73 Caliper Retaining Key
Date: 10/28/2021 07:49 am
2.3 front sump oil pan
Date: 07/24/2018 03:17 pm
Date: 01/04/2017 04:07 am
72 Pinto parts
Date: 12/04/2018 09:56 pm
Date: 03/17/2019 10:15 pm
Date: 01/28/2017 12:30 pm
79 pinto steering column
Date: 08/18/2018 02:00 pm
Pinto Wheel Well Trim
Date: 03/29/2017 11:35 am
Pinto Fiber Glass Body Parts
Date: 01/06/2019 06:53 pm
  • Online today: 2,399
  • Guests: 1545
  • Total: 1545
Fragged!
Started by entropy, July 31, 2016, 05:33:23 AM
entropy
This one's more set up for the "drive it to Mexico" variety...  ;-)
1972 Hoonabout
SBF swap
-308 cid
-CNC ported Brodix heads
8" rear 4.11 posi
G-Force 5 Speed
10 point rollcage
Racing as on a trailer going to a drag strip. That's racing.
entropy
Quote from: dick1172762 on August 17, 2017, 04:22:07 PM
   Smart move. Old carb is / was made for racing.
So's the car, for the most part....   ;-)
1972 Hoonabout
SBF swap
-308 cid
8" rear 4.11 posi
G-Force 5 Speed
10 point rollcage
Quote from: entropy on August 16, 2017, 11:21:39 PM
Update:  Got tired of trying and failing to get that Holley Double Pumper to work right on the street.  Off it comes, and on goes a QuickFuel Brawler series with vacuum secondaries.  Feeling good about this one....
entropy
1972 Hoonabout
SBF swap
-308 cid
8" rear 4.11 posi
G-Force 5 Speed
10 point rollcage
Quote from: entropy on May 13, 2017, 12:35:26 AM
Boom!  Today, and for the first time since July 2016, the car went down the street under its own power.  Got a bit of tweaking to do on it and then all the cosmetic stuff goes back on.  After that, it's back to doling out the harshness on the streets....until the next thing breaks.  ;-)
Congrats on restoring terror and discipline to the Streets, We applaud the Riders of the Storm ;)
entropy
1972 Hoonabout
SBF swap
-308 cid
8" rear 4.11 posi
G-Force 5 Speed
10 point rollcage
Well it kind of wound up being like a friend of mine called me and asked how can you tell if you over speed a engine , my reply was does it fit lossy in a five gallon bucket, guess yours fits that description well   :o
entropy
Quick update:  Engine and trans are still out of the car pending a weekend that isn't raining or threatening to rain.  I used some of the downtime to autopsy the T5 that broke.  Great googly moogly....I assumed that I had broken 3rd, since it broke during the 2-3 shift but noooooope!  Turns out I broke every tooth off of the main input shaft gear and turned the countershaft gear into more of a countershaft....disk.  Oh, well.....the G-Force should hold up a bit better.
1972 Hoonabout
SBF swap
-308 cid
8" rear 4.11 posi
G-Force 5 Speed
10 point rollcage
Quicktime on my B2.
Get in touch with them & tell your combo (motor/trans) to get the right one.
entropy
Quote from: russosborne on October 29, 2016, 11:50:27 PM
I would go with a new SFI rated flywheel for sure.
Are you running a safety bellhousing? Sounds like you should be.
I'm looking at the QuickTime ones.  Any experience with those or any others?
1972 Hoonabout
SBF swap
-308 cid
8" rear 4.11 posi
G-Force 5 Speed
10 point rollcage
entropy
Update: I've picked up a G-Force T5 and a McLeod Street Pro clutch.  I need to have the flywheel resurfaced (or possibly replace it with a new SFI rated one....still deciding), and soon my little monster will be back on the street doling out the harshness to cars that cost 10x more.
1972 Hoonabout
SBF swap
-308 cid
8" rear 4.11 posi
G-Force 5 Speed
10 point rollcage
Thought I had pictures of my T-5 - couldn't find them.
I do (sort of) posting about it before.....cannot find the topic though.
Fairly sure it was determined to be a WC T-5 for a V8.
Will look into it......
It's easy to tell apart WC and non-WC T5s without a tag. The bearing cup on the input shaft side gives it away. I was going to suggest a toploader until you said it needed OD.  ;)
There's also Astro T5 transmissions.
entropy
Quote from: Reeves1 on August 12, 2016, 07:05:08 AM
Now you got me wondering what T-5 I have in the shop...... do not recall a tag on it.
Big job to get at..... 3-4 engines/blocks to move & a truck load of other stuff !
Probably worth looking at, 'cause it it's one like mine, it simply will not do behind a V8 or turbo 4
1972 Hoonabout
SBF swap
-308 cid
8" rear 4.11 posi
G-Force 5 Speed
10 point rollcage
entropy
......Aaaaaaaaand now I'm screwed.  The broken trans didn't have the aluminum tag with the serial number, so I had to do a bit of internet digging to find out what year Mustang the thing came out of.  Wow.  Not good.  1983.  That's right....guy who did the swap put an early  non-WC T5 transmission behind a small block that dynoed 350 lb/ft at the wheels. That's somewhere north of 400 at the flywheel. Being run through a transmission rated to somewhere around 265 lb/ft.  I'm surprised it lasted *this* long.  Seriously.
However, this also means that my trans is an even *more* useless paperweight, since I can't use this case to build anything worthwhile.  So....anybody in CA. got a 1985 or later T5 they want to sell? Broken is fine, since it's going to get turned into a Gforce Street t5
1972 Hoonabout
SBF swap
-308 cid
8" rear 4.11 posi
G-Force 5 Speed
10 point rollcage
entropy
Quote from: Reeves1 on August 04, 2016, 06:40:04 AM
You being in CA - should be lots of places that can build a bomb proof T-5 ?
Yeah...I should be getting a quote tomorrow on a gforce rebuild.  Still trying to decide if I want to go dog box or stick with synchros.
1972 Hoonabout
SBF swap
-308 cid
8" rear 4.11 posi
G-Force 5 Speed
10 point rollcage
entropy
Quote from: dick1172762 on August 04, 2016, 10:23:56 AM
C4 or Torqueflite.
thought about it, but I like having a clutch car and that overdrive is important when you've got a 4.11 gearset.
1972 Hoonabout
SBF swap
-308 cid
8" rear 4.11 posi
G-Force 5 Speed
10 point rollcage
entropy
Got the engine and trans out on Sunday.  The clutch is absolutely fine.  The trans...not so much.  I haven't cracked it open but it is *definitely* broken up pretty good in there. I knew it would break eventually...I mean, even though it's a light car, I'm still making about 100 lb/ft of torque more than it was rated for. Add drag radials and set the countdown timer.  So, now the question is what do I do about it?  The obvious and expensive answer is a gforce built T5.  Probably a faceplated one.  The other expensive answer is a TKO-500, but I can't imagine that's going to fit without cutting out the tunnel...which I really don't want to do. Anybody done one before?  Thoughts?  Suggestions?  Anybody got a burly, built T5 laying about?
1972 Hoonabout
SBF swap
-308 cid
8" rear 4.11 posi
G-Force 5 Speed
10 point rollcage
Keep us up-dated please
entropy
So, I was doing some tuning on the V8 car a couple weekends ago.  The good news is, it made a whole lotta' buncha' more power.  The bad news is that during a...let's go with "street test"...after spinning through first and second, it used that power to frag something in the drivetrain during the 2-3 shift. "Why yes, AAA I'm going to need a flatbed tow in this empty industrial park.  Racing?!  Oh, heavens no!  That would be illegal and, after all, it's only a Pinto..."  So the engine and trans is coming out tomorrow.  My guess is something in the clutch came apart energetically (but not so much that it went through the bellhousing)....or I broke the input shaft off the trans.  I think it's likely the former.  The sound's coming from the bellhousing area and it sounds a lot like somebody put half a ton of scrap in a cement mixer.  Oh well....breaking things means an opportunity to bombproof it for the future, right?   :'(
1972 Hoonabout
SBF swap
-308 cid
8" rear 4.11 posi
G-Force 5 Speed
10 point rollcage
