Cruiser Dash Gauges
Date: 12/04/2016 11:50 am
Date: 12/20/2016 10:47 pm
Front Body parts needed
Date: 02/09/2018 06:09 pm
Date: 06/24/2020 06:12 am
Date: 10/05/2017 02:26 pm
Date: 02/05/2020 11:06 am
Date: 02/18/2017 05:52 pm
Date: 07/20/2017 01:23 am
  • Online today: 600
  • Guests: 499
  • Total: 499
5 speed behind 2.0
Started by oldblu72, December 13, 2005, 10:43:20 PM
Quote from: 77turbopinto on December 14, 2005, 08:32:11 AM
The 2.0's and the 2.3's have the same bolt pattern. The dowel pins are different so you will need 'stepped pins" to bolt up a 2.3 t5 to the 2.0. Also, there are different t5's for the 2.3. Just swapping the bells, llike putting a 2.3 bell on a v8 t5, won't work. If you don't want to re-build the t5, get one from a 2.3 to start with.
BTW: Welcome.
Actually, to clear that up. The 2.0 and 2.3 only share the bottom 4 bolts being the " same" there are two additional bolts at the top of the 2.3 belhousing that do not work with a 2.0 application/T5 swap. This is were some fabrication will come into play.
BTW: Welcome.
There are lots of 5 speeds that will fit behind a 2.0 but none that are a direct bolt on. Please refer to out FAQ section and look at all the T5 information.
oldblu72
is there a ford 5 speed trans that will fit behind a 2.0? i thought a later straight 6 mustang might have the same narrow bolt pattern. anyone try this?
