting the VE values and starting my tune up ( wish me luck.... :P )
Here is a tight shot on the intake side. you can see I modified the fuel rail to accept fuel from both ends.
One from the front.
Here is the exhaust side of things
Well, I've been working slooooooooly on this car. I have some up dates. The engine management system is installed and the car is just about ready to fire up. This picture is what the finished engine looks like from the intake side..
stever
yes i am from whiteland indiana,and no i dont know the gliddens.
CHEAPRACER
May I ask why the throttle body is being used before the turbo instead of after? Just curious, I've never noticed one that way before.
Turbopinto72 check your e-mail.  I have to go to work.  I will be at work until 11pm
i am going to make it a point to get down SD way later this year I would really like to see your cars
Just one more. I am working on the Megasquirt unit. I will be posting a full schematic of all the wiring it takes to set up a megasuirt EFI system and interface with Pinto wiring.
