71,72 Pinto Door Panels
Date: 06/17/2018 08:27 pm
1977 Pinto Cruizin Wagon
Date: 04/11/2024 03:56 pm
1978 Squire wagon 6 Cly
Date: 02/16/2020 05:42 pm
Date: 10/01/2020 02:00 pm
Crankshaft Pulley
Date: 10/01/2018 05:00 pm
Beautiful 1980 Pinto
Date: 04/13/2020 11:53 am
Date: 02/18/2017 05:55 pm
99' 2.5l lima cylinder head
Date: 01/13/2017 01:56 am
1980 Pinto Parts
Date: 08/05/2020 04:20 pm
  • Online today: 600
  • Guests: 370
  • Total: 370
tires and rims
Started by JoeBob, December 04, 2018, 04:13:54 PM
I'm not trying to hinder a sale here, but Bill know what you are getting into. You will need 4.25" X 4 by 4.50" X 5 wheel adapters that run about $300 for a set of four.  Adapter (set of 2) https://www.amazon.com/Wheel-Adapter-Lug-4-25-4-5/dp/B008IJQTVO Add in another $30+ for lug nuts. These adapters will push the aready wide wheels outward about 1" to 1-1/2". I am no expert on ice and snow driving but you likely need tires specific to that climate.  Maybe others can help as to whether wider or narrower tires are better. But at least in this case these wider wheels will require a wide enough tire to fit properly.
So, you are probably looking at $350-ish for the adapters/lugs, likely no less than $450-$500 for proper tires plus whatever Russ wants for the wheels and shipping. This is likely going way over $1,000. And you will have a very wide placed, wide width tire that might have clearance issues.  Again, I'd advise you check with a reputable tire store to see if this is a proper course to remedy your problem. If they say this is appropriate THEN by all means proceed if you choose.
Any sleet, rain, snow, ice driving members out there that can help Bill as to what works best?
Quote from: LongTimeFordMan on December 05, 2018, 05:08:24 PM
Are there any pick a parts left down there?  They closed the one in sun valley.. turned it into an auction site..
Actually there were two self serve yards in Sun Valley. There is the large, corporate LKQ Pick Your Part (some mistakenly called it Pick A Part) over on Tuxford. It is still there. They still have a 40% off (use to be 50% off) roughly every month. But they nickel and dime you on EVERYTHING. It is $3 to get in the "Regular" yard and an additional $2 to get in the "Premo" yard. The place is poorly managed and on sale day check out can be an hour and a half – or more.
The yard you are referring to was U-Pick Part on Penrose. They never had sales but generally their prices were somewhat lower. A sad day when it closed. It was more of a quirky yard where the other is decidedly corporate.
I use to go to both yards monthly for over 15+ years. I'd pack a lunch and be there from 7AM to 6:30PM when they closed. I'd come home tired, filthy and HAPPY! But the past year or so I have not gone. The closing of U-Pick Parts cut the potential parts cars in half. And the "classic" section at the remaining Pick Your Part is two small rows of mid 80's Mercedes, early Miata's and the like.  Hardly classics in my books.
Picture is the last day U-Pick Parts was open.
Couldn't seem to send anything by pm.
here are a couple of quick pictures.
I do have the center caps.
I'll take some better pictures later, I was rushing while heading out to the car to go to work when I took these.
the one just shows the current tire size, to give you an idea of what the rims take.
JoeBob
I will take your offer. PM to follow.
Thank you
77 yellow Bobcat hatchback
Deuteronomy 7:9
LongTimeFordMan
In general I would agree. But his situation is that 205-60-13" tires are not conducive to the frost (and I assume snow) in his area.  If he goes to 205-70-14 he has nearly the same footprint. So, it seems proper tire compound and tread design is more of what needs to be changed. And in the 13" size it he can't get it even if the tire are sold as "All Season."
  I'm thinking if he can get a set of Fox body 14" steel wheels (used) and mount appropriate "snow" (or at least a better All Season) tire it is to his financial benefit. Aftermarket, especially alloy wheels are a lot of money spent for tires and wheels that only see a season each year. Here in So. Cal. the Pick Your Part has Madness Monday where you can buy a steel wheel with whatever tire is mounted for $7.00. They charge $3.00 to dismount the tire if you don't want it. A tire shop is going to charge you about the same as a disposal fee.  And sometimes you even get a decent tire too (but good luck finding a matching set of two..., or four).
LongTimeFordMan
I would upgrade to 14" wheels and tires..
American racing sells alloy rims with a 4 bolt ford pattern...
I have a set of 14" ones..
Not sure of the model numbers though..
I have a 3.40 rear end and 4 spd and the gearing works out well..3000 rpm at 70 mph with good off the line acceleration..
had to change to a 17 tooth speedo gear..
Discount tire, walmart, and a lot of places sell 205 70 14 tires for around $50-70
Bill,
  This link does a good job of explaining wheel offset. https://www.wheelpros.com/page/offset-explained/9 It is important because offset moves the wheel/tire closer to the internal aspects of the car..., or outward closer to potential rubbing fender openings. And in extreme cases the tire won't even be able to turn because if it presses against a portion of the suspension.
In general I'd say tires bulge about 1" outside the wheel. And you probably want no less than 1/2" (better 1") clearance between the tire and anything it can rub against. So, for any wheel considered the inner edge of the wheel should be minimally 1-1/2" away from anything it might hit.  As I stated above one can measure from the face of the brake drum (or hub if disc brakes).  If you are looking at say... a 26" diameter tire hold a straight edge across the drum then at point 13"out from center  measure the distance to anything the wheel/tire would first hit. This then gets processed mathematically .
As an EXAMPLE (only): If you have a 6" wide wheel with zero offset that means that 3" of the wheel goes inward. You want that additional 1-1/2" for tire bulge and clearance. So the distance measured from the face of the brake drum to the first thing likely to be hit (on a Pinto/rear - the leaf spring) you would need a 4-1/2" measurement.
As Russell stated be careful about newer wheels (even though they have a 4.25 X 4 bolt pattern) as they are most often designed for front wheel drive cars and have significant positive offset (center moved inward).  I've also found the the wheel center hole is typically too small to fit over the Pinto hubs.  In general I think (but can't say 100%) you will find that just about any Fox body ('78-'93 Mustangs/'83-'88 Thunderbirds - Ford Fairmont and the Mercury version of all these mentioned cars) 14" or 15" wheels will fit and give adequate clearance. Remember too as I stated above that the taller the tire the more "bog" on acceleration and the difference also alters the speedometer reading.
What tires you find that actually work well in inclement weather is another story. Perhaps having a discussion with a reputable tire dealer would be beneficial.  That way they can direct you towards the proper type of tire, what is available in what size (as we all know the smaller wheel sizes are getting harder to find) and THEN you can start a search for the wheels that are most appropriate.
Another option would be to look on Craigslist for fox body Mustang 15 inch wheels. The ones I have cost $100 for 4. And they're not bad. Somebody wanted bigger. Worked for me.
79 to 93 years. Stay away from the newer ones, the offset is different than these and while they can be used, you don't want to mess with the hassles it takes.
Summit racing sells them also, just tell them you want stock offset but 15 inch. Pick a few out on their website and post links here. We can help you with what works.
Well, Summit only has a few. But fox mustangs are popular l know there are many more around.
Bill, where about are you located?
I have a set of fox mustang after market 15 inch wheels on the 79 that need to go away since I am converting to 5 lug. They have decent tires on them but might not be any better than yours in the weather.
Shipping might be a problem but I could take the tires off.
JoeBob
I bought the mustang wheels last year. I bought the last ones in the yard. I did not inspect them closely, two were damaged. There are no more available.
I am trying to locate after market wheels, but have not had any luck yet. This is my driver. As it is now, I can not leave the house if the road is frosty. This is not a serious problem as I am retired.
I contacted a custom wheel manufacture to see if they carry blank wheels and can add the correct pattern per my request. They are going to call back. I do not understand much about cars. I understand measuring to see if tires fit, but don't under how that applies to offset. I am sure I need to understand this before I order. If anyone knows any aftermarket 15"wheels I would be grateful. As far as the availability of 15" tires in the future, I figure this purchase will out last me.
Deuteronomy 7:9
The more important question is, "What are you trying to accomplish?" The Ford Fox body cars came with 14", 15" and 16" wheels (steel and alloy) that are the same 4.25" X 4 pattern as the Pinto. Aftermarket wheels are also available. So, if you are just trying to get a different wheel size because there is more tire variety then you would not need adapters, just different wheels with the 4.25" X 4 pattern. Do note that I hear people complaining that even 15" tire are getting more difficult to find though I'd think they would be more available than 13" tires.
Tire bulge becomes a factor in wheel offset.  On the rear you can just measure with a straight edge from the brake drum face to the most likely point of contact - the leaf spring. A lot of times the leaf springs are not parallel so measure at the front and back at the anticipated bulge point of the tire.  On the front it gets a bit tricky because clearance issues arise from the turning of the wheels.  Hopefully someone here who has bought wheels can give you a better idea of the numbers that they had to work within. That all said Pinto's have very generous wheel opening. I have temporarily run 225-60-16" on my Pinto with minimal rubbing..., not that I recommend this (see image). On the rear I think I used about 1/4" of spacer and none on the front.
Lastly whenever the tire size is increased the diameter also increases unless one steps the tire series (70, 60, 50) down. I say that because a taller tire will have the same effect as a numerically lower ratio. That will be slower off the line and slower to gather speed. Also the speedometer reading will be off. So just a few things to consider.
Craiggarrett1969
You can use a mustang notchbacks 4 lug rim
JoeBob
I know this issue has been covered a 100 times. I was dumb and did not read about it then, because I did not need it at the time. I bought new Goodrich 205 60 13 all season tires. They are worthless if wet.  These are the only tires I could find 13" Is there such a thing as a 4 to 5 lug adapter? I may need custom wheels made. Do 15" wheels fit safely. I don't know the proper wording for this. what wheel depth or offset do I need.
Thank you
Deuteronomy 7:9
