Date: 02/18/2017 04:41 pm
1973 Pinto hatchback for sale
Date: 11/13/2023 11:30 am
Seeking 1971-1973 Rotors
Date: 04/08/2021 12:23 pm
Date: 02/21/2022 11:11 pm
Date: 09/12/2018 12:33 pm
Date: 01/20/2018 07:51 pm
free transmissions
Date: 11/28/2019 10:21 am
front end parts
Date: 03/30/2018 12:48 pm
Date: 08/01/2018 01:17 pm
  • Online today: 452
73 Pangra Project
Started by turbopinto72, May 05, 2003, 06:42:14 PM
The picture above ant this one shows the Hat I am using that the plumbing from the hat top the innercooler.
Innercooler.....well, I have been working on the innercooler for a bit and thought I would post some ( pre shiny " pictures of the progress to date.
Quote from: turbopinto72 on November 10, 2008, 09:53:16 AM
YUP......... ;D
Still need to mount the innercooler run the plumbing , mount the Blow off valve and build a hat.......... Stay tuned
i had a feeling you might be going that way when you inquired about 'hats' a while back
you think a plastic hat will hold the pressure?
Quote from: turbopinto72 on October 01, 2003, 09:33:42 PM
The turbo is a T4 with a .69 AR and an "N" turbine wheel. Its probably not the " best" turbo for this combo but it works well.
that is what i used on mine originally.  i did like the t4 because of the 'on-center' design.  i did try a .96 ar  but couldn't get the thing to respond like i "needed" it to on the street on friday & saturday nights on the blvd here in whitter.  it also wasn't the best at the 1/4 mile (considering what i had to work with)
street use it's great because of it's quick response but at the top end it tends to pump to much pressure (remember the time frame here) leading to detonation problems.  Mind you I'm talking back in the early '70's.  Intake charge temp was a problem.  Fuel distribution was a problem.
i had a .96  off set on mine for a while and the top end was unbelievable but i couldn't (at the time) make it live.  It was a street fighter so i changed it back.
Quote from: srt on November 10, 2008, 04:04:13 AM
your gonna pressurize the holley?
YUP......... ;D
One more pic
Next, the engine goes back in the car. But wait, whats this ????
That does not look like the same set up as before......Hmmm, what could I be up to now?
Next the pressure plate goes on.
Ok, so its time to bolt on some stuff and get the engine back in the car.
Pictures of the flywheel and clutch/pressure plate
Quote from: srt on October 29, 2008, 12:45:24 AM
what material did you use to raise the floor of the ports?  are the 2.3 heads as restrictive in the valve pockets as the 2.0 heads?
JB Weld  ;)
The 2.3 head is a little better in the valve pocket than the 2.0
Pintopower
#1. 1979 Wagon V6 Restored
#2. 1977 Wagon V6 Restored
#3. 1980 Sedan I4 Original
#5. 1980 Wagon I4 Restored
...Like i said, I like them.
...and I have 4 Fiats.
The finished product looks ok.
The next picture I wanted to show you is what I did with the intake ports. As you can see I raised the bottom of the port and raised the top.
One of the things I had to do is relieve the piston at the exhaust valve. BTY this is NOT really the best way to do this but it works. I used clay to check the clearance between the piston and valve. Actually, the ex valve would never get this close to the piston because at TDC the valve is not at full open, But, for safety sake and in case I break a belt etc I wanted to be safe,
The standard Pinto block have the following numbers.
The numbers on the cossie block are 205 as you can see from the photos. There are other different numbers also. See photos.
So, I am swapping blocks and using a standard Pinto block instead of the Cossie block. The aux shaft in the Cossie block will need to be delt with at another time. So for now, I will use my spare block. Below are pictures of the two blocks. The purple is the cossie block and the blue block is the standard Pinto block
The water seepage is not much and amounts to steam but its still an issue, as you can see. what I have done in the past is use a small amount of silicone and " wipe " the surface of the gasket prior to install. Then I use about 1/2 of the radiator stop leak. That seems to cure this issue.
You might be able to see in the upper right corner of this pic, a slight depression just around the outside edge of the head gasket fire ring.
The block side of the gasket interfaces with the " O " ringed block. the O rings ride just on the outside of the fire ring of the head gasket.
The gasket held up fine between the head and the gasket but the block side did not hold up very well.
So, I am tearing down the engine and I notice something else I dont like. It seems that the head gasket was leaking. I had a similar issue with the Green 2.5 Turbo car. I think I know how to fix it.
 :'( that is UGLY.  i hope you can save it
ewwww...man that bites
FrankBoss
I really hope I can save this block as it is a Cosworth Turbo block............ >:(
Now, lets compare that with what I pulled out just for fun.
Well, it seems like I have done something that might not have been done before... surprised The last time I ran the car, while on deceleration the engine stopped. It looked like I threw a timing belt. To make a long story short. I noticed the Aux shaft was not turning. So, How to get the shaft out of the engine? I fabbed  a puller and pulled it out. What was stuck ? take a look at the pictures. The first pic is what a good shaft should look like.
At least you do not have to flip all the pieces right-side up first!!!  :lol:
