Interior Parts
Date: 08/07/2017 03:59 pm
Date: 07/30/2020 11:45 am
Date: 10/25/2019 04:05 pm
Date: 11/11/2019 04:49 pm
1980 Pinto w/ Trunk
Date: 08/10/2022 04:09 pm
78-80 Windshield
Date: 10/29/2021 03:11 pm
Date: 04/12/2017 06:57 pm
1980 Pinto taillights
Date: 12/26/2017 03:48 pm
Date: 12/09/2016 08:34 am
  • Online today: 1,106
  • Guests: 233
  • Total: 233
Steering Column
Started by Jdm071755, March 18, 2018, 11:03:37 AM
The end of the column where the rag joint connects can move in or out of the column.  You might have to extend it out some to make up for the difference.  good luck to you.
Jdm071755
Quote from: pintosopher on March 18, 2018, 04:29:18 PM
Unless the Column safety Collapse feature was disturbed, or the rack was removed, all should be lined up and within the measured specs. Is there excess play in the rack pinion shaft?
Everything went together fine. Problem is that the rag joint is not  laying flat. The manual says if this occurs to pry up or down the column to correct this
Joe
Jdm071755
Quote from: pintosopher on March 18, 2018, 04:22:25 PM
Is the Column too short, or is there a misalignment?
Just seems a Little short
Joe
Jdm071755
Just replaced my rag joint  after putting it back together it seem the steering column needs to be adjusted down. I checked my manual but it was vague.  Anyone adjuster one? This is on an 80 cruising wagon.
Joe
