Date: 11/05/2016 09:03 pm
Date: 10/25/2019 04:05 pm
Rally spoiler wanted
Date: 05/04/2017 01:32 pm
Date: 12/30/2022 01:30 pm
Weber dcoe intake 2.0
Date: 08/01/2018 01:09 pm
Tire needed p185/80r13
Date: 12/31/2017 09:08 pm
Pinto Runabout wanted
Date: 06/05/2018 04:42 pm
Date: 12/26/2016 04:29 pm
  • Online today: 1,106
  • Guests: 132
  • Total: 132
Hard starting?
Started by dholvrsn, February 24, 2017, 08:15:09 PM
Does it still have EGR? If so, make sure housing isn't cracked , valve stuck open with carbon, Vacuum diaphragm intact and all vacuum hoes in good shape. If the engine only runs fine when warm, it could be a intake leak anywhere that is leaning out the mixture too much to allow the choke to richen the mixture enough.
Any FAQ or anything about when your 2.3 is really hard to start? It takes a lot of pumping across a lot of attempts to get it going. So far, the automatic choke does work as far as it's closed when the car is stone cold and opens wide when it warms up.
