Date: 08/13/2018 02:46 pm
2.3 front sump oil pan
Date: 07/24/2018 03:17 pm
Date: 02/10/2017 09:30 am
79 Wagon with many extras
Date: 07/08/2020 04:18 pm
PINTO TRUNK LATCH & CATCH
Date: 03/23/2018 09:39 pm
Date: 04/27/2018 10:28 pm
72 PINTO WAGON
Date: 09/23/2018 06:16 pm
Misc pinto parts 71-73 2.0
Date: 05/05/2020 11:56 pm
Date: 12/10/2017 01:14 pm
  • Online today: 600
  • Guests: 381
  • Total: 381
5 speed behind 2.0
Started by oldblu72, December 13, 2005, 10:43:20 PM
Quote from: 77turbopinto on December 14, 2005, 08:32:11 AM
The 2.0's and the 2.3's have the same bolt pattern. The dowel pins are different so you will need 'stepped pins" to bolt up a 2.3 t5 to the 2.0. Also, there are different t5's for the 2.3. Just swapping the bells, llike putting a 2.3 bell on a v8 t5, won't work. If you don't want to re-build the t5, get one from a 2.3 to start with.
BTW: Welcome.
Actually, to clear that up. The 2.0 and 2.3 only share the bottom 4 bolts being the " same" there are two additional bolts at the top of the 2.3 belhousing that do not work with a 2.0 application/T5 swap. This is were some fabrication will come into play.
BTW: Welcome.
There are lots of 5 speeds that will fit behind a 2.0 but none that are a direct bolt on. Please refer to out FAQ section and look at all the T5 information.
oldblu72
is there a ford 5 speed trans that will fit behind a 2.0? i thought a later straight 6 mustang might have the same narrow bolt pattern. anyone try this?
