  • Online today: 1,166
  • Guests: 90
  • Total: 90
Bleeding brakes
Started by Jdm071755, November 02, 2017, 04:35:06 PM
Jdm071755
Quote from: dick1172762 on November 08, 2017, 10:17:57 AM
Let us know what you find inside. If I remember right, there is a threaded hole in center of the fitting. Remove what ever is screwed in the hole and replaced it with a bolt. Use this bolt to make sure the part that slides back and forth stays centered while your replacing the part. Just make the bolt finger tight. Bleed the brakes and then remove the bolt.
This is what I found so far. This piston is fused to the 5/8 inch not. Soaking it in Ammonia per rebuild instructions
Joe
Jdm071755
Quote from: dick1172762 on November 07, 2017, 12:03:43 PM
I still think the way to go would be to remove the other of the brake line and slide a box end down the brake line to the stuck fitting. A box end wrench would grip the fitting much better.
Got it out. Now I'll take it apart and see what's wrong
Joe
The flair nut wrenches taper on the contact surface. If you can tap the wrench on the nut it make sung up and help - a little. Every little bit helps.
Jdm071755
Quote from: Wittsend on November 06, 2017, 05:00:17 PM
Those are called "Flair Nut Wrenches." Unfortunately if you tried a regular open end wrench first (been there, done that) the nut likely distorted and then even the flair nut type can have issues. Sometimes I have had to resort to vise grips that mangle everything. I've even had tubing that stuck to the nut so tightly that when the nut finally turned it just twisted the tube too! Try a penetrating oil (and some heat like Dick mentioned). No guarantee it will work but it is an approach of last resort.
Thanks everyone. I will try some hear and see what happens. I'll let you know how I make out
Joe
I went to our hardware store and got a name brand wrench for under $10.00.
Would not hurt to heat the fitting before trying to break it loose. MAKE sure the wrench fits tight. Metric wrench's will not work so don't use one. The wrench to use is 5/16 or 3/8 inch. You will know the right end when you try the wrench.
Yes, that is the type Dick is talking about. Can't tell from the picture what brand it is. Cheap ones (in wrenches in general) have a tendency to be not quite the right size. Or the nut may have just gotten a little wore. I've never had good luck with one once it starts to round off.
Have you tried soaking the joint in something like PB blaster?
In the past I've ended up having to use vise grips, which will ruin the nut. But sometimes you don't have a choice.
Jdm071755
Quote from: dick1172762 on November 04, 2017, 01:35:24 PM
What you need is a brake fitting box in wrench that has a slot on one side to allow it to be slip'd over the brake line. DO NOT buy a cheap one as it will take a lot of pulling to break the fitting loose. Look on e-bay for a picture of one.
I tried this tool 7/16 end and it did not work. Is this what you are talking about?
Joe
Jdm071755
Quote from: dick1172762 on November 04, 2017, 10:38:22 AM
Looks like a very though out kit with all the parts necessary. Go for it.
Trying to get brake lines off of proportional valve. Striped one so far. It seems 7/16 wrench is a little sloppy in fit. What is correct size?
Joe
Jdm071755
Quote from: dick1172762 on November 03, 2017, 05:41:37 PM
Proportion valves can be taken apart and made to work again.
I found a rebuild kit. It it worth getting?
https://www.musclecarresearch.com/valve-kit-kh-D7DZ
Joe
Jdm071755
Quote from: pintosopher on November 03, 2017, 01:55:44 PM
That combination Proportion valve is stuck, allowing fluid to move to the rear wheel cylinders only. A sure sign would be the fluid in the master cylinder only drains from the one half that you can bleed (rear).
Now the problem is finding a valve. I did find this
Joe
Jdm071755
Quote from: pintosopher on November 03, 2017, 07:01:26 AM
From the sound of it, you would need to verify that any fluid is getting through the front Steel lines to the hoses. If none is there after applying pressure, then it's a sure thing that the Proportioning valve is stuck and isn't allowing the fluid to the front steel lines. Otherwise, I would make sure those new calipers aren't defective and stuck or clogged. There are some You Tube videos on servicing a valve, not Pinto specific, but possibly some help and very informative. ( Check out the Mercury Cougar one)
Good luck and keep us posted,
Ok what I did was disconnected the metal brake line from the flex line on the drivers side and still a hard pedal
Joe
Jdm071755
Quote from: pintosopher on November 02, 2017, 07:41:13 PM
If the rotor won't move freely with the pedal released, the Proportioning valve may be stuck and won't allow the fluid to move to the calipers and allow the master cylinder to directly move the caliper pistons. This is a problem as the valve is no longer available . My 72 just recently pulled this trick, and I fear the whole system is going to need the parts replaced.
If anyone has a source let us know..
My rotors spin freely. When I did the back brakes I was able to bleed the rear brakes. So not sure what to try next
Joe
robertwwithee
I got a 79 prop valve that may work for ya.  I dont get home until nov 12 though
Jdm071755
Doesn't sound promising
Joe
Jdm071755
Quote from: Jdm071755 on November 02, 2017, 05:30:21 PM
I'll give it a try
I took the bleeder all the way out the pushed on the pedal still won't go down
Joe
Jdm071755
Quote from: robertwwithee on November 02, 2017, 05:28:56 PM
Take bleeder all the way out and check its not filled with contamination.  Small drill bit from top and side hole to clear.
I'll give it a try
Joe
robertwwithee
Jdm071755
Quote from: Jdm071755 on November 02, 2017, 04:35:06 PM
Replaced calipers and pads I tried bleed brakes but I have a hard pedal this car is fighting me all the way
Oh I also replace the flexible brake line
Joe
Jdm071755
Joe
