  • Online today: 600
tires and rims
Started by JoeBob, December 04, 2018, 04:13:54 PM
Quote from: pintoman2.0 on February 17, 2019, 11:33:41 AM
I ran a set of Fox LX wheels on my 75 Bobcat, with 225-60-15 for years with a 1/4 inch spacer. Started without, backs wedged against the springs. The spacer took care of the problem.
They sound like 15x7s with 4.5" backspacing, which is common for Fox3s. I have some 10-hole wheels off of an '86 T-bird I was going to use, but didn't want to fuss with spacers. Then I went 5-lug anyway with 15x7 slot mags.  8)
I went with 205/50-15s to keep the height close to stock. It's slightly shorter so the speedo reads is just a tad high, but that's better than too low in my opinion. One thing to be aware of is that short sidewalls like mine will make you feel the road noticeably more for better or for worse.
pintoman2.0
I ran a set of Fox LX wheels on my 75 Bobcat, with 225-60-15 for years with a 1/4 inch spacer. Started without, backs wedged against the springs. The spacer took care of the problem. Front rubbed on the frame rail when I turned it left all the way to the lock. I just learned to not turn that sharp. I also ran a set of GT wheels with the same size tire on my 77 Ralley Wagon without spacers, never had a problem.
JoeBob
Here is a side by side comparison of tires that came with the car and what I am getting on Tuesday.
OEM  195/70/13       Hight  23.7   Width 7.7    Speed 60mph
195/55/15                         H 23.4   -1/8"  W 7.7        Speed 59.2
This is the tire Firestone said was the only tire that would fit, and no longer made.
225/40/15                          H 22.1
-1 ½    W 8.9  +1 1/8       Speed  55.9
I will post photos when it is all done.
Thanks again Russ
77 yellow Bobcat hatchback
Deuteronomy 7:9
Glad you finally got someone that is willing to help.
In the past there were more stories like your first Firestone store. Most people I knew avoid them because of that.
What size are you going with?
JoeBob
PROBLEM SOLVED!
    Boy am I dumb. I have been fighting with lying firestone for 3 months. They lied again today. They told me there was only one tire they could source in my needed size. I called another firestone and asked for options in my size. They had loads. I was going to use this information to pressure them to deal fairly. Then I thought, why not get the new store to honor my tire guarantee.
    They were wonderful. They gave me $110 ea. credit on my 7 month old $115. tires. I need to paint Russ's rims, so installation is next week. Thank you all for advice and ideas
Deuteronomy 7:9
JoeBob
Go to this as provided by Whitt. You will see spedo variations listed, when you make a comparison of sizes. It is on the second page (tire comparison) 185/70/13  @ 60 mph equals 63.9 mph for 15". For myself, I don't believe an adjustment is worth the effort.
ps  Can anyone tell me the width of the OEM 13" rim?
Deuteronomy 7:9
ford man
thanks for posting the link for the gears !
Need some !
LongTimeFordMan
I posted this somewhere else but if you are concerned about correcting your speedo and odometer to tire size.. there is an easy way by changing the speedo gear.
They are available here
https://transmissioncenter.net/shop/driven-gears-for-ford-standard-transmissions-and-ford-transfer-cases/
To determine correct tooth number use a smartphone with a gps speedo app and compare readings to speed indicated on your car speedo..
For android
Speedometer & odometer - Tripmaster Car and Bike
By DS Software
Most 4 speed pintos have 19 tooth gears..
To find correct tooth number use this formula..
Remove and count teeth on existing car speedo gear or match color from pix on the website.
Drive at a speed.. maybe 60 mph as indicated by gps speedo, note speed indicated on car speedo.
Speed on gps speedo divided by speed on car multiplied by tooth count on car speedo equals  orrect tooth count on replacement gear.
Example..
car speed 65,
Gps speed 60
60÷65=.92
.92x19= 17.5
Russell did a good job of explaining it. Because you are going to 15" wheels yes, you do want a relatively short 15" tire.  Ideally as close to the original size as possible. I ran a "guessed" 185-70-13' tire as the original through this calculator with a "new size" 15" wheel https://tiresize.com/calculator/ and you can see the range that is acceptable in green. It doesn't mean you can't deviate from that slightly.  As 2.34me stated above he runs 195-55-15" tire and that does fall within the green (acceptable) range.
Plug some number into the calculator and see what you get. You can always order tires on line and then get them mounted elsewhere. As I stated above the Tire Rack has "associated" other brand tire stores that work with them. They will ship to the desired store and you just arrange an appointment.  The bulk of a tire stores profits likely come from the mount and balance far more than the tire itself. So, while a local store would also prefer to sell you the tires they are likely content to take the bigger chunk of profit on the mount and balance.
JoeBob
Witt
You mention how tall a tire is important. What number tells me how tall proposed tire is? I assume I want the shortest tires possible so as to keep the speedo close.
Turning a bigger wheel will be more strain. Is there a possibility of  abnormal wear and tear on gearing and trans?
Deuteronomy 7:9
205 is slightly narrower than 225. 195 is even narrow. The bigger the number the wider the tire (very basically, it is a bit more involved). These numbers are millimeters. Width also depends on what size rim/wheel you put them on.
The other thing is going to be a problem because these cars NEVER came with 15 inch tires. So there is no CORRECT 15 inch size. You will just need to get tires there and have them mounted somewhere else most likely.
here's a decent explanation of tire sizes
https://www.justtires.com/en-US/tire-basics/tire-size
There are as Wittsend said above online tire size calculators for both width/height and the difference in speed.
For speed, all I do is follow my wife with her driving different speeds, and I look at my speedometer and see what the difference is and hopefully remember that number. On the 79 I will be using a GPS speedometer, so gears/tires/etc makes no difference.
JoeBob
I don't know anything about cars. Mine is a stock 77 bobcat, 4speed, with a 2.3.  I don't need performance. I am a handy capped old man. I just drive the neighborhood. Safe is all I care about. I don't know tire measurements.  What is the difference between 205 and 225.
Because I have a all stock car, can anyone tell me what I need to know to enter information in the calculator? I can show the dealer the correct size.
Deuteronomy 7:9
There are tire calculators available that allow you to see the difference in your tire sizes and engine rpm's at certain speeds. Your car having an automatic or a manual might be a factor. But likely most important is the rear ratio.  If you are in the 3.40, 3.55 area you can go with somewhat taller tires. If you are in the 3.00 and sub ratios you likely don't want taller tires. Comparing the rpm's of your current tire size and a proposed tire on "paper" is a start. BTW, the Firestone dealer stating 225-40-15 tires is odd.  Following the factors that equates similarly to roughly a 205-60-15" tire which is much more common.
I think that 205-60-15" tires aren't that bad a size..., ratios permitting. And the speedo can be re-calibrated closer with an appropriate speedo gear. It may not be perfect, but you can get it close. If the tires you received hold air try them out temporarily to get an idea of how the car responds with the 225-60-15".
In summary, gear ratios don't mean much and tire sizes don't mean much but tire size and gear ratios combined mean everything.  BTW, have you looked to the Tire Rack for tires?  They even deliver to the many "associate" tire dealers in your area and you just show up with your old tires/rims for the mount and balance.
one2.34me
I have a set of 195/55-15's on 15x7 rims on my Pinto. Very close to the same diameter as a 185/70-13.
If used is a possibility you would consider, I just saw this on Craigslist in your area.
https://denver.craigslist.org/wto/d/denverused-firestone-affinity-touring/6784982242.html
You can do 205 60 on those wheels also.
I'm thinking smaller is a safer bet.
225 60 was what were on them. 215 60 might be a better fit for you
But let's see what others think.
And forget Firestone if at all possible. Discount Tires or Big O, or what you have around you. Shop for the tire size, not the car. Pintos never came with 15 inch wheels.
JoeBob
     I thought I would update everyone about our wheel deal. I received the wheels today just as Russ promised. He is a real gentleman.
     Firestone is a real problem. This started with new 13" all season tires with no grip on frost or worse. No other tires were available. They suggested I upsize to 15" They also informed me of a suggested 15" tire they would pprovide. After 2 months I lost their recommendation.
     They now say the only tire that will work (they did math calculations) is 225/40/15  This tire does not exist. I asked is this calculation for the purpose of speedometer or safety?  Tire salesman paused and said "kinda both." I think he is BS ing me. I got the wheels from Russ because they recommended it.
     I gladly paid Russ the shipping price for the wheels. He did exactly what he said he would do. Not only did he give me free wheels, he gave me his time. I would not have wasted his time if I knew Firestone was unreliable.
     What size 15" tires are you all using? These rims are 15"x7
Deuteronomy 7:9
LongTimeFordMan
Agreed..
I actually met Aadlen i think.. he was an old guy who hung out at the yard on penrose.. he had a pacemaker and so did i so we swapped stories..he was pretty cool. I bought a lot of mgb and 76 dodge truck parts there.. s8nce the early 90's. I liv3d about 2 miles away and used to go there and walk around for exercise..
LTFM, My bad. You are right the LKQ Pick Your Part is on Pendelton.  If you have a 10-20 year old car if might be a usable source for parts. Nothing else though. And yes, I have left many a part on the check out counter when they tried to jack up the price. Also had my credit card number lifted there. Only used cash there ever after.
Once I even bought an engine then AFTER I paid for it the guy at the gate said the exhaust manifolds weren't included. He offered me the option of giving him "some money" or going back in line at the counter. I had another guy hounding me because he wanted the engine lift. I threw the guy $4 and left.  For years people went in with tools and dismounted tires themselves.  Then one day after I had paid for the tires the guy at the gate strongly harassed me telling me I wasn't allowed to do so and threatened to bar me from the place.  There was NEVER a sign to this day stating that they prohibited the process.
The place is SO poorly managed. On sale days the Premo section (about 40% of the volume) has ONE guy checking people in AND checking people out. The Regular section has five people for about 60% of the people - and they don't have to check people in. Look at their engine prices on line. They sell engines as "complete" and as "packages." NOTHING defines what the difference is and price wise they are all within a few dollars. Then where most engine "packages" (fuel injected, turbo etc.) are in the upper $200/lower $300 range for some stupid reason a "carburetor" engine package is over $700!  WHAT???  If anything it should be cheaper.
The Penrose yard (U-Pick Parts) was the American yard and the Foreign yard (separate) was closer to Telfair and I believe called A Foreign??? But they  basically had same owner (Aadlen Brothers). In their last few years they took the wall down between them (saved $2 on admission) and moved the Foreign yard to the front of the American section. In fact, in their closing months there was no admission charge. They just had you sign the wavier. This was the quirky yard with a water buffalo in a corral and many other oddities. Here are a few articles about the yard closing.
http://sanfernandovalleyblog.blogspot.com/2015/10/sun-valleys-u-pick-parts-closing-down.html
https://www.dailynews.com/2015/10/29/sun-valleys-venerable-u-pick-parts-junkyard-to-close/
Quote from: russosborne on December 09, 2018, 10:50:14 PM
Hopefully these two come out better.
Ahh, Haa. It is the hole for the single screw center cover, coupled with the (previous) angled image, that made it look like a possible fifth lug bolt hole. Yes, obviously 4 bolt pattren for sure.
LongTimeFordMan
Hi.. actually the LKQ is on pendleton and glenoaks across from the dump..  i never had much luck there.. when i lived in sun valley on vineland i was into mgb's and used to go the foreign  yard on both tuxford  and the american yard on penrose for parts for my rv..
I think the LKQ yard changed ownership sometime in the 90s there sed to be a section called memory lane there where they had a lot of classics.. i would cherry p8ck the goodies from.british cars, switches, allison ign modules, etc for really cheep. But then they got wise..
And the main yard checkout people couldnt recognise parts and often undervalued them.. then LKQ took over and things changed
I never had much success at the new LKQ yard since most of the check out people were latin, tended to speak spanish a lot behind the counter and tended to price gouge non hispanics..
And they did nickle and dime a lot.. if you bought an engine, they charged for pulleys, mounts, water pump, etc..
I think the yards on tuxford and penrose used to be one then they split it up to foreign and domestic... at least i remember the "domestic" yard on penrose having a lot ot mgb cars there in the 90s.
The folks at the yards on tuxford and penrose seemed a lot fairer and prices were better..
Anyway.. end of an era...
Bill, I will try to get a picture of the other side tomorrow with the center cap on.
Didn't realise how bad the reflections were on this one, like I said I was in a hurry to get to work and that side was the only one the car cover wasn't covering completely.
That spot that caused the confusion is the nut that the center cap mounting screw goes into.
Definitely 4 lug Fox Body Mustang. Not  sure of the exact rim width, but you can go a bit narrower or wider than the tires that are on it. Depending on clearance with the car that is.
I actually had bought these for the 89 Mustang I had, but scrapped that car. Tossed these on the Pinto so I could move it around after selling the tires/wheels it came with.
Well Bill this gets better all the time. So, they are the stock bolt pattern (so much for pictures telling the whole story). And it is very generous for Russ to offer them to you. Hope it all works out.
JoeBob
Thank you Russ. Just let me know what you need.
Deuteronomy 7:9
And what sale?
They are free.
These are fox body Mustang. Direct fit.  .
They are currently on my 79 Pinto, no adapters needed.
Sorry for any grammar errors, just woke up. can't see the keyboard well
Frankly it is hard to tell in the picture if that is a fifth wheel stud..., or a reflection that looks like a fifth wheel stud. The stud spacing on the right looks 4 bolt but the stud spacing on the left looks 5 bolt. It may just be picture distortion. If they are 4.25 X 4 then that saves about $350 right there and also eliminates the extra widening that the adapter would create. Many issues solved.  So, if they are 4 bolt my apology for the unnecessary concern. Better to be safe than sorry (as a buyer).
JoeBob
Did I misunderstand this offer, or did Whitt? It is my impression that you are offering 15" 4 lug direct fit rims. Just bolt on and go. Nothing besides tires are necessary. I have the nuts.
Thank you
Deuteronomy 7:9
