1600 CC WATER PUMP
Date: 06/02/2018 09:13 am
Date: 08/30/2018 12:59 am
2.3 carb intake
Date: 07/15/2020 09:25 pm
1980 pinto/bobcat floors
Date: 07/24/2018 08:11 pm
Date: 10/25/2019 03:30 pm
1979 Runabout Rear Panel
Date: 01/04/2020 02:03 pm
Pinto Wagon
Date: 05/25/2018 01:50 pm
Date: 02/27/2017 10:10 pm
1980 Pinto taillights
Date: 12/26/2017 03:48 pm
  • Online today: 279
  • Guests: 280
  • Total: 280
2.0 engine enthusiasts..
Started by LongTimeFordMan, November 20, 2018, 11:44:12 PM
robertwwithee
Quote from: Wittsend on November 21, 2018, 11:38:58 AM
Apparently not rare enough.  For years I've been trying to find a buyer for my 2.0. I removed it when I went to a 2.3 Turbo engine.  86k miles, air cleaner to oil pan, fan to flexplate. Compression was in the 125 to 140-ish range. The engine smoked so I assume it was the valve seals??? The only other negative is that a heater hose ruptured and the coolant cracked the exhaust manifold. But I assume anyone who would want the engine would rebuild it and use a header anyway.
I offered it for the mere sum of the core charge at Pick Your Part ($75) and never got any takers. Anyway, I have no intentions of shipping it but if anyone is willing to pick it up, it is still $75.  I'm in Southern California.
Yea, i found couple near me for around $100.  Running with carb, dizzy, exhaust, etc.
robertwwithee
Those with 2.0 tend to stash performance parts, myself included.  Im lucky enough to live near Ivey engines and have good enough relationship to assist me.  Ivey engines is a West coast 2.0 specialist building Formula and Sports 2000 engines.
Spec/basically stock motor will net 161 hp, i seen it.
LongTimeFordMan
Well as i mentioned, the main reason i posted was to maybe connect some 2.0 owners to share info about parts and tuning..
The 2.0 is a good little motor but you are both correct that parts are becoming hard to find at a reasonable cost.
There are a lot of go-fast goodies out there though.
LongTimeFordMan
Well back in 1980 i had a 72 capri with a 2.0 and i redid the engine with a 465x 310 isky cam, mallory dual point distributor, hooker header and 390 cfm holly 4 bbl and it ran really strong..
Ive heard a lot of opd timers have had good luck with the 2.0 and since there are still some early pintos with the 2.0, it would seem that tweaking the 2.0 would be a simpler choice than doing the 2.3 conversion.. but its getting difficult to find new speed parts and i was thinking that there are prolly some used stuff around if it could be found..
I was thinking maybe some folks who have done the conversion may have some good used stuff around..
No, I never did. I had the 5 sp. Turbo Coupe as my daily driver for 10 years. So it was "donor ready."  Cart before the horse I had the donor car before I had the Pinto to do the transplant.  With the auto trans the 2.0 was very underpowered. And with the 2.3 turbo ready and waiting I never opted to improve the 2.0.
LongTimeFordMan
Did you ever get involved in building a performance 2.0.  Ive found that with some basic mods, carburetors, distributor recurve and cam t8mi g a stock cammed 2.0 can be improved a lot
Got ya. Well at least it prompted me to again make my 2.0 engine availability known.  To quote Ben Stein, "Anybody..., anybody..., anybody?
LongTimeFordMan
Hi.. thanks for the update.. too bad we didnt connect before i moved from north hollywood to texas.  The problem that I have encounteres isnt with finding rebuildable cores, its finding performance equipment like headers, manifolds, etc and sources for tuning tips, such as how much valve lift/head milling can you use before needing to notch the pistons..
I see a lot of info about the later model 2.3 engines but not much for the 2.0
I do see some folks posting about 2.0 performance upgrades and assume the die hards might want to stay in touch to compare notes..
LongTimeFordMan
I was just thinking that since the 2.0 engines are getting rare, perhaps a thread could be started with building tips for them..
