  • Online today: 261
  • Guests: 192
  • Total: 192
2.0 engine enthusiasts..
Started by LongTimeFordMan, November 20, 2018, 11:44:12 PM
It will work fine, no problem with your application.
Bret Culpepper
My 122c.i./2.0 has the Blackjack Header, Weiand Intake & the Holley 390c.f.m. & I wish to install a T9.
I know the T9 has specific weaknesses, but will there be a problem matin my 122c.i./2.0 now?
72DutchWagon
The Merkur had a turbocharged 2.3 Lima with a T9 behind it. So now I guess that all T9's in the US have an input shaft for a 2.3 Lima engine.
LTFM, I'm sorry but I don't think you will be able to find that donor car in the States, it is a European Ford Sierra, the bodyshell is very much like the US sold Merkur, but in Europa it was available in many body styles, with carbureted 1600, 1800 and 2000cc Pinto engines, and 2000cc Pinto EFI (and diesel!).
The factory EFI head is said to be flowing as well as a stage 2 tuned carbureted head.
Stock EFI was 115 HP, later they were detuned to 100 HP for emissions by lowering the compression.
In the US it might be an idea to just get a Pinto specific throttle body set up, or make one up, and then find a 79 or younger fuel injected Volvo 240 B21F and scavenge all the electronics, ecu  and sensors from that. The Pinto can be bored to a 2.1 too if desired.
LongTimeFordMan
What model.car is this and where can i get one for a donor..
Is this the mythical mercur?
72DutchWagon
Robert, so you got the T9 working with a 2.3 bell behind the 2.0? Great to hear!
Blaine might be interested in the details, though it will be easier for him, your T9's all have the V6 input shaft I guess.
Everything OK here, just doing more driving then wrenching this year.
Srt, hope you won't get more annoyed, but you might want to take a look at what these Swedes are doing with a stock EFI Pinto 2.0, which basically has the same engine block as the 70's cars.
https://www.youtube.com/watch?v=k7OnjQZiytM
man do I wish this stuff had been around in the early 1970's
Quote from: 72DutchWagon on November 29, 2018, 01:31:25 PM
forum with a ton of information on tuning the Pinto 2.0;
http://www.turbosport.co.uk/forumdisplay.php?f=179
I posted it here before but a reminder might come in handy.
Fuel injection conversion example 1:
http://www.webcon.co.uk/shopdisplayproducts.asp?id=959&cat=Retroject+Kits
Fuel injection conversion example 2:
https://store.jenvey.co.uk/ford-2l-pinto-tbp45-kit-ckfd17-kit
I'm still happily plodding around with Donkey, my 72 wagon with 85 EECIV EFI Pinto, 90 injection head with factory hardened valve seats and Kent cams FR34 injection cam, T9 5-speed, 79 Mustang II 8-inch rearend with 3.40 gears.
robertwwithee
Hope all is well Geert.  My T9 has worked out well.
72DutchWagon
LongTimeFordMan
I just relocated to texas a cew years ago from los angeles and have been looking for fun roadtrips..
How far are you from dallas..
Also, have yiu done any of the pinto stamped events
cossiepinto
FordMan, I'm out in West Texas.  If you're out this way, drop in and we'll do some bench racing.
LongTimeFordMan
Ill try to look up links to spme of the pix ive made of the mods to ign wiring for pertronix and distributor curving mods as well..
LongTimeFordMan
You can also download and read the pdf  on a phone or pad without printing it..
Then if desired print selected sections
Also Ive been doing a lot of experimentation with tuning, especially distributor, ign and cam timing and there are pix of the mods in my posts..
Feel free to search the posts and comment..
cossiepinto
Yep, there it is.  $22.  Full of info on both the SOHC and the Cosworth 2.0 engines.
Cheaper than paper and ink for the printer.
Thanks FordMan!
LongTimeFordMan
cossiepinto
LongTimeFordMan, I was the temporary owner of the Galpin Ford-sponsored Trans Am Pinto.  I talked to the owner/driver George Cheyne once before he passed away about the car.  Then a few years later, I had the opportunity to buy it from a guy who had bought it from Shankle Engineering (they built Cheyne's engines) a few years later.  I think his name was Mike Boyd (North Hollywood, CA).  Neither Mike nor I drove or raced it.  I sold it to John Ed Smith (Knoxville, TN) in the late 90's.  He campaigned it in vintage for a few years, then sold it.  One of the designers/consultants on the car build was Dave Bean (Dave Bean Engineering, San Andreas, CA), who actually flew to Sebring to co-drive the car with Ed Smith on its debute in vintage racing.
I think Ed was the one who sold the Pinto back to Galpin, and it's in their museum now.
Sorry, but I don't have any of the engine details, except that it was on twin Weber 40mm (maybe 45) DCOEs, dry sumped, etc.  I gave Mr. Smith all the tech sheets when he bought the car.
Henrius, the question was how to modify the 2.0 for performance.  I suggested there's a good source for that info.  I remember that book went out of print for a short while, and the price skyrocketed.  Now it's available again for $69, which would be a good investment if someone were going to spend hundreds/thousands building a 2.0.  I was looking for a replacement for my book, since it was literally coming out of the binding, and I did find it online in a pdf file with a free download.  All it cost was the paper to print it on.  It's probably still out there somewhere.
These engines are not so rare that the "heavy" components aren't available here in the States, either. Most of the advice in the book was on setting timing, distributor mods, carb jetting, etc.  A full-on 2.0 will need side/down draft multiple carbs and camming to complement, along with the heavy-duty parts to make it last. $peed co$t$, so any cheap advice ($69) is a worthy investment.  Or check for the free download, and buy a ream of paper and some ink.
I followed some of the book's suggestions on the Cosworth build in that same book, and I'm sure it saved me more than $69 in my build.
Regards to all, Paul Ramsey (Cossiepinto)
LongTimeFordMan
evo_208
Thank you all so much...  I thought so...  And yes, My head is at the machine shop to get new hardened seat when they discovered a deep crack in the head.. I will take what ever head I get to the machine shop and have them update it,, And I will look into that cam shaft...  You guys are great..
                                    Thanks
                                               Evo
LongTimeFordMan
If you need a camshaft theres a great place on los angeles that will grind a custom cam from your core. He has a small.shop, has been in business since the 70s and has had a lot of experience with 4 cylinder cams.. You just tell him what you want, power band, intended use and he will grind one for you.
Usually costs under $100 including return shipping. And turn around is usually less than a couple of weeks..
The website is
https://www.americancustomcam.com
Ask for Joseph, tell him Ed Manges referred you..
LongTimeFordMan
Also, its always a good idea to have hardened seats installed when having a head redone. Costs a little more but worth the cost and effort.
I just had a head done here , complete valve job, new seats, valve guides, cam installed, head milled .040 for $300.
Maybe a little high but done by a good local.shop.
Where are you located evo
No, it will not fit. They are different engines. Your 2.0 is an EAO engine. The 2.3 sourced 2.0 head they sent you is a Lima engine head that was used in the Ranger. They are different.
Your 2.0 EAO engine was made in Germany.  This link defines the difference (scroll down to 2.0) https://www.pegasusautoracing.com/document.asp?DocID=TECH00149
BTW, got your PM regarding a head. I'll answer it here. No, I don't have just a head. I have a complete engine. While it ran, it smoked quite a bit. The compression was low and some valves had zero or less clearance. So the seats must have a fair degree of recession. In essence the engine needs a rebuild. It is NOT something I will ship. So it is pick up only. I'm in Southern California.
BTW, there seems to be a LOT of mis-information on the Internet.  While the 2.0 EAO engine is "similar" to the 2.0 Lima engine they are completely different as far as parts swapping.
LongTimeFordMan
2.0 head has 3 cam bearings, 2.3 has 4..
Check post by wittsend, he has a complete 2.0 for sale...
evo_208
I'm gonna ask a dum question...  I'm trying to buy a 2.0 head for my 73...  This company sent me a head with 4 cam bearings and I told them that mine has 3 cam bearings.... They then told me I was wrong and that is the right head and there are 2 overhead cam cyl heads for a 2.0...  I don't think that's true...  and will a 2.3 head fit on a 2.0???
LongTimeFordMan
I made my own manifold for SUs.. i found a set of HIFs from a 72 mgb with manifild and linkage on ebay for $150.  I made the manifold from tubing salvaged from a directv antenna mount and some 1-3/8 emt and some 1/4 steel plates..
I posted pics awhile back but heres another..
Btw..  the upgrade to the SUs improved both low end torque and upper rev capacity from 4200 with the stock webber to 6000 with the SUs. And personally i think the SUs are a lot easier to tune than the webber DCOE setups..
Quote from: Henrius on November 23, 2018, 07:45:58 PM
Nice, but $69 for a paperback? I have got David Vizard's 2.0 upgrade book and it is the Bible. Trouble is, Dave is a Brit and talks about all the parts he could get over there. Some you still can, but heavy engine parts cost a lot to be shipped from England.
Esslinger used to be the go-to place for the Ford 2 liter but no more.  The Pinto Hooker Header is long gone.
LTFM made his own dual SU setup. It is somewhere on this site. Maybe he will post a link. Not everything needs to come from Jolly old England.
Side story: Back in the 1980's I bought an Offenhauser intake at a thrift store for $6.98.  My reasoning was if I ever got a Pinto..., I'd have a nice beginning for modifications.  I had it for over 20 years. Then when I bought my Pinto back in 2007 I dug it out.  I knew I was going to a 2.3 turbo but was curious because the car originally had the 2.0.  Well it turns out it wasn't a Pinto intake it was for a - VEGA.  I looked on line and saw that a few has sold for around $100. So I put mine up at a $9.99 attractive start price and figured it would get bid up. Ahhh..., No! It sold for $9.99. After Ebay fees I probably made $2.00 after holding on to it for 20+ years. Oh w-e-l-l.
LongTimeFordMan
As far as fuel injection..
Megasquirt has universal kits with pump, injectors,  omputer, etc but its a lot of effort to install and calibrate..
A 350 cfm ford 2 bbl or 390 cfm holly works really well.. buy the 2.0 vibrates a lot and the booster venturies tend to work lose after about a  year..
Onereason i went with a pair of SUs.. nothing to wear out..
Henrius
Quote from: LongTimeFordMan on November 20, 2018, 11:44:12 PM
I was just thinking that since the 2.0 engines are getting rare, perhaps a thread could be started with building tips for them..
[/quote
Can't remember where on this forum but there was someone who hot-rodded his 2 liter with fuel injection and had it for sale. I would like to know where he got the parts to do it.
1973 Pinto Runabout with upgraded 2.0 liter & 4 speed, and factory sunroof. My first car, now restored, and better than it was when it rolled off the assembly line!
Henrius
Quote from: cossiepinto on November 23, 2018, 01:21:57 PM
https://www.amazon.com/Power-4-Cylinder-Pinto-Cosworth-Engines/dp/1903706106
Very informative book for building the 2.0 Cosworth, but also the SOHC 2.0 engine.
LongTimeFordMan
I think that someone bere mentioned that he once owned the Galpin Trans AM pinto.. do you know how the engine was set up, what mods, etc
cossiepinto
LongTimeFordMan
I agree.. i think the 2.0 is underestimated in the US , they are still building them in europe.. i agree that 160 hp is doable..  as mentioned brfore simple mods like adjusting cam timing, distributor curve and carbs can add a lot of hp at reasonable cost, my goal is to maybe get some 2.0 enthusiasts together, maybe start a forum specifically for 2.0 to exchange ideas..
I have had exp with 2.0 on cir le tracks and they do well.. onky problem is lack of access to hardware
